Motorola 9505A Sat phone and sms
Submitted: Friday, Apr 13, 2007 at 20:10
lifeisgood
Hi I am looking at purchasing the 9505A Satphone without a plan and using my Telstra GSM phone sim card on Global roaming when beyond normal mobile range (ie most of our Melb.-Kakado trip coming up soon ) Can anyone advise if an sms sent to us will be received and can be read on the sat phone (with our Gsm sim inserted) Also can an sms be sent out from the 9505A.
Comments from anyone who has tried this would be appreciated.
Secondly , I have a $2600 price from our site advertiser , (includes external antenna kit) Does any one know of other prices and deals for outright purchase.?
Telstra apparently has $1900 but requires a 2 yr plan.
I do not Qualify for the Govt remote subsidy. Thanks
Reply By: Smudger - Friday, Apr 13, 2007 at 21:19
My understanding is that you would have SMS reception, senders can also message you via email, and you'll also have SMS TX ability.
Try these guys, they gave me some good tech advice. www.trtelecom.com/default.asp (If it doesn't hyperlink cut and paste it)
Another option is to get hold of a 9505 model, now only available 2nd hand, they should be a heap cheaper to buy, same drill for using with Telstra sim card and I believe same TX/RX functions. I have the older 9500 model, it does the job for basic emergency coms, but no SMS or email ability. If available they are 2nd hand for around $1000.
233215
Follow Up By: lifeisgood - Friday, Apr 13, 2007 at 22:30
Thanks Smudger Did you get a external antenna with the 9505 package?
I will check out that site.
494105
Follow Up By: Smudger - Friday, Apr 13, 2007 at 22:56
Mine is the older model 9500 ..yep external antenna, 2 batteries, battery car charger. Have never needed to use the external antena, the short one has always done the job. If you can see the sky you're on the air.
When I was shopping I saw an ad for a 9500 where the seller said .."I bought it for my Himalaya trek and checked home on it daily."
Like I said, I paid $1000, that was about a year ago. I still see them occasionally for around that.
494112
Reply By: marq - Saturday, Apr 14, 2007 at 08:01
If you wish to purchase new - talk to TR Telecom.
$30/mth plan for 4 month minimum term, $15/mth to hold account
Ask them to match Telstra's price of $1995 for the 9505A kit (contains leather case, ext antenna, international adaptors, etc)
As said above - the SMS is via email only, however if you have a website hosted with php or similar, then you can have a script running which (say):
1) looks at new email for a particular email address from the satphone
2) grabs the phone number from the beginning of the email
3) sends an email to a email to SMS gateway for normal mobile phone deliverly.
SMS's are $1 ea from the satphone.
233275
Follow Up By: lifeisgood - Saturday, Apr 14, 2007 at 12:45
Mmmmm so that means you could buy the phone at $1995. After 4 months and $120 worth of plan (4 x 30) end the relationship and just use it with your Telstra sim when needed after that ? Assuming there is no cancellation fee after the 4 mths and the phone is not locked.!?
Hope you dont work for TR Cheers
494191
Reply By: marq - Saturday, Apr 14, 2007 at 20:05
The phone is unlocked to start with - but the 4 months min may or may not be required (ask them) to purchase new.
No I do not work for TRT -
Just that I hate burning money with Tel$tra - 24 months is bs....
233392
Reply By: prado geoff - Saturday, Apr 14, 2007 at 21:13
If you are talking about receiving SMS whilst on the Satellite network (as opposed to being attached to the GSM network) I don't think you will receive calls on a roaming enabled SIM card. I tried it last year and none of the SMSes made it through. Refer to posts 41794, 39749 & 42954. The second one has another person who confirmed that SMS will only work if sent to the Iridium SIM card (numbers starting from +8816)
-geoff
233425
Reply By: Member - outback2 (WA) - Sunday, Apr 15, 2007 at 12:08
If you are doing a once off trip why not consider a 2nd hand Telit handset...using Global Star..they are on offer on Ebay through a regular seller and seem to go for around $400 to $600. They are a dual handset that is they switch from GSM to satellite subject to what signal is available...the phones are unlocked...just insert your sim card they say !
I had an Ericson sat phone on Global star..the same deal..no real problems with the service but coudnt get replacement batteries when they stuffed up and so I now have a 9505A with Telstra....they simply had a beter deal at the time.....SMS works fine....from my experience I think the Telstar satellite service might be a little more stable compared to the Global Star..but that may be a reflection on the old Ericcson hand set rather than the Satellites themselves
233524
