Caravan vs Pop Top
Submitted: Saturday, Apr 14, 2007 at 16:06
ThreadID: 44302 Views:11844 Replies:9 FollowUps:4
Hi! We are embarking on caravanning around Australia but with short interstate trips first... my husband and I are at odds about towing a suitable van ie Pop Top or caravan. My preference is a 21' inc ensuite and we have a Landcruiser. Is there any articles re pros & cons of caravans vs pop top pls?
Reply By: _gmd_pps - Saturday, Apr 14, 2007 at 16:18
with a 21' your probably better off with a poptop if there is such thing
as a 21' pop top because the cruiser is going to work hard with a full van that size.
against pop tops is that they are not as dust tight as full vans especially when open and harder to cool down via aircon ...
also pop tops are lighter .. you will save quite a bit of fuel with a poptop over
a full height ..
when I load my slide-on on my truck I am 3.40m high and it costs me usually
around 5-6l/100 where the boat in the back (2.5t) does hardly affect fuel consumption when the camper is on .. and without the slide-on the boat costs me just about 2l/100k .. but I drive the truck just the same with the slide-on as empty
so I could save a bit with slowing down but that makes me itchy ...
I guess with a Cruiser the differences would be more with a full 21'
Go and rent one and the other and try it out ... don't argue about such minor
things in life ..:)))
good luck
gmd
AnswerID: 233350
Follow Up By: disco1942 - Saturday, Apr 14, 2007 at 16:53
Pop-tops are not available in vans over 17'6" (19'6" body length.)
Pop-tops are generally cooler in hot weather due to good ventilation in the top, particularly if you have 6 vents in the sleeve. We rarely miss aircon in our van because of these good vents - possibly 5-8 days per year.
All of your dust problems are from lower down so there is no difference between the two. Any dust getting past the top seal just lies within the folded sleeve. When you pop the top it all falls off
Pop-tops are actually heavier than full height vans. The top must be made stronger than the top of a full height van and you have the large metal frame around it together with the lifting mechanism. When you cut the top off a van there is very little strength in the walls to stop them flopping about. To regain most of that strength you have to incorporate a large box girder around the top. all this makes for a weight penalty not a gain. The old Viscounts with the little pop-top in the middle of the roof may have been a little lighter but not the modern models with their full tops lifting.
FollowupID: 494229
Reply By: Member - Boo Boo (NSW) - Saturday, Apr 14, 2007 at 16:33
tiagc
We have a 20' van with ensuite. When we travelled it was about 2.1t. We have a 1995 troopy with after market turbo and we just leave it in fourth gear and sit on 90-100. It pulls the van just fine.
If we go down hill or have a tail wind I slip it into top gear and sit on 100.
Without the van its about 7-8.5 km per litre, with the van its about 5km to a litre.
You do loose a lot of space for storage etc with a pop top...for what its worth.
Actually we have just moved to Jabiru NT and no longer need the van. Its in Quirindi NSW if you are interested.
Regards Bob
AnswerID: 233351
Follow Up By: Angler - Saturday, Apr 14, 2007 at 16:53
Tiagc,
Weight wise the pop top is only marginally lighter than a full van.
Cost would be about the same.
Storage area is much greater with a full van.
Full vans are fully insulated.
Vinyl is not much of an insulator.
Pop tops vinyl part allows larger windows and they allow in much more light.
Full vans are probably more secure.
Pop tops may go in your garage.
Cost of towing is similar (personal experience with both types)
Full vans are more comfortable when stopping for lunch/smoko etc.
Roll out awnings are harder to use with a pop top.
Had both and will not go back to a pop top.
Pooley
www.bycompass.com
FollowupID: 494230
Follow Up By: Member - Boo Boo (NSW) - Saturday, Apr 14, 2007 at 17:56
Pooley
about 12 months ago had a look at your site and downloaded a few things, but never got around to thanking you so here it is 'thankyou', its a very good site. I'm still having a look at the knots.
Regards Bob
FollowupID: 494244
Reply By: Mikee5 (QLD) - Saturday, Apr 14, 2007 at 16:55
When you say caravan or pop top do you mean a full height caravan versus a pop top caravan or are you asking about the Jayco type wind up and fold out camper trailers? We have a pop top caravan, chosen against full height van for lower wind resistance in towing and better tree clearance off road. We can walk around inside without lifting the roof if I stoop a bit, As I get older and shorter this should be less of a problem though - LOL.
Mike.
AnswerID: 233355
Reply By: Willem - Saturday, Apr 14, 2007 at 17:01
Towing whatever around Australia has its merits and downsides and one can nitpick about this and that and not come to any formal conclusion like you and your husband may be doing
However, you will find that with a Poptop it is a real pain if you want to stop for a bite to eat or to boil the billy at a roadside stop as you will have to 'pop' the top every time you do that. If you are very short in stature this will probably not affect you that much.
We were on the wallaby for 5 years towing a homebuilt 27 footer and it was very comfortable. Towing was a tad more hazardous at times but we managed to get up and over all of the extreme passes in the country that we took on. Truckies hated us we were soooo slow on hills but I used to pacify them over the radio.:-D
AnswerID: 233356
Reply By: yakodi - Saturday, Apr 14, 2007 at 17:03
The difference between towing our 18'6'' full size 2.3 tonne Supreme van Vs 1200kg jayco camper is about 1-2L per 100km with GU Patrol - but we feel it in the hills. The full size van retains more heat in cooler weather compared to camper, heat goes straight out the walls, or in a pop top out the roof.
AnswerID: 233357
Reply By: Member - DAZA (QLD) - Saturday, Apr 14, 2007 at 19:57
Hi Tiagc
We have a 22ft 6 York Procyon full caravan weighs 2500 kgs give or take a
couple of kgs, We tow it with a Nissan Navara ST-R diesel, we sit on 95-100 ks
very easy to tow. The cook loves the toilet & shower, night use only, she hates
walking to the amenities block on a rainy night ect, We had a pop top for a couple
of years, suited our needs at the time, as stated earlier a real pain when you want
pull over for a meal or a cuppa. the little bit of extra fuel far out ways comfort.
WHAT EVER YOU GET I AM SURE YOU WILL HAVE A WONDERFUL TIME.
Daza
AnswerID: 233390
Reply By: Andrew Kilby (QLD) - Saturday, Apr 14, 2007 at 21:09
Can't add much that others have not said but we are glad we have a full height van. The extra storage space via overhaed cupboards and the ability to use the kitchen for making lunch etc while travelling is very welcome.!MPG:7!!MPG:7!
AnswerID: 233421
Follow Up By: bloosted - Saturday, Apr 14, 2007 at 23:38
just wondering what sort of econ you get from the paj while towing?
FollowupID: 494345
Reply By: Go-N-Grey (WA) - Saturday, Apr 14, 2007 at 23:09
Understand the problem. If you are PK (post kids) go for the full height with ensuite.
BC we toured in in a Suzuki 2 stroke 540cc in a 2 man tent and went everywhere.
PS (3 primary school kids) we graduated to a Jayco Finch (campervan) and finally a Jayco Swan (campervan) in which we did the GRR in 1990. We still talk about that trip and the kids now have kids of their own
Kids got older and we went upmarket to a 17" poptop Caravan (5 berth) and did the east coast as far as Sydney from Perth for 8 weeks. We and the the kids loved every minute including -4C at Jindabyne Caravan park, and storm force winds at Adelaide when we lowered the top.
Just recently bought a 22' full height van with ensuite and cant believe the comfort or the cost of fuel.
Over Easter it was just fabulous to cuddle up in bed when it started to rain at Wave Rock knowing there was no wet canvas in the morning, and no drips or condensation onto bedding.
We have come to the following conclusions:
Comfort costs money
Enjoyment is money independent
The older you get the more comfort you need.
We are now VERY happy with our full height 22' 2.7 tonne van with ensuite and 250 litres of water, and we don't go fast.
The kids come in their own cars and sleep in tents outside!! They are much more resilient than us now.
AnswerID: 233468
Reply By: Member - Thomo - Tuesday, Apr 17, 2007 at 21:11
We have a Regent pop top and my mate has a full van have towed both extensively and there is no noticeable difference. The pop top has more head room and has better ventilation however at the end of the day it comes down to what suit you best.
Thomo
AnswerID: 234068
