strange noise in 3ltr patrol
Submitted: Monday, Apr 16, 2007 at 11:27
joeblogs
Hi everyone I have had my tyres fitted Cooper ST 265/75/16. I went this size so that I could still drive in my garage with roof rack fitted. Thanks for all the advice,I now have a noise coming from the engine bay. I had my belt tensioner replaced about 2 years ago and I am worried that a bearing or something is damaged and making weird ticking noises. It seems to be at its loudest when the engine is cold but it can just be heard when warm. My mechanic put some grease on the belt and this seemed to stop the noise for a couple of weeks.Could anyone help diagnose problem as mechanic is talking about the crankshaft ($$$$) or alternator or
water pump in fact he wants to replace things until noise goes away.
Reply By: navaraman - Monday, Apr 16, 2007 at 11:31
Hard diagnosing a noise over the internet. I had a squealing noise which was worse when cold and gradyually disappeared as the engine got warm. it sounded exactly like a belt slipping or a bearing letting go.. It turned out to be a leak from the EGR valve, fairly common as I found out after a bit of research. Might be worth looking at,
mine was covered by warranty but it was a fairly lengthy repair job.
233738
Reply By: joeblogs - Monday, Apr 16, 2007 at 11:46
Thanks for the reply navaraman the noise increases in speed as the engine speed is increased this is why I think it must be a bearing but which one and why does it disappear when grease or spray is applied.
233742
Reply By: Chris & Debbie - Monday, Apr 16, 2007 at 11:47
If the noise went away when the mechanic put grease on the belt then the belt will be the problem, to check if this is still the problem either spray plenty of CRC, WD40 or whatever (Belt Conditioner is best but people usually don't have that laying around) onto the belts with the engine running if the noise stops its obviously the belt so would be best to replace it. This is an easy first step to diagnosing the problem.
Chris
233745
Follow Up By: Member - Craig D (SA) - Monday, Apr 16, 2007 at 13:14
When I had a three litre I had a similar noise. To check the serpentine belt just pour a small amount of
water over the top with the engine running - if the noise goes it's the belt, if it remains then it's something else, maybe the tensioner? In the end I just had to use Belt Conditioner to shut it up (applied weekly!).
Good luck with the diagnosis.
494639
Follow Up By: nowimnumberone - Monday, Apr 16, 2007 at 18:21
the other problem is sometimes when a belt gets wet it will start to squeel.
and the only problem with spraying crc everywhere is it can get on to the noisy bearing and shut it up at the same time.
a pain in the butt job but remove the serpintine belt run the vehicle for a short time and see if the noise is gone.if its gone spin any idler bearing you can get to and feel for anything funny.they should spin free and no tight spots.
494715
Reply By: GQ_TUFF - Monday, Apr 16, 2007 at 16:16
Suprised to hear "goingplatnium" hasn't pop'ed his daft head into this post yet!! Don't worry the master of all things 3lt Nissan will be along soon I am sure!!
Have a good day
Cheers Stefan
233802
Reply By: Member - Stephen M (NSW) - Monday, Apr 16, 2007 at 20:07
If you have the room without cutting your hand I just use good old soap (bar of soap) and hold it against the belt as the engine is running and will shut it up if thats the problem. By doing it this way there is no chance of over spray onto your bearings etc making it easier to eliminate the problem. I have used so many of those belt sprays to stop the belts on the old hilux from sqeaking I just went back to the hand soap and worked a treat. Regards Steve M
233861
Reply By: TheMajor - Monday, Apr 16, 2007 at 20:17
Hi joeblogs
Just read your problem in regard to the 3ltr Nissan motor with noise coming from the belt drive area. I notice that you have already had your belt drive tensioner checked and remedied, however, there is another problem that occured with the belt drive on the 3ltr motor, which was recognised by Nissan and a bulletin from Nissan was sent to all Nissan dealers to cover this problem under warranty. Also the belt drive tensioner was also a problem Nissan identified and covered under warranty.
1. The fan belt tensioner had a problem which you have apparently had seen to and
2. also, there is a problem with the alignment with the belt pulleys. As I said earlier this was recognised by Nissan as a problem and covered under warranty. So any Nissan dealer would be aware of these problems with the ZD motor.
You have to be very careful as not all of them are honest and will try and suck the last $ out of you.
If you give the Nissan Technical Service section a ring in
Melbourne on phone 03-97974111 they will be aware of this problem and be able to advise you accordingly. You haven't mentioned whether your vehicle is still under the warranty period or not, however, if not and because it has been an established recognised problem you may be lucky. Who know, but what do you have to lose. I have found that there was a lot of problems with the ZD30 motor but the Nissan Technical Branch were reasonably honest but some dealers were still out for a quick buck.
Good luck and hope you fix the problem.
The Major
233864
Reply By: ross - Monday, Apr 16, 2007 at 21:15
I would find another mechanic or tell him to go ahead with the crankshaft replacement on a no fix ,no pay basis LOL. See what he says then.
Normally when there is a noise in the belt areas you remove them one at a time until the noise disappears.
When all the belts are removed ,turn the alternator and
water pump by hand by hand and feel for roughness.
233883
Follow Up By: joeblogs - Tuesday, Apr 17, 2007 at 06:56
Thanks for all the information I have spoken to my mechanic and he will remove the belt and start motor check all pulleys by hand. I hope the belt is the problem other wise I am looking at some big dollars as it is out of warranty
494837
Follow Up By: 120scruiser (NSW) - Tuesday, Apr 17, 2007 at 21:28
The alternator pulley has a one way clutch set up which can make a noise as
well. Dear as usual for a 3 litre. You also need a special tool to remove the pulley. Only available from Bitsrmissin.
494977
Follow Up By: joeblogs - Wednesday, Apr 18, 2007 at 17:54
Thanks for replies got the truck back from mechanic today. He took belt off and cleaned all the pulleys apparently they were very dirty covered in thick dust and fitted a new belt . No noise could be heard but will monitor over next few weeks. Still cost me for a new belt and 3 hrs to remove all covers and clean all pulleys.
495174
