boat info on Cape needed??
Submitted: Monday, Apr 16, 2007 at 18:27
crocket
Hi to all readers. Heading for the Cape in 46 sleeps time. On the ct boat rack ,whAT is the best material to sit the boat on?[its a 3.8 tinnie] EG. Would cut up motor bike tyre do the trick? Would a marine radio be usefull up there? Thanks DAVE.
Reply By: Member - Willie , Epping .Syd. - Monday, Apr 16, 2007 at 18:39
G'day Crocket ,
I dont think it needs anything but a couple of strips of wood or that white nylon they sell at boat shops as runners for trailers . As long as it is strapped on super tight .
I use nothing on
mine - it is held onto the rack on the CT with clamps - not ropes or straps .
Willie
233841
Follow Up By: Member - Duncs - Tuesday, Apr 17, 2007 at 17:09
The white nylon stuff can be bought at the $2 shops etc. It comes in the form of chopping boards.
My Dad uses it as bearings for the rudders on his boat. It's cheap, easy to carry, lasts for years. You can even let SWMBO think it is a chopping board until you need to replace the stuff on the boat.
Duncs
494907
Reply By: Wheelerdog - Monday, Apr 16, 2007 at 19:19
I would suggest sitting boat on carpet.
I would suggest running a VHF radio, depending on how far you are going, not may people use 27 mhz up this way.
the trade winds are howling at the moment so i guess you want be going to far out do you have an epirb.
233848
Follow Up By: Crackles - Monday, Apr 16, 2007 at 22:45
2 Votes for carpet. Certainly helps with something soft as the vibration combined with the dust can abrade an alloy hull. We used additional webbing straps as
well to minimise any movement between the boat & trailer.
Cheers Craig........
494812
Reply By: On Patrol (Aust.) - Monday, Apr 16, 2007 at 20:57
I used the white nylon such as Willie ref. to on
mine years ago, it did the job
well. As for radio, you might ask yourself, who are you going to talk to?
I have only 33 sleeps to go for my Cape trip. Might see you on the track Dave. Enjoy yours mate.
Colin.
233878
Follow Up By: Mayesy - Monday, Apr 16, 2007 at 23:12
the tyre rubber will work but thick carpet pads are excellent.
Geoff
494821
Reply By: Grungle - Tuesday, Apr 17, 2007 at 07:42
Conveyor belt rubber is good. Nice and thick so can be screwed down. Also you can get strips of Nylon (I think that is the material) from boat shops that you use to line rails to aid in the launching/recovery of boats. Comes in various lengths and at reasonable prices. I am going the route of the
conveyor belt.
I have been looking for a while to the the same but have not had the time to do it. We have 53 days until our Cape trip (only decided last week) so have to pull my finger out and do these last few jobs.
David
233928
Reply By: Bros 1 - Tuesday, Apr 17, 2007 at 16:22
crocket,
I use the blue teflon stuff that they use on boat runners. Cut it the right length, drill two counter sunk holes away from where the gunwales will sit, secure with 2 stainless self tappers and away you go. (3.7m savage tinny.)
Bros.
233990
Reply By: Wheelerdog - Tuesday, Apr 17, 2007 at 18:57
VHF radio travels along way, channel sixteen is monitored by all boats and ships and can be heard all through the torres strait and gulf, that time of the year there will be many tourists boating around the cape, if you are stuck somewhere there is a good chance someone will hear you.
234032
Reply By: crocket - Saturday, Apr 21, 2007 at 21:08
Thanks for all the ideas. cheers crocket.
234985
