Coromal independent suspension
Submitted: Wednesday, Apr 18, 2007 at 11:26
ThreadID: 44447 Views:22453 Replies:8 FollowUps:7
I am considering buying a two year old van (coromal) and have been told that independent suspension tends to scrub out tyres on some models of van. Could owners of vans with same please reveal their experiences, both good and bad. Thanking you in advance. Les
Reply By: pepper2 - Wednesday, Apr 18, 2007 at 12:02
anything is possible but my 420 magnum off road tracks perfectly no tyre wear other than normal.however i did lose the spare wheel when the weld on the bracket failed after many ks of rough roads....anyone find brand new desert dueller on sunraiser rim bolted to half a metal bracket......
AnswerID: 234195
Follow Up By: Stu-k - Wednesday, Apr 18, 2007 at 12:41
Yup I found it and its wheelie good!
FollowupID: 495083
Follow Up By: hoppy_a - Wednesday, Apr 18, 2007 at 18:53
Thank you for your views. I now have enough info to consider.Hoppy
FollowupID: 495203
Reply By: Member - Fred L (NSW) - Wednesday, Apr 18, 2007 at 12:30
G'day Hoppy,
Had mine now for about 2 years after buying 2nd hand - I was told that the original owner did E to W Aus and up the West coast. I have not had or seen any problems with my tyres but will keep an eye on them. I saw a lot of Jaycos around during Easter without independant suspension and wondered how restrictive their movements in the bush would be!
AnswerID: 234202
Follow Up By: hoppy_a - Wednesday, Apr 18, 2007 at 18:55
Thanks Fred, I now have enough info to consider,Hoppy
FollowupID: 495204
Reply By: Neil & Pauline - Wednesday, Apr 18, 2007 at 14:01
Les
I had a Coromal Priston 701 and never found any tyre scuffing. It flexed the frame rather than scuff the tyres. A friend of ours had one the the support arms welded in the wrong place causing bad scuffing. Coromal put it down to wear and tear but dealer fixed. It is hard to see how wear and tear shifts a welding point.
There are other issues with some of the newer Coromals.
Have a good look to see that there is no movement in cupboard joins, no evidence of water leaks or repairs around windows and edges, the angle iron floor supports are not twisted (This is indicated with the floor joins being obvious on the inside) and no cracking of galvanising at the and of the main tow A frame.
Some of the early Prinstons had a light chasis which failed.
There are a lot of Coromals that are holding up so just be aware.
Neil
AnswerID: 234222
Follow Up By: hoppy_a - Wednesday, Apr 18, 2007 at 19:14
Neil & Pauline, Thank you for your input. Hoppy
FollowupID: 495215
Reply By: dj Patrol - Wednesday, Apr 18, 2007 at 16:52
Gday Hoppy,
I brought my Coromal Capri New in 2004 was a 03 model and it scrubbed out tyres all 4 only 6,000 and a authorized caravan repairer adjusted it by cutting the welded stay and moving it which made it worse than ever.So I finally found a Truck Lazer Wheel Aligner who had the van for a week and had to move all the Chassie Brackets and re-weld-
Lots of work and only charged me $650.
It now runs ok and does not scrubb tyres at all.So I contacted Coromal and they told me basically to go jump and that they had paid for the Warranty Job once and to go see the caravan repairer (yer-rite) they also said that I most likely had hit a Pothole so ya better not hit any Pot-holes in a Coromal Caravan.
So finally I am able to use my $50,000-00 caravan after two years and I also have fitted a new set of 195-14 tyres which are a much better tyre than the 185-14 they fit.
AnswerID: 234244
Follow Up By: hoppy_a - Wednesday, Apr 18, 2007 at 19:00
Very interesting information. Thank you for your input as i can now reconsider my options, Hoppy
FollowupID: 495205
Reply By: Dalb - Wednesday, Apr 18, 2007 at 17:19
Last year I bought a 3 yr old Coromal Seka 535 pop-top that had done about 20,000 km, including a Kimberley trip. I recently did over 10,000km with it towing at up to 110KPH on bitumen, and the four original 16inch desert dueller A/T tyres still look like new.
I believe the Coromal independent wheel system is now antiquated compared to the modern springy systems, but I have nothing but praise for its ride and stability on and off the road. Maybe the newer systems are more responsive and bounce more, thus there may be more tyre wear?
Cheers.
AnswerID: 234253
Follow Up By: hoppy_a - Wednesday, Apr 18, 2007 at 19:12
G'day Dalb, & to you & to all who replied, thank you for your input. I now have a better understanding of potential problems and forewarned is forearmed. Hoppy
FollowupID: 495212
Reply By: Keith_A (Qld) - Wednesday, Apr 18, 2007 at 19:14
Hi Les - we owned a Coromal Magnum for several years, and now a Coromal Corvair (poptop).
Both units have the same suspension, and never had a problem........Keith
AnswerID: 234287
Reply By: tolinja - Friday, May 04, 2007 at 20:16
I have a coromal excel 520 on road has anyone changed the wheels over to 15" or 16" wheels to increase ride height?
is it possible to under sling the axle?
let me know what you think as i need ideas
AnswerID: 237941
Follow Up By: StephenF10 - Friday, May 04, 2007 at 21:50
Coromals don't have axles (apart from the stub axles on each wheel). Each wheel is connected by a wishbone to the inner chassis rails and has a leaf spring bearing on the outer chassis rails. I suppose you could try replacing the springs with taller ones but then you would get negative camber.
Stephen.
FollowupID: 499085
Reply By: StephenF10 - Friday, May 04, 2007 at 21:59
I have a 2003 Coromal Seka 535 with 8000kms on the original tyres, which are barely worn. Although the suspension is independent the wheels show very little camber so I wouldn't expect them to wear any more than on any other van.
We've had no other problems except a water leak (from below) that was fixed under warranty.
Stephen.
AnswerID: 237978
