OZI Explorer downloading Treks
Submitted: Thursday, Apr 19, 2007 at 07:33
ThreadID: 44483 Views:2867 Replies:3 FollowUps:6
Good Morning All
I have a question for all your learned guys on OZI Explorer installed on Laptop,
Have a GPS Mouse connected to up market Lap top by USB with Natmaps Premium 2005 DVD 1-2 as well as Hema Maps. All works great with moving Maps running.
Question 1.Can I get mileage travelled on Moving Map screen ,I get speed ,Elevation & others.
Question 2 . I have problems loading Treks to OZI Explorer,I have download many files from OZI , I have got some to work ,& lost others as I still don't how I got some to work as it was by try & error, Please Help
Reply By: Member - David (WA) - Thursday, Apr 19, 2007 at 12:34
Hi CLC50,
I know a bit about moving maps so I hope I can assist.
Q1
Ans: When moving map is activated the system creates a plot file called 'mmtrack.plt' in the oziexplorer main folder. This plot file has recorded, amongst other things, the distance travelled between readings. Its a bit time consuming to add up the various distances but it can be done.
There maybe someone on this forum that can provide details of a better way of doing this, as I too would welcome it.
Q2
Ans: Not sure what your problem is but any .plt file can be loaded once a map is active. The .plt _Affordable_Storage_Drawers.aspx a line on the screen showing the course that was travelled. Using track control you can view details of the track as described in 1 above. To do this click on the track that is displayed in the window. The screen track then shows all the points of the track. To show the details of the track click on the show track list button.
I hope that is off assistance.
Cheers from WA
David
AnswerID: 234455
Follow Up By: CLC50 - Friday, Apr 20, 2007 at 07:16
Thanks David
I will see if I can get it right now, other wise a few more grey hairs
FollowupID: 495588
Follow Up By: Bonz (Vic) - Saturday, Apr 21, 2007 at 17:14
dump the file into excel and use that to do the calcs
FollowupID: 495942
Reply By: SA_Patrol - Thursday, Apr 19, 2007 at 15:00
Hi CLC50,
Q 1 : Open VIEW then TRACKS and then TRACK CONTROL, this should give you the total tarck Distance, or TRACK PROFILE to view the Distance/Time and Elevation
Q 2 : Could be a number of things, need more detail on how you are opening the files.
AnswerID: 234493
Follow Up By: CLC50 - Friday, Apr 20, 2007 at 07:14
Thanks SA-Patrol
Well in reference tt your answer Q 2.I download to desk top the drag into the Ozi explore Program ,then I loss my way,sometimes I get it to work other times I loss it in space some where.
FollowupID: 495587
Follow Up By: SA_Patrol - Friday, Apr 20, 2007 at 23:15
Save all your tracks in the Data folder in Ozi, open the files from LOAD then Load track from File. Sometimes I have trouble, it also may be tracks from a different version of Ozi
FollowupID: 495832
Follow Up By: CLC50 - Saturday, Apr 21, 2007 at 06:15
Thanks SA-Patrol
That has now give me the answer .
CLC50
FollowupID: 495851
Reply By: The Explorer - Saturday, Apr 21, 2007 at 12:42
Hello - There is an add on for OziExplorer that has the feature (distance travelled/trip metre) you are chasing. The program is called is called Travellmate and can be found here...
travelmate.valkron.com/
The program allows the setup and use of 4 Re settable Odometers that feed off the information from OziExplorer/GPS. The program also has many other features.
I have never used it (I use PDA and there is no CE version of travelmate) so I can not provide any advice on use etc.
AnswerID: 234924
Follow Up By: CLC50 - Saturday, Apr 21, 2007 at 20:02
Thanks Explorer
I shall download these files
Thank you
FollowupID: 495965
