Steel jerry cans
Submitted: Thursday, Apr 19, 2007 at 10:05
13gef13
I've been given 2 steel jerry cans, in real good condition on the outside. One even has super petrol still so the seals are good. Unfortunately when I flushed them with petrol some gunk came out. Not much but it worries me. Is there some way of cleeaning them out effectively? I want to use them for diesel and when I transfer from jerry can to vehicle I always use a funnel with a fine filter mesh.
Thanks, Geoff
Reply By: Robin - Thursday, Apr 19, 2007 at 10:21
Hi Geoff
I wouldn't bother as 1% petrol in diesel isn't an issue - and you are using filter for particles anyway
Robin Miller
234428
Reply By: Tony - Thursday, Apr 19, 2007 at 10:27
Re-flush them with a bit of petrol until you get no more gunk out. Anything left will get picked up in the funnel.
234430
Follow Up By: Vince NSW - Thursday, Apr 19, 2007 at 10:51
I have used a handfull of small stones & some petrol. Give a good shake, but watch out when you open the can as you will build up a small amount of pressure.
Vince
495375
Reply By: Member - Duncs - Thursday, Apr 19, 2007 at 12:23
I always use a piece of material from the wifes old panty hose, as a final filter.
I use a syphon and simply hold a few layers of the material over the end of the hose with a rubber band or some gaffa tape. I have also used the same system over the end of a funel. With or without the mesh filter in the funnel I usually get something in the pantyhose.
Remember to replace the rubber band/gaffa tape every time you transfer fuel because I don't reckon either will stand up to the fuel very
well. Even if they would I won't take the risk.
Also if you leave a little bit of fuel in the bottom of the jerries and keep them properly closed all the time you will get less problems with corrosion on the inside.
Duncs
234451
Reply By: phil - Thursday, Apr 19, 2007 at 19:46
How old are the jerry cans?
I am still using 3 of them which are marked W^D 1952 I guess this makes them 55 years old. Nearly as old as I am!
There are bits of red paint flakes occasionally, but nothing which is a problem if a simple filter funnel is used.
I just filled them all as I got a 20 cent/l fuel discount from a wine offer.
Phil I
234570
Reply By: obee - Thursday, Apr 19, 2007 at 21:29
the mesh is there to stop
water more than anything else. A bit of grit will stop in the car's filter but
water will block it total
234603
