OT-sort of. Using wheels to tumble glass
Submitted: Friday, Apr 20, 2007 at 08:47
Willem
An Art Project is in the pipeline and the need has arisen to break glass bottles and alike into small pieces and to take the sharp edges off the glass.
Buying a Gemstone Tumbler is an option but by doing some lateral thinking(lol) I came up with an alternative idea. There is also a need to fit a heavy duty rubber sleeve in a tumbler
So I thought...."Hey, I have those dud Cooper STT's and Eldorados sitting in my shed....why not pop the glass bits and stuff that goes with it, into a tubeless tyre and then go for a drive....slowly, for say, 20km up a back road?"
It may work?
Any ideas pertaining to smoothing off glass bits?
Reply By: Member - bushfix - Friday, Apr 20, 2007 at 09:17
G'day Willem,
put them in a cement mixer with some blue metal or gravel?
234691
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:08
Now why didn't I think of that?.......lol
495658
Reply By: Russel & Mary - Friday, Apr 20, 2007 at 09:20
It should work. Our local steel engineer has a tractor tyre set up to put multiple steel cuts off the metal shear guillotine into and sets it going for a day. This takes the sharp edges off. Rus.
234693
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:14
OK thanks for that info. Learning new stuff every day...:-)
495663
Reply By: Member - Wim (Qld) - Friday, Apr 20, 2007 at 10:26
Morning Willem.
The problem I see is in keeping the surface of the glass in good condition. No scratches.
If this is not an issue, maybe sand along with the glass may work.
Wim
234707
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:10
Thanks Wim
The glass is going to be on smaller bit so surface scratches do not really matter.
At the moment it is just a concept. I am trying out various ideas.
495659
Reply By: Member - Michael J (SA) - Friday, Apr 20, 2007 at 10:34
Mornin'
That'll be different, puncture from the inside........lol lol
Does the glass need to retain its 'shine' Willem?
If not fill the cement mixer with your bits of glass, add some
water and a few turns should take off sharp edges.
I usually throw a few half bricks in the mixer when finished mixing concrete, keeps the mixer clean and it sure takes the edges of the bricks......
Michael
234709
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:11
Hmmmm I had thought of you and a cemnet mixer. Mebbe we could employ you when you finally 'retire'....lol
495660
Reply By: V8Diesel - Friday, Apr 20, 2007 at 12:04
Maybe try a cartridge case tumbler and experiment with the abrasive media you use. Most shooters who reload will have one. Walnut husks and rice with a drop of Brasso works a treat on grubby brass for example. Start easy and work up. Some tumble and some vibrate so try both.
Good luck.
234726
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:12
Thanks V8. Now all I have to do is find a shooter...:-)
495662
Follow Up By: V8Diesel - Friday, Apr 20, 2007 at 17:59
Hmmmmmm.........wonder where you'd find one of them?
Maybe the local moggies would know;-)
495724
Reply By: Member - MUZBRY (VIC) - Friday, Apr 20, 2007 at 12:06
Gday
In my job, I put our product into Linda. Linda is an old cloths dryer ..named after a girl that my wife worked with..You will have to read between the lines to work out the name.
234727
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:15
Linda hand????
lol
495664
Follow Up By: Member - MUZBRY (VIC) - Friday, Apr 20, 2007 at 14:28
No Willem
She would be a good rumble.........We rumble the product to smooth the outer edges
495667
Reply By: Des Lexic - Friday, Apr 20, 2007 at 12:24
G'day
young Buck,
I don't think the glass in the tyre even at 20k's an hour will work all that effectively as the centrifical speed will hold the glass out and stop it from tumbling. I think the concrete mixer is the better solution. If you have lot's to do, speak to your local concrete truck driver.
happy tumbling.
234733
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:17
Thanks Uncle Des
No concrete truck drivers here. They all come from elsewhere. But I get the drift...lol
495665
Reply By: Member - MUZBRY (VIC) - Friday, Apr 20, 2007 at 12:46
Gday Willem
I have some RAW rubber here if you need it . Raw rubber might be better known as LINATEX..It is used in rock screens and pipes for pumping sand. Give me a size and I can send it or bring it over in July.
234737
Follow Up By: Willem - Friday, Apr 20, 2007 at 14:18
Thanks Muzbry, I will keep that in mind.
495666
Reply By: Dave198 - Friday, Apr 20, 2007 at 19:51
G'day Willem, there is a business in
Mildura called Woodsies Rock
Shop. They have made their own machines for tumbling rocks etc.
They have old diffs with
wheels attached and If I remember right, it is turned by a washing machine motor. Just can't remeber if it was just a half wheel split down the middle and the tyre was virtually open on the outside allowing access.
Just vary the size of the pulley to get the speed nice and slow.
I also think if you went for a drive, the centrifugal force would be a problem.
And you would probably finish up in the Flinders anyway. Can't imagine you just travelling 20 Kms.
234816
Reply By: Nick R - Friday, Apr 20, 2007 at 22:23
is it for a glass mosaic?
cool
Nick
234857
