hf radio recommendations
Submitted: Friday, Apr 20, 2007 at 23:24
ThreadID: 44553 Views:3085 Replies:11 FollowUps:8
we're looking for a second hand hf radio. what models do people recommend we look for? do some of the older models still perform well or are there likely to be problems that occur? cheers all.
Reply By: SteveL - Friday, Apr 20, 2007 at 23:37
I would not go for anything older than a Codan 8528 as they have most of the features you need and are readily available second hand.You can run them with a multi tap or autotune (9350, the older 8558 is too unreliable).The reason I would get a codan is there are a lot more of them on the market as the have been used by many Govt. departments,Telstra etc. Older models have spare parts availability problems,often don't have selcall (essential for emergencies) and are more difficult to program. -Steve
AnswerID: 234871
Reply By: Hairy - Saturday, Apr 21, 2007 at 01:28
Gday
Do you want a radio for emergencys or something to listen too? If its for emergencies, have a look at sat phones.
AnswerID: 234878
Follow Up By: Hairy - Saturday, Apr 21, 2007 at 01:30
Yes I know....emergencies
FollowupID: 495846
Reply By: Member - Bentaxle - Saturday, Apr 21, 2007 at 09:20
Check EBay do a search for HF radios and look for a seller named 'Unkerdunk', he resells 2/hand radios that have been refurbished and have RFDS, VKS, Selcall, and Radtel frequencies.
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 234893
Reply By: Member -Signman - Saturday, Apr 21, 2007 at 10:18
I have a Codan 8525- with all the good channels- for sale...
AnswerID: 234902
Follow Up By: molzy - Monday, Apr 23, 2007 at 07:13
how much are you looking at for it and does it come with an aerial. cheers
FollowupID: 496267
Follow Up By: Member -Signman - Monday, Apr 23, 2007 at 08:56
Hi molzy
email me at
op(dot)support(at)tsn(dot)cc
FollowupID: 496283
Reply By: Member - dock - Saturday, Apr 21, 2007 at 10:39
Molzy, I have just bought a Barrett 250 (With selcall) from "unkerdunk" and am installing it this weekend. Cost just over $1000, which is aerial, base, etc, no more to pay except for licence and some wireing and have nothing but praise for David Collins. Came within a couple of days of transfering the money all nicely packaged.
Hope this is of some help.
AnswerID: 234904
Reply By: Footloose - Saturday, Apr 21, 2007 at 12:32
home.iprimus.com.au/jimshire/4WD.htm
AnswerID: 234922
Follow Up By: Mobi Condo - Saturday, Apr 21, 2007 at 12:36
Try Wayne Reid of Reids Radio Data in Cowra NSW.
Cheers - Mobi
FollowupID: 495900
Reply By: Member - Shane D (QLD) - Saturday, Apr 21, 2007 at 17:49
I also have bought a second hand barrett 250 from Dave and would happily recommend others who are looking for a HF
My unit came with VKS channels installed as well as selcall, plus multitap aerial spring base for around $1000,once I fitted it, I took it back,to insure that I had fitted it correctly,and to insure it was working WELL,not just working.It wasn't quite up to scratch and after some tests we found that the wire that runs outside the aerial was a bit dicky so he got another one,fitted it ,all good
Irony is this was ebay item,and I came away thinking I would not of got better service had I bought a new one from a dealer.
I'm Happy with the performance with the 250 lots of interference in the city(Brisbane)once the sun goes down it really come to life and regularly can get the 3 ABC radio trans from Alice,Katherine,Tennant Creek, NT.
I did a bit of research before I bought mine and yes the 250 is considered entry level,but it does almost the same stuff as the flashie units do.
I bought mine in preparation for up coming Simpson crossing and after that it may not get much use for another 12 months, so spending $3K not really an option.
Lots of argument's +/- for sat phones IMHO HF the go for me .hope this info from personal experience may be of help
Shane
AnswerID: 234958
Follow Up By: Member - Davoe (Nullagine) - Monday, Apr 23, 2007 at 22:48
Hmmm someones making good cash. Mine came in at under $600
FollowupID: 496558
Reply By: Mike Harding - Saturday, Apr 21, 2007 at 18:05
Of course if you did an Amateur Radio Foundation Licence
http://www.wia.org.au/foundation/foundation%20licence%20information-v1.pdf
you could buy one of these - Yaesu FT857D
Site Link
and chat to other Amateurs - indeed I hear some naughty Amateur operators
use them on VKS7373 - but I'm sure no one on this austere forum would be so irreverent...?
Mike Harding
AnswerID: 234961
Reply By: Member - Matt M (ACT) - Sunday, Apr 22, 2007 at 20:49
Molzy,
If you end up going for a Barrett with the 910 auto tune aerial, I would suggest going for a later model aerial. The earlier (light grey) one did not have sufficient bracing around the join and is prone to cracking and failure. An expensive ($400-500) fix.
The later (dark grey) model has longer supports and is not subject to the same type of failure.
Other than that, the Barrett 550 is a good radio.
Matt.
AnswerID: 235183
Follow Up By: molzy - Monday, Apr 23, 2007 at 07:12
do you know how much an autotune aerial is. cheers
FollowupID: 496266
Follow Up By: Member - Matt M (ACT) - Monday, Apr 23, 2007 at 07:51
Molzy,
For the Barrett aerial, I think about $1400-1500 new. Second hand, I am not sure but probably about $500 if you can find one. Not sure for the Codan either.
My radio came with the auto tune, but honestly, if you are only using it for the odd call to VKS 737, it is probably worth just getting a tapped whip.
Matt.
FollowupID: 496274
Reply By: andoland - Monday, Apr 23, 2007 at 09:10
Have you thought about hiring one for your trip?
A few places in Brissy hire them. Try http://www.atrekcamping.com.au/hire/hirepricelist.pdf who have them for $70/wk (I assume would be cheaper for many weeks hire that you need).
I think 4wd Hire may also hire them and the RFDS does as well.
Chris
AnswerID: 235230
Follow Up By: molzy - Monday, Apr 23, 2007 at 12:48
cheers I'll check them out.
FollowupID: 496357
Reply By: Member- Rox (WA) - Monday, Apr 23, 2007 at 21:35
Get 1 with Sellcall facilities. Mine is a barret 950 & 550 Auto tune.
AnswerID: 235430
