Firestone airbags
Submitted: Saturday, Apr 21, 2007 at 13:18
The Rambler( W.A.)
Just had a pair of Firestone airbags(bellows) fitted to my Troopy.Been told never toexceed 100p.s.i. when loaded.Is this correct and what average pressures are used on say a 3.2t load? Also unladen what pressure would you reccomend for normal bitumen driving? Any danger on running them empty? The installer gave me a brief rundown but would like to hear from those with experience using these units.
Reply By: Member - John (Vic) - Saturday, Apr 21, 2007 at 13:33
I run
mine with about 50 to 60 PSI as a max with a full outback load, never felt the need to get anywhere near 100 psi.
Don't run them empty I let them down to about 20 psi with minimal load as you have no bump stops and the bags and mounts may take a hammering if you bottom out for some reason..
Also watch the U bolts, I have had one loosen and the bottom mount shift.
I tend to think the U bolts and base mount are a bit light and I will make a new base out of heavy channel and fit it with 3/8 or 1/2 inch U bolts.
Other than that they work real
well and make a real difference with the saggy bum syndrome Troopies suffer.
234930
Follow Up By: Harry - Saturday, Apr 21, 2007 at 21:31
Is there enough room for the bigger diameter U bolts ?
495992
Follow Up By: Member - John (Vic) - Saturday, Apr 21, 2007 at 22:30
Hi Col
Yeah i think they should fit, maybe have to shift the brake line a bit but should be right.
Those front rated recovery points from John Whimpy are a good bit of kit.
They bolt into existing holes nice and neat, he's done a good job with them.
496008
Follow Up By: Harry - Tuesday, Apr 24, 2007 at 20:47
BJ,
had trouble sending this through, so if you already have it then disregard.
Make sure you get those brakelines out of the way coz that's what rubbed the crap out of
mine and had to replace 1 bag although I thought the brake line was not near enough to touch something must have moved or whatever.
Don't know whether those recovery points of John W will fit the new truck as they have made it 90mm wider. See what he says.
496767
Reply By: macka2 - Saturday, Apr 21, 2007 at 15:07
Can I suggest you contact STA on the net as he is real expert on the subject?
234938
Reply By: TroopyTracker - Saturday, Apr 21, 2007 at 17:14
Rambler,
Fella who fitted
mine gave a similar speel. I rang the manufacturer to make sure he didn't miss anything. They said, no less than 5psi, no more than 100psi and I recall someone telling me you should let them down before putting the car on a hoist mounted under chassis?? Can't see why it should be and issue though?
My Troopy is very similar weight and I find around 45psi is good. Having said that I would have different spring packs of different age which have had leaves added and been reset earlier in their life also......so no point going off someone else. Start at 40psi and run around for bit like that and adjust to suit once the leaves have settled again. I'd love the in cab adjuster kit but can't justify the $400 odd it costs. You only need to make tiny adjustments with the compresser/finger as the volume of air is so small it drops and rises so quickly.
Great product and I'll be ripping
mine off and putting them on the next one hopefully.
Matt
234947
Follow Up By: The Fox - Monday, Apr 23, 2007 at 09:06
I already had a compressor and
tank fitted to the truck. They still wanted $525 for the cab kit without the comp and
tank! I found a hot rod air-ride
shop on the web and bought the two, two way pnematic switches and a dual needle pressure gauge for $155.00. Fitted to a panel, they cost $240. Huh?
Haven't done the job yet, but just need a panel to mount then and a few metres of hose and a some fittings and should be ok.
496286
Reply By: Member - Phillip S (WA) - Saturday, Apr 21, 2007 at 17:40
Rambler, I have
mine for a while now and with my troopy parked on flat ground I stand back and look how she sits and adjust as necessary, they need very little air to adjust, very sesitive to pressure.
I also use a measuring tape to measure from the top of the tyre to the top of the wheel arch inside (top of tyre straight up to body) to try to get them the same or you can just stand at the back and look to see if she is level.
The pressure each one is to have will be determind how you pack her...maybe a bit one side more than the other to make sit normal (side and back view).
Keep an eye on the mountings for tightness etc.
But they have been terrific, had no trouble, easy maintenance and used in all sorts of situations and even when towing a 21 ft full van of about 2.8 tons with electric brakes.....great. cheers Phil
234955
Follow Up By: Richard Kovac - Tuesday, Apr 24, 2007 at 22:25
Im with you Plil,
I adjust
mine to suit the eye left-right, frront-rear, they work
well and no problems
Richard
The measuring tape, thing I use for tyre air pressure as
well as for the air bags..
496802
Reply By: The Rambler( W.A.) - Saturday, Apr 21, 2007 at 20:49
Thanks for the advice guys, but also wondering if the bag on the left rear is too close to the exhaust.It is fitted with a shield between the exhaust and the bag but it seems very close to me. It looks as though it is the only place to go and the shield must be part of the kit for the Troopy but it would be piece of mind to hear from others.
234979
Follow Up By: Member - John (Vic) - Saturday, Apr 21, 2007 at 22:34
Yeah the shield is part of the kit.
As Harry says below no real issue with heat although if you let the bag down completely it may balloon out enough to touch the exhaust.
They are good jiggers and you will have no problem working out the best pressure etc to suit your vehicle and conditions.
If you have an email address I am happy to send you a few picture of
mine installed if it helps.
Send me a MM with your email details if you like.
496009
Reply By: Harry - Saturday, Apr 21, 2007 at 21:27
Hey John, you didn't say what happens to the bag if the "U" bolts come loose. :>)
The exhaust heat is not a concern, the bag doesn't suffer.
I find the best way to inflate is to pump up with a HANDPUMP and knowing the measurement from the centre of the hub to the mudguard edge will get you to the right level. Measure the truck when it is empty or measure one at a yard.
John carries about 400kg more than
mine hence more pressure,
mine sits
well at 32/35psi. My truck usually weighs in at 3200kg
Also carry your old bumpstops with you in case a bag gets damaged.
Put some threadlock on the "U" bolt nuts.
234992
Follow Up By: Richard Kovac - Tuesday, Apr 24, 2007 at 22:35
Harry
I just put lock nuts (second nut) on all my U-bolts left them long and put garden hose around the extra thread to protect them.. You can always do some thing if saomething goes wrong and you have the extra thread.. Methinks anyway.
I haven't have anything go wrong so far (but now I will be getting on the back and having a look tommrow) .. LOL
Richard
496804
Reply By: Twintrail(W.A.) - Sunday, Apr 22, 2007 at 00:29
hi rambler .still waitng to hear who took that photo.maybe you could take photo of new 70 series this time. reards twintrail
235035
Reply By: Member - Leigh (Vic) - Monday, Apr 23, 2007 at 08:57
Hi Rambler
As the others have intimated these bags are bullet proof. Yes, you should stick within the parameters of 5 to 100psi athough you'll probably find 20-50 psi satisfactory for most occasions. IMHO I think it is best to inflate to a height measured from the bottom of the rim to the top of the wheel arch and in this way maintain normal ride height. If you need more clearance then put more air in. I think the brackets are underdone and like
John may beef up the bracketry and fit some high tensile bolts, if I can be bothered that is!
John has done some serious rough sh#t with these bags so his comments on this is at the extreme end.
There are a few sites that have heaps of data on these kits (US) and I bought
mine from the US and modified accordingly.....not much required and a lot cheaper at the time. Pump em up and enjoy the ride!!
235226
