inverters
Submitted: Sunday, Apr 22, 2007 at 16:32
gertie
Want to buy an inverter for the caravan that will enable us to charge the phone,watch tv or maybe run the laptop. Any sujestions as to brands,etc & where to buy. Your help will be vry much appreciated.
Reply By: lifeisgood - Sunday, Apr 22, 2007 at 17:28
Pop into a Jaycar store if nearby and discuss your needs and budget.
The better ones for your laptop are the sinewave versions which are a little more expensive. For your needs (as stated) I would suggest 300Watt would suffice.
Jaycar Cat No. MI-5153 $199. If thats beyond your budget the 300W non-sine wave unit p/n MI-5104 at $80 is a starting point.
235130
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Apr 22, 2007 at 18:10
Hi Gertie
I fit the Projecta 600W unit to most vans.
It will run a drill as
well as all other charging situations.
I have just finished testing a new unit. Marine grade and will run a fridge. They are in my next container due in 3 weeks time. I will load some pictures in an hour or so.
If you need one straight away then the IN600 from Projecta is perfect. It has twin outlets and I trust the product.
Derek.
235140
Follow Up By: Member - Andrew (QLD) - Monday, Apr 23, 2007 at 09:00
Whilst i recognise that you generally have a good name around here with your business, i am intrigued at how you can "self-promote of products" which is against the
forum guidelines.....is there something that other advertisers/businesses who do not promote their product on the
forum as it breaching these rules, miss in interpreting the rules? (i'm thinking of a recent thread, not old threads)
How is this post (and the other one below) not self-promoting your products?
496284
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Apr 23, 2007 at 10:00
Thanks Andrew,
Advice taken however I post pictures and links to more than just my own site.
I try to advise where I can and threads are not is aimed at self promotion.
Derek.
496308
Follow Up By: Member - Andrew (QLD) - Monday, Apr 23, 2007 at 14:18
Thanks for your calm reply to my post ;-) i wasn't actually advising, rather that i am concerned that some of these posts could be considered no different in their advertising slant than my old mate Bill....god rest his soul (apart from the abrupt nature i remember).
496378
Reply By: Member - stefan P (NSW) - Sunday, Apr 22, 2007 at 18:20
I have a 1500watt I got from Ebay, it is over kill for my power needs but its nice to know I have the power if I need it. I paid $178 posted to my door. Runs my 240v waeco fridge with out a drama. With regards to laptops I have been told the transformer for the laptop converts the modified back to a pure sine wave. So you don't need the expense of a pure. My father has been running his laptop of his inverter without a drama.
Cheers Stefan
235143
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Apr 22, 2007 at 18:24
Most but not all modified sine wave
inverters will recharge a laptop but if the laptop power supply gets very hot then there is a problem and don't use the inverter on it.
235146
Reply By: Member - Doug T (W.A) - Sunday, Apr 22, 2007 at 19:39
One of the best and most imformative sites for
Inverters is right here on EO
Site Link
235167
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Apr 22, 2007 at 23:07
Hi Gertie
Sorry it took so long to put the picture up but here it is. It is a Marine Grade inverter.
img src="
http://www.sidewinder.com.au/_wp_generated/wpdfaf2837.jpg">
I had to first load the info onto my web page as it is a new product that we have had manufactured. There are 3 containers due in port any day now.
Derek.
235207
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Apr 22, 2007 at 23:08
Opps I will try again.
496243
Reply By: gertie - Monday, Apr 23, 2007 at 08:38
Thankyou so much for your replys--we are not in a panic so shall look in to all your advice--thanku ozteam for that site link--even i can understand
inverters a little better now.
235225
Reply By: Member - Alex K (NSW) - Monday, Apr 23, 2007 at 19:08
I bought and installed a PSW 600W JayCar Inverter in the LC80 and couldn't be happier. You'll need extra cable as they only supply 1m. Make sure you get thick cable (same as what it comes with), I think it was 4G.
235370
Reply By: Mainey (WA) - Tuesday, Apr 24, 2007 at 00:14
PURE Sinewave 300Watt should be ok (minimum) with the equipment you nominate
Get model with a fan - not heatsink
think closer to $300 - not under $100
Install close to battery in open area to dissipate heat & avoid voltage loss.
Check out the technical specifications.
50/60Hz: (+/-) 0.3%
Efficiency: 89% plus
Input voltage range: 10.5v - 15v
What protection is included: Overload, Short circuit, Reverse polarity, Over/Under voltage, Over temperature.
Meet or exceed the above specs.
mainey...
235462
