Tow Bar - Spare wheel carrier
Submitted: Monday, Apr 23, 2007 at 10:19
ThreadID: 44624 Views:11508 Replies:7 FollowUps:10
I have a navara dual cab and am looking at carrying an extra spare wheel, but no space really.
Is anyone aware of a spare wheel carrier which can fit inside the hayman reece towbar, it seem logical, as it could be used on any vehcile?
Reply By: Member - Sam (NSW) - Monday, Apr 23, 2007 at 10:41
Not sure if one exists, but it wouldn't be too hard to make one or have one made up. The only issue though is that it is a lot of weight pivoting on one small point, unless you have a way to anchor it to stop it moving around.
AnswerID: 235255
Follow Up By: vcbb - Monday, Apr 23, 2007 at 10:49
We thought of getting one made, might have to, but there is design work, as you said with the weight, but the square tubing going inside the tow bar can be heavy duty, we thought two swing arms, one side for the tyre, and the other for a jerry can., the weight would be closer to the centre.
FollowupID: 496324
Follow Up By: Member - Sam (NSW) - Monday, Apr 23, 2007 at 11:06
What kind of bumper do you have? On my old Hilux, i made up my own swing out wheel carrier for the 2nd spare. bolted a hinge plate to one side of the rear bar (twin tube steel) and a strike/catch plate on the other side of the bar, but when closed, a catch hooked over the tongue of the tow bar, transferring the weight of the tyre and arm down onto the tow bar. Hardly any movement as the tyre/wheel was put as low down as possible to where the upright and cross sections of tubing met and were reinforced.
FollowupID: 496328
Follow Up By: Member - Sam (NSW) - Monday, Apr 23, 2007 at 11:07
I think i still have photos of it. So if you want I could email them. Just drop me a message with your email addy and i'll flick them off (providing i can find them)
FollowupID: 496330
Follow Up By: vcbb - Monday, Apr 23, 2007 at 11:14
That would be appreciated, I hve the normal rear step bumper for the D22 Navara, Was hoping to not have to put any more holes in the old girl, and that it could be transferrable to other vehicles. Photos would be much appreciated
bryree@westnet.com.au
Brian
FollowupID: 496333
Follow Up By: Member - Alex K (NSW) - Monday, Apr 23, 2007 at 18:49
vcbb,
Could I trouble you for a copy of your photo's too. I have a LC80 and have been considering making a twin spare wheel carrier for a while (can't justify $3K for a commercial one).
alex.kempson @ au dot fujitsu dot com
Thank
Alex
FollowupID: 496445
Follow Up By: Member - Sam (NSW) - Monday, Apr 23, 2007 at 19:12
Brian/Alex,
check your emails. photos should now be there ;-)
cheers,
Sam.
FollowupID: 496453
Follow Up By: Kata - Wednesday, Apr 25, 2007 at 08:31
Gday Sam
Would it also be possible for you to send me some pics as Im also looking at doing the same on a 93 4runner
email address is kon_k@iprimus.com.au
Kata
FollowupID: 496856
Follow Up By: graemejohn - Sunday, Apr 29, 2007 at 19:20
Hi Sam.
Would it be possible for you to send me some pics as Im looking at doing the same thing on a 2005 single cab Hilux with a Roscos ali canopy on the back.
email is gowalker@aapt.net.au
Thanks Graeme.
FollowupID: 497742
Reply By: Member -Signman - Monday, Apr 23, 2007 at 11:18
I have For Sale- a heavy duty rear bumper/step incorporating swing-away wheel carrier..
Made to fit Rodeo Dual cab, but bit of mod to the bumper brackets should fit Navara
AnswerID: 235266
Follow Up By: vcbb - Monday, Apr 23, 2007 at 20:04
what sort of price are you looking at?
FollowupID: 496481
Reply By: DIO - Monday, Apr 23, 2007 at 12:34
If you are a member of the Australian 4 Wheel Drive Forum, have a look at this link, on the Hyundai Terracan Owners section, it might be just what you are looking for to give you some ideas about construction, application etc. Link Good luck with it, I put togetheer something very similar many years ago, attached to the ball mount hole, worked well, never failed me over many thousands of km's. Don't forget to obtain an additional number plate and number plate light to install on the spare wheel - if it obstructs your original number plate. It did on mine.
AnswerID: 235275
Reply By: Member - Rob S (NSW) - Monday, Apr 23, 2007 at 19:21
Hi BARS,N,RACKS Brookvale in Sydney make one about $400 .
I made my own but to carry fuel for extended out back trips but can be easily made to carry a spare tyre, they are simple to make if you have the gear and can weld .have a look at my home page there is one picture of it . if you email me i will send you more.
I only ever made one mistake
and that's when I thought I was wrong!
AnswerID: 235374
Reply By: vcbb - Monday, Apr 23, 2007 at 20:03
do they have a website at all?
AnswerID: 235392
Follow Up By: vcbb - Monday, Apr 23, 2007 at 20:16
found it, have emailed them requesting details, thank you
FollowupID: 496489
Reply By: Member -Signman - Tuesday, Apr 24, 2007 at 11:49
Hi vcbb
email me at
op(dot)support(at)tsn(dot)cc
re: rear bumper/wheel carrier
DC
AnswerID: 235506
Reply By: vcbb - Sunday, Apr 29, 2007 at 20:14
Have just picked up a pair of wheel carriers from a landcruie\ser, so I am now looking at having them placed on a bar to go in the tow bar
AnswerID: 236709
