BFG or Cooper
Submitted: Tuesday, Apr 24, 2007 at 13:44
RayB
Hi all,
Can anyone give me a comparison of cost of and mileage between BFG tyres and Cooper tyres running on a Patrol 3 litre diesel. Most driving is bitumen highway withoccassional dirt.
Thanks Ray
Reply By: Steve from Top End Explorer Tours - Tuesday, Apr 24, 2007 at 14:06
Hey RayB
I copy and pasted this of a post I did the other day.
I swear by the OZ made Bridgestone A/T duellers, I run them on 4 Landcruisers and done so for the last 6 years.
D693 265/75R/16s
These tour trucks work hard between Arnhemland,
Kakadu and
Broome, just make sure that there Oz Made as they are a much stronger tyre than the Japanese made ones.
I've never had a tyre let go yet, in fact I put another set on my new truck last Saturday and I need to replace another set on the troopy soon and that will be my 11th set.
I also get over 60000 km per set.
To me that is tried and tested.
Profits stay in OZ.
Cheers Steve.
235528
Follow Up By: SA_Patrol - Tuesday, Apr 24, 2007 at 14:28
Hi Steve,
what pressure do you run in your tyres on the, I had 2 of the Dueller AT fail on me, once doing 110kph and made $1100 damage to rear and one waiting at the red light in
Adelaide.
You must be one of the lucky one's that's had no problems with them.
496670
Follow Up By: Steve from Top End Explorer Tours - Tuesday, Apr 24, 2007 at 14:37
40 psi front 42 psi rear.
I wouldn't call no trouble with 11 sets lucky.
There just a great tyre.
Steve.
496673
Reply By: Truckster (Vic) - Tuesday, Apr 24, 2007 at 14:26
Ask Willem about coopers - he has 8 in his shed he will sell you REALLY cheap.... :)
I'd go MTR's.
235529
Follow Up By: Leroy - Tuesday, Apr 24, 2007 at 14:46
'Most driving is bitumen highway withoccassional dirt'
I don't think MTR's are the best choice.
Leroy
496680
Follow Up By: Member - Davoe (Nullagine) - Tuesday, Apr 24, 2007 at 15:13
Give you
the tip Truckster the MTR wouldnt fared much better for Willem - I have used a total of about 7 or 8 plugs in my MTR mostly in the sidewalls and shoulders and havead dramas every time I have used them apart from
well formed tourist tracks - Very good road tyre though
496685
Follow Up By: Truckster (Vic) - Tuesday, Apr 24, 2007 at 16:31
I'd say its how your using them.
Thru Flinders, they were fine, on Warraweena fine (although one of willems rags spat a pre-repaired tube), thru high country, toolangi, Marysville, on a few of the hard tracks I did with the simexs they were fine.. Only been with one dude who has sliced one, that was at Mt Dissa few weeks ago, but that was his pressures.
496701
Follow Up By: Member - Davoe (Nullagine) - Tuesday, Apr 24, 2007 at 17:02
Ive found them good on tracks like that but on less
well used tracks in the
woodlands I have found the shoulders and sdewalls susceptable to wood damage.
I recently did the Yowe rocks track from the Evanston
menzies road to Koolynobing and copped 3 punctures all to the shoulder. Done this track quite a few times running rags and the only 2 flats i got were after extended off track xcursions into the nether regions of the area for work andlast did this track with the same veicle running the MRF without incident so proper head to head . ried running lower pressures (28psi) but they only lasted 5 min off the highway.
Point is
yea i reckon there a good tyre but they ae still easily damaged out bush
496709
Follow Up By: Willem - Tuesday, Apr 24, 2007 at 18:05
Ahhh Correction needed there Trucky. Was running a radial not a rag.
Youi city blokes....lol
496725
Follow Up By: Willem - Tuesday, Apr 24, 2007 at 18:09
You city blokes....lol
496727
Follow Up By: Truckster (Vic) - Wednesday, Apr 25, 2007 at 20:18
Cheeze cutters.. :P Still outdone by the MTR LMAO
496974
Follow Up By: Willem - Wednesday, Apr 25, 2007 at 20:27
You are showing your true colours winding up a situation I found myself in. Would not have taken those tyres if there had been an option..
496977
Follow Up By: Truckster (Vic) - Wednesday, Apr 25, 2007 at 21:24
MTR's for Prime Minister - honestly they couldnt do a worse job than Mr Sheene..
dude dont get so stressed, its a bit of fun.. u know I was bleep ed iwthout your assistance... .. You should just have had MTR's :P
496988
Reply By: donnnnny - Tuesday, Apr 24, 2007 at 15:05
have had coopers and bfg's i found the coopers were very suseptable to damage in the side walls. i always seem to end up back with bfg mud or all terrain
cheers donnnny
235538
Reply By: Member - Captain (WA) - Tuesday, Apr 24, 2007 at 15:08
Watch all the opinions come out of the woodwork now!
I had several sets of BFG TA's on my 80 series and had a very good run until the 3rd set. Changed over to Coopers ST's when I got my GU 3.0TD and only replaced them this weekend after 86,000km. Still had ~35% tread but have now put them on my camper + used for spares.
While I had a very good run with the ST's and was more than happy to buy them again, others have had issues. But then again others have had a good run with BFG's while I had issues!!!
Bottom line is, both are good tyres but YMMV
Captain
235539
Reply By: BennyGU - Tuesday, Apr 24, 2007 at 17:05
On second set of 285/75/R16 BFG AT's on a GU 2.8 Patrol. A mate had the tyre dealer tell him these are illegal on a GU so he got 265's but this is shiezer. The 285's make the GU speedo almost accurate at highway speeds (102km/hr on GPS, 100 on speedo) where it was (94km/hr GPS, 100 on speedo before).
As I said the other day these tires run on my four trucks and yet to have a problem. Got them for $275 fitted and balanced each on 98 GU ST steel rims. From memory 285/75Cooper ST's were $307 each and 265/75 ATR's were $260 ea.
The work truck and GU do alot of highway and sand kilometers but both have gone to the cape three times each without probs. The Jeep and Bush Basher have done everything and no probs either. Tried the rest (coopers, yokohama, pirelli, factory fitted bridgestones) and will not go back to any of them.
This question is just like starting another Toyota Vs Nissan war........ and seing as I own both I going to be a lazy fence sitter when answering this specific question.
235556
Reply By: Garbutt - Tuesday, Apr 24, 2007 at 20:07
I recommend Evakool tyres on your Engel Patrol Cruiser
235609
Reply By: Member - Duncs - Tuesday, Apr 24, 2007 at 22:23
If most of your driving is on bitumen with the occasional dirt trip why not have a look at the Michellin LTX AT's.
Mate of
mine is running them out of
Broken Hill on a 3lt GU and has over 80,000km so far. He reckons he will replace them in a month or so. That would mean he would have done about 90,000km on them with no problems at all.
He does a bit of playing and has been on a couple of trips with me to the
Flinders Ranges and
Innamincka. We did some pretty high speeds on dirt roads on the way back from
Innamincka too.
I am running Cooper ST/C's and am reasonably happy with them too.
Duncs
235657
Reply By: Russ n Sue - Wednesday, Apr 25, 2007 at 22:18
I'm not going to buy into the argument between brands as I've never tried the Coopers on my own vehicle. I have had BFG's and I work in country guaranteed to puncture tyres, and yet with 115,000 km in two years in my Pajero, I have no idea where the jack is in that car. That should tell you something.
235815
Follow Up By: Russ n Sue - Wednesday, Apr 25, 2007 at 22:48
Oops, forgot about costs and Kms.
Mine were 265 70/R16's at $269.00 per corner. I got 45.000 Km out of the first set, 50,00Km out of the second set and still on the third set. I drive along gas pipelines where the tracks no longer exist and I pull my 1.2 tonne off road CT along for a lot of the time.
To me, this wear is pretty good and compares with my off-sider who goes to the same
places and pulls a 2 tonne caravan some of the time. He also uses BFG's.
Neither of us has blown a tyre in two years!
497003
