Desert Parks Update Bulletin
Submitted: Tuesday, Apr 24, 2007 at 17:07
ThreadID: 44677 Views:7361 Replies:3 FollowUps:10
National Parks and Wildlife South Australia
Outback Region
DESERT PARKS BULLETIN
NO. 309
24th April 2007
Flooding of the Eyre and Warburton Creeks has altered through access to Birdsville and Clifton Hills. QAA Line to Birdsville is open by a detour, and the Warburton Crossing to Clifton Hills is closed.
If you decide to travel in the Outback Region, you should ensure your vehicles are properly prepared and equipped for outback travel and any emergencies or delays. The use of trailers in the Simpson Desert is not encouraged. Serious damage can be caused to vehicles and the environment, and difficulties are likely to result. Take extra water, food and fuel supplies. Ensure good communications equipment, either HF Radio or Satellite Phone. Ensure you notify a responsible person, such as a family member, of your plans prior to travelling into remote areas, and seek local advice.
If you attempt driving in sandy conditions and get bogged, do not attempt to get the vehicle out without ensuring 4WD and hubs are engaged, tyre pressures are decreased and sand is removed from the path of the tyres. If you become stuck, do not leave your vehicles to walk for assistance as this can have fatal consequences.
Check road and weather bulletins and local conditions before travelling into the Outback Region. Speed limits of 40km per hour apply within all Parks. For up to date public road information outside of National Parks, please call the Transport SA Road Condition Hotline on 1300 361 033 or visit the Transport SA web site on Site Link.
Be aware that entry to Desert Parks requires a day/overnight permit or a Desert Parks Pass that must be displayed on the vehicle windscreen.
LAKE EYRE NATIONAL PARK
General Conditions
Floodwater is still entering Lake Eyre and flowing down the Warburton Groove but are not sufficient to view from ABC Bay, Halligan Bay or Level Post Bay. For further information regarding the National Parks and Wildlife South Australia visit our web site www.parks.sa.gov.au. For information regarding air tours phone the Wadlata Outback Centre on 1800 633 060. Check local conditions before traveling into the Outback area.
If you decide to travel in the following areas you should ensure your vehicles are properly prepared and equipped for outback travel and any emergencies. Take extra water, food and fuel supplies. Ensure good communications equipment. Notify a responsible person of your plans prior to travelling.
Halligan Bay Track – Open to 4WD with extreme caution. Caution required at creek crossings, corrugated sections and silt bar areas created during January rains. Take care on cut up sections and gutters caused by traffic after past rain. This track is a declared Public Access Route. Driving on the Lake surface is an offence and dangerous. Recommended speed of 40km/h once reaching gibber country and dropping down to Lake Eyre.
Level Post Bay Track – Open. This track is a declared Public Access Route. Driving on the Lake surface is an offence and dangerous. Major sand drifts have occurred on the car park area at Level Post Bay and extreme caution should be taken to avoid becoming bogged. If in doubt, check the sand dune area for conditions before entering or take the short walk from the Lake Eyre National Park sign to the lake (approximately 150 metres).
William Creek Roadhouse – Agents for the Desert Parks Pass & Lake Eyre Permits. Accommodation & caravan park facilities available. Ph: (61 8) 8670 7746
Marree’s Outback Roadhouse – Agents for the Desert Parks Pass & Lake Eyre Permits. Post Office & Commonwealth Bank Agency, diesel & unleaded fuel, gas bottle refills, licensed restaurant and take away service available. Ph (61 8) 8675 8360
INNAMINCKA REGIONAL RESERVE
General Vehicle Access.
Note: Be aware that entry to Innamincka Regional Reserve requires a day/camping permit or a Desert Parks Pass that must be displayed on the vehicle windscreen. Desert Parks passes/permits are available from the Innamincka Trading Post.
Coongie Track – Open. Caution at roadworks, and areas of ponded water and loose sand.
Walkers Crossing Track – Closed at the crossing. Due to flooding.
15 Mile Track and Access to Cooper Creek – Open. Will’s Site - caution at washouts.
Burkes – Open.
Cullyamurra Track – Open.
Bore Track – Contact Bollards Lagoon (61 8 8091 3873) prior to crossing private land.
The Innamincka Trading Post (Ph: (61 8) 8675 9900). Agent for the Desert Parks Pass and camping permits. Provide a comprehensive range of supplies and services for visitors in the Innamincka area.
Innamincka Hotel (Ph: (61 8) 8675 9901). Provide meals, drinks and accommodation.
WITJIRA NATIONAL PARK and the SIMPSON DESERT RESERVES
General vehicle access
Check local conditions before travelling into this area. See the National Parks and Wildlife South Australia web site on www.parks.sa.gov.au for more information.
Witjira National Park – Open to 4WD.
Caution is required on wet, soft sections of road from Dalhousie Springs to Purni Bore due to recent rain. Grading will continue to occur during April/May so use caution with machinery on roads. Spring Creek Delta is closed until further notice, so use the by-pass road.
Check local conditions before travelling. Please call the Desert Parks hotline on 1800 816 078 for further information. A public phone (card only) is available at Dalhousie Springs. (Note: Phone cards not available at Dalhousie) Camping should be restricted to Dalhousie Springs, 3 O’clock Creek and Purni Bore while within Witjira National Park.
The Pink Roadhouse Oodnadatta – Desert Parks Pass Agents, phone cards, diesel and unleaded fuel, food and travel supplies, fine food, refreshments, tyre and minor repairs and welding –
Ph: 1800 802 074 Email: pinkroadhouse@bigpond.com
Simpson Desert – Open to 4WD only. No access/exit via Warburton Crossing.
Access/exit via the QAA line is open by a sign-posted detour at Eyre Creek. More water is expected to arrive so this route may become closed at any time. Ensure you have enough fuel, food and water for an exit from the Simpson Desert by a return trip via Dalhousie when Eyre Creek levels happen to rise. The use of trailers in the Simpson Desert is not encouraged. Serious damage can be caused to vehicles and the environment, and difficulties are likely to result.
Visitors are advised to drive in a convoy, carry a HF radio or sat phone and limit the total load of their vehicles. However, do take extra reserves of fuel, food and water. Check local conditions before travelling in the area. Satellite phones are available to hire for Simpson Desert trips from Mt Dare Hotel and the Wirrari Tourism Centre in Birdsville. See contact details below.
Warburton Crossing – Closed due to flooding until further notice.
Mt Dare Hotel – Desert Parks Pass Agents - Diesel and unleaded fuel, accommodation, meals, hot showers, fuel, minor repairs, camping and travel supplies available for travelers. Satellite phones are available to hire from Mt Dare Hotel for trips across the Simpson Desert. Contact Mt Dare on (61 8) 8670 7835
ADDITIONAL INFORMATION
Hire of Communications Equipment
Satellite phones can be hired from Oodnadatta, Marree, Birdsville & Mt Dare. For further information call:
Wirrarri Centre - Birdsville (61 7) 4656 3300 Mt Dare Hotel (61 8) 8670 7835
CONDITION UPDATES
As conditions change a further update bulletin will be issued. For further information on SA Desert Parks and Far Northern South Australian road and track access, please call the Desert Parks toll free hotline on 1800 816 078 or the Transport SA Outback Roads hotline on 1300 361 033.
Alternatively contact local Police where applicable for condition updates. For travel communications, contact the Australian National 4WD Radio Network Inc on (61 8) 8287 6222.
Tony Magor
Senior Ranger
DESERT PARKS
desertparks@saugov.sa.gov.au
While every attempt has been made to provide up to date information in this bulletin, all travellers are responsible for ensuring that they obtain accurate and detailed information and are properly equipped and prepared for all emergencies prior to traveling into remote outback areas.
Privacy, Disclaimer, Copyright © 2007
Reply By: Willem - Tuesday, Apr 24, 2007 at 18:00
Good on ya Uncle Des. Now the hordes will be appeased for 5 minutes. once the thread is off the page someone will post(in a small voice) " Can I go via Walkers Crossing in May?"....LOL
AnswerID: 235572
Follow Up By: Bonz (Vic) - Tuesday, Apr 24, 2007 at 23:02
FollowupID: 496811
Follow Up By: Des Lexic - Tuesday, Apr 24, 2007 at 23:36
No Read the B** text
FollowupID: 496818
Follow Up By: Bonz (Vic) - Wednesday, Apr 25, 2007 at 08:08
i read my SMS txt nothing about it on the phone.....So can I?
FollowupID: 496853
Follow Up By: Des Lexic - Wednesday, Apr 25, 2007 at 14:06
Yes but only if you leave right now
FollowupID: 496894
Follow Up By: Bonz (Vic) - Wednesday, Apr 25, 2007 at 15:50
ok I'm o
FollowupID: 496908
Reply By: ExplorOz Team - Michelle - Tuesday, Apr 24, 2007 at 20:07
I hope that everyone is aware that every edition of this bulletin is summarised in our Road Conditions reports on the SA page, and put into the road conditions map -
see http://www.exploroz.com/Roads/SA.asp#Deserts for the exact section of SA where the desert info is located.
These reports are updated a couple of times per week, or when new reports are received. Travellers are reminded that they may also contribute by adding interative feedback. Only official reports are used to update our reports - so this makes digesting the info on these pages easier for you to determine who says what. ie. the left column is the official report, the right column has been entered by registered users to the site entering updates and allows more flexibile and detailed reporting. The map is based on the road status - either open, closed or caution and is based on the official report.
Michelle Martin
Marketing & Customer Support
AnswerID: 235611
Reply By: Bonz (Vic) - Tuesday, Apr 24, 2007 at 23:02
Man u r a typer Des, taking your lappy to the OBC?
AnswerID: 235666
Follow Up By: Des Lexic - Tuesday, Apr 24, 2007 at 23:41
No and Yes I need some lessons on the PDA,
Where do we camp during the week? Bush/Silverton elsewhere???
Waiting on a call from the Supreme Passage Controller. He was doing a westwards border crossing last weekend and the Jeepney couldn't make the grade so he did a Northerly one instead. I think he was looking at a Territory.
FollowupID: 496819
Follow Up By: Bonz (Vic) - Wednesday, Apr 25, 2007 at 08:09
I am looking at a Territory
FollowupID: 496854
Follow Up By: Bonz (Vic) - Wednesday, Apr 25, 2007 at 11:51
Bring it along we do BH lessons on anything and everything for a small fee
Lucy und Bonz am camping at the West Darling Hotel $30 a night incl breakfast and a scintillating atmosphere we're booked in already
FollowupID: 496883
Follow Up By: Des Lexic - Wednesday, Apr 25, 2007 at 14:09
I think Lucy was looking at a Capital territory.
Are you staying at at the Pub for the whole week or just Fri and Sat nights?
FollowupID: 496895
Follow Up By: Bonz (Vic) - Wednesday, Apr 25, 2007 at 15:51
Staying Mon thru to the Sat night then up to Nundooka, when'r u arriving?
FollowupID: 496909
