gu springs
Submitted: Wednesday, Apr 25, 2007 at 11:40
ThreadID: 44704 Views:1991 Replies:3 FollowUps:0
I read somewhere that gu springs will give a gq a 1 1/2 lift. Can anyone confirm this? What other improvements in suspension are on the gu?
Reply By: howie - Wednesday, Apr 25, 2007 at 14:05
can't confirm anything, but i have a complete set of springs and shockies taken off a 2001 gu before it hit the road. no reasonable offer refused, but i am in perth.
however, i will miss them being in the wardrobe!
AnswerID: 235736
Reply By: Pezza (Bris) - Wednesday, Apr 25, 2007 at 15:28
I stuck a set out of a petrol GU in my 3lt petrol GQ and it came up just under an inch, my old man still has the ones I put in his 4.2 diesel GQ, they came out of a GU 4.2 TD and lifted it 20mm.
The ride is much better than the GQ springs, takes the 'Queen Mary' body roll out of it as the shocky's are better technology as well, it's much more stable and 'confident' over undulating surfaces and round corners.
Pezza
AnswerID: 235754
Reply By: rolande- Thursday, Apr 26, 2007 at 17:35
G'Day,
I was told you would get about 1" due to the extra weight of the GU.
I bought a set of aftermarket 2 1/2" lift springs for my GU.
When I compared this with the original height the rear was 4" higher and the front 3" higher.
"What the!"
Until I checked new height against mates new GU. Turns out it really was only 2 1/2" higher, the extra came as a result of my orignal springs sagging.
I now believe it has as much to do with newer springs as the difference in models.
Plenty of "as new" standard springs around for almost nothing. Well worth changing to get a small improvement.
Hope this helps
Rolande
AnswerID: 235950
