One for you all sparkys out there.
Submitted: Thursday, Apr 26, 2007 at 12:26
4wdNewbie
I think my problem is that I don't want to acknowledge the fact that $1000 worth of amps lay dead in my garage. For those of you who remember the dramas I had with the Mav, after getting it home, I noticed an oily substance on the amps ( and an empty motor oil bottle :(( ), and after trying both of them, have concluded that both are in amp heaven. However, is there anything I can try/replace that may allow them to work properly? It may be a longshot but any suggestions are welcome. I'm trying to source a working amp to rule out there being any wiring issues. As is stands, one of my mates suggested changing all the fuses so ill give that a go and see what happens.
Cheers, Anand.
Reply By: 4wdNewbie - Thursday, Apr 26, 2007 at 12:29
Nothin left to do now but sit here hitting refresh till I get a reply or go out to lunch... :D
235891
Follow Up By: Des Lexic - Thursday, Apr 26, 2007 at 12:40
Go out down to the Pub and drown your sorrows Newbie.
497071
Reply By: Sacred Cow - Thursday, Apr 26, 2007 at 12:42
I presume amp = amplifier?? Saturate all of the amp including the printed circuit boards with
water and dishwashing detergent (definitely not DISWASHER powder/detergent). Paint on with a brush and work in thoroughly. Then use a Gerni at lowest pressure setting and blast all muck of PCBs, etc. Ensure everything looks like new in that it is so clean. Heat in an oven at precisely 49 degrees Celsius for 30 hours.
SC
235893
Follow Up By: Member -Signman - Thursday, Apr 26, 2007 at 13:31
You sure it's 49 deg. C for 30 hours???
I thought it was 30 deg. C for 49 hours !!!
497079
Follow Up By: 4wdNewbie - Thursday, Apr 26, 2007 at 13:36
Are you guys pullin my leg here? And yes amp as in thing that makes my sub go boom boom.
497080
Follow Up By: Nick R - Thursday, Apr 26, 2007 at 13:57
boom boom??? I thought it was doof doof and the tweeters go oonce oonce
Nick
497082
Follow Up By: 4wdNewbie - Thursday, Apr 26, 2007 at 14:04
Oh, is it doof doof... a couple of years of having a big sound system and I can't actually hear anymore... XD
497083
Follow Up By: WA Joe - Thursday, Apr 26, 2007 at 14:32
I'd be trying "Contact Cleaner" saw something similar with a cup of coffee once and contact cleaner did the trick. Good luck.
Joe.
497089
Follow Up By: Red Frog - Vic - Thursday, Apr 26, 2007 at 14:37
That was me I can't stand that boom boom noise. I added some molecular transfer liquid to the cloud seeding that's been happening in your area, you need rain right! anyway what it does is make all the amps the produce the boom boom go BOOM
497090
Reply By: Member - Glenn D (NSW) - Thursday, Apr 26, 2007 at 16:06
Hows it going ,
I reckon the damage is done by turning them on wil the oil all over them , hopefully the fuses have protected them.
You can clean them in something like Isopropyl alcohol , you will need to strip them down and use a brush , if you get a thin 1" paint brush and cut the bristles so it leaves about 1/4 of original length it will make like a mini scrubing brush.
After your done you can dry with compressed air or just leave to air dry .
Hope this helps you out .
Glenn.
235925
Reply By: Member - Stephen F (VIC) - Thursday, Apr 26, 2007 at 16:32
Newbie just a thought do you have a mulit meter if not get one the cost of replecing all the fuses may just pay for a cheap meter test all your fuses (1 at a time so you remember which fuse went where) on continuity if all in contact turn your meter to dc volts and test voltage going to amp (leave amp disconected while testing) if you have your old head unit with the inbuilt amp test your speakers with this.
As mentioned above pull amp apart and clean with isotopal alchol this stuff just evaporates.
just curious where have you got your amps mounted?
I hope this helps lets us know how you get on
cheers Stephen
235931
Follow Up By: 4wdNewbie - Thursday, Apr 26, 2007 at 22:00
had them under the rear seats in the gq. Botton of the
seat folded up so access was easy enough.
497183
Reply By: nowimnumberone - Thursday, Apr 26, 2007 at 18:48
pull the covers of the amp.
wurth make a contact cleaning fluid
use as directed and give it a go
its briliant stuff.
had a jeep a few weeks ago power windows wouldnt work all the time
pulled the plugs of the switches gave them a couple of sprays all works great.
i had a stereo in our car that played up a bit(flip out head)sometimes volume wouldnt work couldnt push play ect.
after using it on the jeep and seing it work i tried it on our stereo.
that was a month ago and still going fine.
i dont work for wurth(in fact i think there to dear)but that stuff works.
235968
Reply By: Sacred Cow - Thursday, Apr 26, 2007 at 19:02
Please re-read what I wrote earlier today. On no account use iso propyl alcohol or any other solvent as suggested by others. If you do, you will dissolve all the printed circuit board varnish and varnish off any enamelled wire. I have provided you with the correct industry method of recovering electronic equipment after an environmental catastrophe. I have experience in this field after a $30M fire.
SC (Electrical Engineer (Electronics and Telecommunications)
235975
Follow Up By: Tim - Thursday, Apr 26, 2007 at 21:46
Yeah ditto to that, melted boards are not a good thing. There are some that will literally eat plastic, its a very sad lesson that I have learnt the hard way as
Tim
497173
Follow Up By: Member - Glenn D (NSW) - Friday, Apr 27, 2007 at 20:37
Hows it going Mr Cow ,
I am an Avionics engineer , the only thing we are allowed to clean elctronics with is Isopropyl Alcohol because it is gentle and doesnt leave any deposits behind when it drys.
Other products such as canned contact cleaner , white solv etc desolve plactics easily !
All 'varnish' used on circiut boards should be like resin which needs to soak in paint stripper to remove it , havent done that for about 15yrs but cant imagine that it has changed that much.
Glenn.
497362
Reply By: Geoff (Newcastle, NSW) - Thursday, Apr 26, 2007 at 21:24
The Sacred Cow is on the money, be very careful with solvents.
They strip the varnish off PC boards.
Geoff
| Geoff,
236017
Reply By: 4wdNewbie - Thursday, Apr 26, 2007 at 22:04
Righto Crow if you aren't giving me a bum steer then I'll give it a go. Wasn't sure if you were having me on or not. So one question remains, do i bake the amp or grill it :))
Cheers to everyone for all the info and I'll let you know how it finishes up (or drive within 5k and you will hear me:)).
Cheers, Anand.
236030
