Tubes in Tubeless Tyres ??
Submitted: Thursday, Apr 26, 2007 at 20:29
ThreadID: 44755 Views:6448 Replies:11 FollowUps:4
Evening All,
I'm planning on fitting tubes into my tubeless tyres. Anybody had any problems doing that??
Main reason is to drop pressure without worrying about pushing the bead off the rim and letting the puff out.
BoB
Reply By: Andrew-rodeo - Thursday, Apr 26, 2007 at 20:40
Tubes are more prone to punctures, and if a bead moves it can pinch a tube. I would personally go with bead locks.
AnswerID: 236005
Reply By: Willem - Thursday, Apr 26, 2007 at 20:49
What psi do you want to run? You can safely drop down to 8psi without running a bead off. Careful driving techniques would be necessary though.
AnswerID: 236007
Follow Up By: Smudger - Thursday, Apr 26, 2007 at 23:42
The recommended low pressure without bead lockers is 16psi. Below that you're at risk of rolling the tyre off the bead. Before tubes, investigate bead lockers, you can the go down to 5 -8 psi without risk. But, why would you want to go that low?Competition trucks are about the only guys I know who reduce pressures so low.
FollowupID: 497202
Follow Up By: Willem - Friday, Apr 27, 2007 at 00:27
Who recommends it?????
I regularly run pressures below that on desert crossings and beach work and have only once run a tyre off a rim and that was a tubed tyre!
FollowupID: 497211
Follow Up By: Wayne-o - Friday, Apr 27, 2007 at 01:23
my gauge stops at 5psi and have had to drop below that to get out of a bog. The BFG's had no worries, and to top it off my compressor sh_t itself on inflation and had to drive with less than 5 psi 20km to the servo, we just out of Coral bay. Obviously had the tyres inspected at the first chance, but there was no damage. Have done this twice now, but as already said be careful, turn shallow and keep speed below 25kmph.
FollowupID: 497218
Reply By: Crackles - Thursday, Apr 26, 2007 at 21:28
Bob I ran a few sets of tubeless tyres with tubes fitted for the same reason, in particular in bog holes. No immediate issues although towards the end of their life I had a couple blow out. BFG's have a small sticker inside the tyre that if not removed can rub a hole in the tube as well. Run good quality heavy tubes & you shouldn't have too many issues. They may run a touch hotter but we don't normally run mud tyres at high speed anyway. They make a cheap set of bead locks.
Cheers Craig................
AnswerID: 236020
Reply By: Beast of Bodmin - Thursday, Apr 26, 2007 at 21:58
Thanks for the response fellas.
The tyres are Simex Jungle Trekkers - for winter trips etc.
Last year l ran my 33" MTR's down at 23psi and they were generally ok, but at 16psi, pushed off the bead in the rough stuff. I thought about 2nd air beadlocks but at $250 or so per corner, its too much. Simex tubes are $35 each!
I'm hoping the tubes will hold the bead on and l wont have to worry about losing air.
Another plus. My ladder chains for the MTR's fit the JT's ok too.
AnswerID: 236028
Follow Up By: Edmund from Toyota LandCruiser Club of South Austr - Thursday, Apr 26, 2007 at 22:47
Bob as stated by others you shouldn't have to many issues, I can't see why you would get any more punctures than tubeless, the one thing to watch is when down low 10-12psi be careful of using too much power too quickly,you might spin the tyre on the rim and damage the valve stem. Jap tubes seem to be ok.
FollowupID: 497193
Reply By: obee - Thursday, Apr 26, 2007 at 22:46
I think people go to tubeless when a lot of low pressure operating is called for. If the tyre spins on the wheel a tube will have the valve ripped off any way. Air pressure is air pressure tube or no tube. I cant see how a tube would solve anything. I use tubes because I am too mean to buy new rims for tubeless! As already mentioned there is heating issue and punctures and repairs. tubeless are much easier to plug than tube is to remove and patch at least where the sidewalls are not holed.
Owen
AnswerID: 236039
Reply By: Richard Kovac - Thursday, Apr 26, 2007 at 23:37
BoB
A Toyota 70 series that runs split rims has tubes in tubeless tyres standard,
you only have the same problem that we have, that is if you get a puncher the tyre goes flat..
It is OK and for the reason you're doing it is a good enough reason (to me)
Richard
AnswerID: 236056
Reply By: Member - 'Lucy' - Friday, Apr 27, 2007 at 00:34
BoB
Why don't you contact the Nat Importer of the Simex Jungle Trekkers and have a chat to him.
He is a high profile comp person and uses 2nd airs or internal bead lockers (whatever you like to call them)
I have watched him 24/7 on the Outback Challenge where I have a particular 'marshalling' role, and what he doesn't know about keeping beads on the rims at low pressure's is not worth knowing.
His name is Chris Hummer and you find him at Dynamic Tyres in Melbourne.
AnswerID: 236065
Reply By: Dion - Friday, Apr 27, 2007 at 08:03
A tube is not designed to work in a rim meant for tubeless tyres. Damage can occur to the valve stem, as it is designed to work in an elongated hole, and sit central in the rim. The rim also is usually flat across it's inner surface.
The tubeless rim has a contoured surface which is unsuitable for tubes.
I'd only fit a tube to a tyre as a last resort to get me out of strife, ie tyre casings being absolutely buggered.
Dion.
AnswerID: 236087
Reply By: Member - Davoe (Nullagine) - Friday, Apr 27, 2007 at 09:23
Wont work for that purpose - in fact the oposite
Iwas running very low pressure on the beach to make a sandy cutting. Unknown to me one of my ytres was running a tube. It spun the tyre a bit wrecking the tube - no worries with the tubless tyres and that was running 5 psi from the cutting at bellingers beach up the top of Mt pasely (I was to slack to reinflate them) and most of the way along poison creek beach until the tube gave up
AnswerID: 236112
Reply By: Flash - Friday, Apr 27, 2007 at 09:59
There's no way in a million years I'd fit tubes, for the reasons above and more.
You'd regret it trust me......
AnswerID: 236125
Reply By: Godlike Chef - Friday, Apr 27, 2007 at 11:43
I wouldn't put tubes in tubeless tyres as when i was on the beach at Bell's Point (Near Middle Lagoon, Broome) I had to let my tyres down to 10psi to get out of a bog in the sand, when i drove off the beach the track had a couple of rocks on it but was only about 30m to the camp, pinched the tube and got a flat. Didn't even know there was a tube in it until then as it was the original one on the vehicle when i bought it second hand, pays to have a look! Had it happened on the way down onto the beach it would have been a nightmare to get off the beach!!!!!!
AnswerID: 236151
