jerry cans on roof rack
Submitted: Thursday, Apr 26, 2007 at 22:18
MATT DAY
Hi All
When carrying jerrycans on the roofrack can they be laying on their back or
standing up, which is better? Never carried them before, we will be taking 4.
Matthew & Julie
Reply By: Voxson - Thursday, Apr 26, 2007 at 22:30
laying on their back with the spout at the top is ok so long as you have a good new seal....
I find it ok if you maybe put 18 litres in....Because even new seals sorta leak a bit...
4x4 shops sell a dual jerry can holder which can strap to your roof rack..
236035
Follow Up By: MATT DAY - Thursday, Apr 26, 2007 at 22:35
Thanks for that
497191
Reply By: Willem - Thursday, Apr 26, 2007 at 22:58
Matt
In the past I have carried jerries on the roof rack by laying them down on a rubber mat. If you make sure, or buy new seals, the cans won't leak. You can strap them down. Just remember each weighs around 20kilos so handling is a pain and it does raise your centre of gravity a tad. I have dispensed with a roof rack now as it just encourages one to carry too much gear...lol
236045
Reply By: Smudger - Thursday, Apr 26, 2007 at 23:36
As long as the seals are good and the spout is up, no prob's. And if you have a long enough syphon hose you won't even have to move them, just run the hose down to your filler ..and fill them where they are at the next servo.
236055
Follow Up By: PradoTrev - Friday, Apr 27, 2007 at 12:16
Check it out first but you should always have the jerry on the ground (earthed) to avoid a staic spark when fillg them up. Mainly for Petrol yes
But fuel is fuel.
TM2CW
Trevor
497277
Reply By: howie - Thursday, Apr 26, 2007 at 23:51
DIesel or petrol?
plastic or metal jerries?
i carry plastic 20L of petrol on roofrack. (renew seals if needed)
3 jerries fit standing up in a black kerbside recycle bin, easier to tie down and stops them moving about.
only put max 20L in jerry and of course, empty the jerries as soon as possible.
drive accordingly with the centre of gravity being high.
236062
Reply By: Diver1 - Friday, Apr 27, 2007 at 09:12
We use 2 x 20lt red plastic cans....lay them on the side with spout up the top and not the bottom....didnt replace seals.....use marine carpet underneath, on side and behind them on the roof rack...(still got the carpet there too!) to stop and rubbing...
Laura
236108
Follow Up By: SA_Patrol - Friday, Apr 27, 2007 at 09:56
Will the carpet cause static electricity?
Maybe it won't if you don't walk on it :-)
497253
Reply By: Ole Grizzly - Friday, Apr 27, 2007 at 10:17
Just be aware of the danger (Static Electricity) either place them on the ground to fill, or use an earth strap if filling while up on the rack.
I use plastic outboard fuel tanks..low profile..robust and never leak.
236132
