shock absorbers
Submitted: Monday, Apr 21, 2003 at 08:26
PETER
just heard that shock absorbers should be fitted to caravans and trailors is that so and if so what should i have fitted to a duel wheeled tandem pop top of 6.5 m thanks for your help peter
Reply By: Johnad - Monday, Apr 21, 2003 at 16:44
I have an off road caravan that is fitted with ind.
suspension. The only shocks that I would use are Koni. I would suggest speaking to the experts regarding your setup. The people I use are toperformance on 03 9873 1722, they provide really sound advice.
Good luck, John
18013
Reply By: Flash - Tuesday, Apr 22, 2003 at 11:40
It's an old arguement, but I would never tow a decent trailer or van without shocks- just like i wouldnt drive a car without shockies either. The trick is to find a shocker that fits your van or trailer and it will often have to be mounted on a fair angle- I recently fitted shocks to a mates almost brand new 18foot van and it made a HUGE difference to stability-
Used new Monroe pump-ups (air-lifters)from an Escort panelvan which we chose after going thru specs in the catalogue- works a treat and quite affordable.
Koni are very good but very expensive- not really cost effective for most people... ie: how many
miles would your rig do?
Good luck
18076
