Adelaide Local 4wd Tracks
Submitted: Friday, Apr 27, 2007 at 11:31
Bubbles
Does anyone know any 4wd tracks that are within 30mins of
Adelaide? Doesnt need to be too long or hard but enought to test out the vehicle.
Fil
Reply By: SA_Patrol - Friday, Apr 27, 2007 at 11:48
Adelaide isn't that small, 30mins will only get you as far as Salisbury/ Lonsdale, there are dirt roads within that time but not 4wd tracks, unless you want to cross the River Torrens :-)
236152
Reply By: Bubbles - Friday, Apr 27, 2007 at 11:52
What about in the foot hills towards Basket Range ?
236155
Follow Up By: SA_Patrol - Friday, Apr 27, 2007 at 12:43
I don't know of any around there, aren't they mainly dirt roads
Morgan Quarries is the best you'll get within 2 hours drive from
Adelaide.
Shell Hill , around palmer rocks is very basic.
Pt
Gawler,
Deep Creek
A private property will open up soon in
Kersbrook
497278
Reply By: PradoTrev - Friday, Apr 27, 2007 at 12:01
Hi bubbles
The back of coxes scrub just out of Mt compass is a short track that will give you a quick fix and stop the shakes and withdrawls.
The back of the Aussie pub has a 1k track with some light weight rough bites (private land at the end)
thats about it
236159
Follow Up By: Voxson - Friday, Apr 27, 2007 at 13:16
Yeah,, you can go across coles crossing,,,, finnis river.. *spelling*...should be a couple of feet deep today...
Then up a tricky
little hill afterwards..
497286
Reply By: thomasando - Friday, Apr 27, 2007 at 14:39
Saunders Gorge in the
Adelaide Hills. I haven't actually been there (was planning on it when I was in
Adelaide in January but didn't have time) but looks good from the website.
Saunders Gorge
236182
Reply By: Gossy - Friday, Apr 27, 2007 at 15:24
Correct. Saunders Gorge is basically it. Real 4wding close to
Adelaide can only be achieved in the Southern flinders :(
236197
Reply By: Member - Davoe (Nullagine) - Friday, Apr 27, 2007 at 16:44
Unfortunatly he has sold the property but a freind of
mine had excellent 4wding on his Callington property which he let some 4wd clubs use - Good oportunities exist in the area if you can get to know landholders. We spent 1/2 a day 4wding and fishing
236213
Reply By: Member - lyndon K (SA) - Friday, Apr 27, 2007 at 17:36
Yep
Adelaide sux when it comes to 4x4. Used to be some good fire tracks at skye. Learned to ride my dirt bikes there, like everything else!! LOCKED UP!
Ofcourse you can still get in there with a dirt bike, if you know how :))
236222
Follow Up By: Pete and Lez S.A. - Saturday, Apr 28, 2007 at 20:57
Gee, I wonder WHY they are locked up these days!!!
497571
Reply By: hiab - Friday, Apr 27, 2007 at 19:41
head to mcclaren vale, go through mcclaren vale towards willunga, as you come into willunga there is a
cross roads, the school is on the other side, turn left there and follow that road up to a substation, turn right and go up the
hill and follow to the end where it turns into a track which goes up another
hill, pretty good track, has some ruts and rock stairs very tricky if wet. when you get to the top you will drive past a couple of houses then come to a sealed road, turn right for willunga or go back down the track .
236249
Reply By: little rhino - Monday, May 14, 2007 at 02:18
hey, most of what you read from the others is spot on. coles crossing is short but has a mud hole normally ok weeks after rain, follows hard sandish track with
water ruts on the side, for the eager, bit after that it will bend left and down. about halfway you mite want to look as is a nice drop off. im only stock height so its a challenge for my little terrano 3.0l petrol. after the drop abit down the road is a
creek ( finess river) has a rocky pebble bottom so traction is ok not to hard apart from the drop off. follow through
creek to a
hill climb that overlooks
murray mouth. comes out near kuipto forest. nice test track. may find only one way if wet due to drop off can be a b****. head towords mt compass take the Knagarkt turn off and take your third left BLACKFELLOWS ROAD im 99% sure follow that cant go wrong.
239850
Reply By: little rhino - Monday, May 14, 2007 at 02:19
creek to a
murray mouth. comes out near kuipto forest. nice test track. may find only one way if wet due to drop off can be a pain. head towords mt compass take the Knagarkt turn off and take your third left BLACKFELLOWS ROAD im 99% sure follow that cant go wrong.
239851
