Jayco Outback
Submitted: Friday, Apr 27, 2007 at 17:26
meercat
Hi having looked at various offroad camper vans, I am looking at purchasing a camper from the Jayco outback range - most likely secondhand though. Does anyone have info/advice on the difference between build quality of say a 2000 model vs a later model. I have heard that prior to 2003, all Jayco outback models suffered from poor chassis build. So far I am looking at the Hawk, Swan or Eagle but the Flamingo seems to grab me in terms of subtle extras and room. For $17k, I can pick up a 2000 Flamingo outback but this doesn't include the electronic brake controller or tregg hitch system.
Reply By: Alcoz - Friday, Apr 27, 2007 at 19:53
HI meercat
I have a 93 Eagle off road, while being no expert l have noticed the A frame section threw to chassis is different from
mine to the early 2000 models.
I've chatted to people along the way and the only real problem we've all struck is interior cupboard construction but you can fix it by re-enforcing the joins.
It's also going to be influenced by where you plan to go.
Fiddling and altering these thing to suit yourself is half the fun anyway!
Enjoy!
Regs Al
236256
Follow Up By: meercat - Saturday, Apr 28, 2007 at 14:06
Hi thanks Al, I believe the problem relates more to the
suspension as opposed to the overall chassis.
497482
Reply By: RosscoH - Friday, Apr 27, 2007 at 20:39
Hi Meercat, $17,000 seems a bit too much for a 2000 model, I got a 2004 model Flamingo that has only been used half a dozen times and hasn't done 10,000 kms for $16,500. Still looks like new.
Cheers RosscoH
236269
Follow Up By: meercat - Saturday, Apr 28, 2007 at 14:07
Was this for the offroad 'outback' version as I can find an onroad late model Flamingo for around $17k.
497483
Reply By: Anthony - Friday, Apr 27, 2007 at 22:30
Hi Meercat,
We have a 2003 Dove Outback, which has the aluminum frame in the walls and a wooden frame for the cupboards and seats. The wooden framing has staples on all joins and uses screws and angle brackets on about half of the stapled joints.
As far as the chassis goes, the 03 model uses 125mm by 50mm box A-Frame. I think that Jayco was trying different a cross section A-Frame (2002 models ? with lighter box section) but went back the 125mm by 50mm box section.
The Jayco is not a heavy duty off road camper, but if you are ok with the
tools and able to do a few custom mods that suit your needs and take it a bit easier on the rougher stuff, then I think you will find the Jayco Outback good value for money.
The few tips/mods I’ve picked up to help improved the Jayco Outback for off road work are.
Fit some sheet metal to protect the
tank drain tap from stone damage.
Cover or paint the
tank fill and pump piping (clear plastic tube) to help prevent algae growth in the
tank by blocking out sun light.
The lower shocker mounting brackets fatigue on the (I think ?) pre 2003 models. The lower mounts break with a lot of corrugations causing the lower brackets to flex and break. The solution is to fit stronger brackets or reinforce the existing ones.
Replace the screws that fit the upper roof clamp brackets (which lock the roof section down while towing) with 3/16 nuts & bolts. I’ve heard that the odd clamp has popped its screws on rough tracks.
Jayco changed to a Setec 12volt power supply (with inbuilt battery charger) late 2003/ early 2004. The Setec is a local made unit and the previously used American 12 volt supply/charger seemed to have a few problems. Ours failed twice, then Jayco fitted a Setec (at no cost). Had no problems since.
236306
Follow Up By: meercat - Saturday, Apr 28, 2007 at 14:12
Hi Anthony thanks for taking the time to describe the problems. I don't plan on doing really rough stuff but I am a bit of a 4wd buff so would like to be able to take it off road where standard campers can't get to. I plan on taking a 6 week trip along the west coast thru
Kakadu so corrugated roads will most likely be plentiful. I will be towing it behind a 2001 Patrol. I hadn't heard of the battery problem before. Based on other
forum responses, I am wondering if I should just hold off and wait for something post 2003 to come along if Jayco have rectified the problems they experienced with earlier models.
497485
Reply By: Muzzgit [WA] - Saturday, Apr 28, 2007 at 00:25
Before you buy anything, get inside and climb on the bed, both of you. Then see what happens as you get off the bed.
I'm serious... some of the Jayco models have a tiny little step and trying to get up on the bed is embarrassing, if not awkward. Then getting down can be a little scary.
On the Finch - Dove - Eagle models, there is a couch/
seat at the main bed end and it is easy to get on to the bed.
The Hawk has the silly little step at the main bed end.
We bought a new outback Finch in 2005 but sold it last month and bought a 2005 Dove to get the bigger bed, and there have been some quality issues with both.
The cupboards need some re-enforcing, the electrical wiring underneath needs more cable ties, the
water pipes (plastic) need to be cable tied.
Don't over tighten the roof clips and you won't pop any screws!
They are a light duty camper with a heavy chassis and an "OUTBACK" sticker on the back !
236332
Follow Up By: meercat - Saturday, Apr 28, 2007 at 14:13
Thanks for
the tip - I really didn't even consider this.
497486
