No Spark from Coil
Submitted: Saturday, Apr 28, 2007 at 21:14
ThreadID: 44850 Views:7625 Replies:7 FollowUps:3
I'm pretty sure there is no spark did the basic lead test, but how do you determine what the exact cause is?
I've tried another coil, still no spark, I've tried another lead still no spark
4x4 specs FJ62 F3 LPG/FUEL
Any one got some ideas on how to check for faults, will try again in the morning
Can some one point me the right way to Electronic ignition please ( website )
TT
Reply By: awill4x4 - Saturday, Apr 28, 2007 at 21:34
If new leads and coil still produce no spark perhaps the points have closed up or it's a rotor button/distributor cap problem.
One critical feature required by all LPG powered vehicles is a very good spark and keeping your ignition system in order really is important. Poor spark with LPG is the usual cause of backfiring and is common on LPG carby GQ Patrol's, the fitting of electronic ignition to these gives excellent results but whether you get the same benefits with your HJ60 I don't know.
Regards Andrew.
AnswerID: 236491
Follow Up By: awill4x4 - Saturday, Apr 28, 2007 at 21:46
Oops, sorry TT I didn't see you have the FJ62 but the same principles apply. Most of the Nissan guys convert their points setup to a Pertronix electronic system together with an extended rotor button specifically for GQ Patrols.
Ontrack Automotive in Ferntree Gully, Melbourne sell them and they also have kits to suit Toyota as well here's a link to their system.
Pertronix ignitor
Regards Andrew.
FollowupID: 497579
Reply By: hiab - Saturday, Apr 28, 2007 at 21:47
check for spark at the points, ignition on and a screwdriver across the contacts, if nothing check points contact area for pitting , check gap, cant remember the gap but i would guesstimate 14 -16 thou, if points are pitted obviously replace, next suspect the ballast resistor, white ceramic with wires attached, if you have a spare try that one, dont forget condensor, check the distributor shaft cam , they can seize, lube if suss and try turning the motor over and see if shaft turns , also been known to break, sorry if im wrong, diesel mech., but spark only comes from a few places, and suspect the unexpected.
AnswerID: 236492
Follow Up By: Member - Rotord - Sunday, Apr 29, 2007 at 10:39
Lift distributor cap , look inside base section for a short insignificant looking lenght of wire .Check end connections for security and condition . Wire can break where it enters the crimped connectors .
FollowupID: 497649
Reply By: samsgoneagain - Sunday, Apr 29, 2007 at 12:18
make sur the rotor is turning, simple but common
AnswerID: 236578
Reply By: tommytomato - Sunday, Apr 29, 2007 at 12:19
I got it started, so far i can see that the points where not opening, the so I ajusted it so they did, then it fired up, now i need to set the points gap. any one know what the gap is, reckon I should replace with new points ?
TT
AnswerID: 236580
Follow Up By: Richard Kovac - Sunday, Apr 29, 2007 at 13:14
Should be a sticker under the bonnet, giving spark plug, points gaps & timing info, if not yours someones
Richard
FollowupID: 497669
Reply By: Member - DOZER- Sunday, Apr 29, 2007 at 18:35
Pirahna make a kit that replaces those ugly bad points with optics...half hour and never to happen again...
AnswerID: 236667
Reply By: tommytomato - Sunday, Apr 29, 2007 at 18:50
I'll be looking into that this weeks, most of the auto shops i went to today didn't have them in stock.
TT
AnswerID: 236671
Reply By: Dallas from Team Green Autogas - Monday, Apr 30, 2007 at 21:44
Hey there Tommy,
As a bit of a rule of thumb, 16thou for 6cyl's & 20thou for 4 cyl's. Normally that'll get you up & going.
Sounds like you've been in amongst it mate but hey, you came out on top!!
Get in there & have a go!!!
Dallas
AnswerID: 236994
