Trol just died..car left in town.
Submitted: Sunday, Apr 29, 2007 at 11:56
ThreadID: 44864 Views:3049 Replies:8 FollowUps:3
Well, i just finished working overnight, and hop into the car. Starts fine, gets 50m down the road, loses power and engine dies...
TD42 Nissan Diesel. My initial thought as it happened was clutch..but its not that as the engine wont restart. turns over like a trooper just wont fire.
It felt as if i ran out of fuel (loss of power, then carried on for a few seconds longer, then died), however the fuel guage still says 1/4 full (lucky me if it only guage stuck and it is empty). I caught a taxi home as I've been awake for longer than i care to remember and i wasnt going to stay in town trying to problem solve...
Am about to go to sleep...but when i wake up, and get back into town ill have to have a decent look at it.
Im thinking putting 10L fuel in just in case, bleed the fuel system and reprime, then try again... IF that doesnt work...then i need to think of something else...
Hopefully its a simple fix....its almost 10am...so goodnight. Any advice will be welcome, ill read the thread when i wake up.
Jeff
Reply By: Brew69(SA) - Sunday, Apr 29, 2007 at 11:58
Yeah sounds like a bleed should fix it.
AnswerID: 236576
Reply By: samsgoneagain - Sunday, Apr 29, 2007 at 12:15
there is a screen inside the banjo fitting on the inlet side of the fuel pump. that usually gets overlooked or forgoten about.
AnswerID: 236577
Follow Up By: nowimnumberone - Sunday, Apr 29, 2007 at 12:44
yes amazing how many of them we come across blocked
FollowupID: 497667
Reply By: Exploder - Sunday, Apr 29, 2007 at 13:01
Fuel shut off solenoid, mabey
AnswerID: 236585
Reply By: Tim HJ61 (WA) - Sunday, Apr 29, 2007 at 13:38
....It felt as if i ran out of fuel (loss of power, then carried on for a few seconds longer, then died),
It probably has - at least at the injection pump. Change your Fuel filter/s, check any filters hidden inside the inlet to the injection pump, prime it up and away you go a relieved man.
Also check your fuel lines for cracking or loose connections which will let air in - particularly when left for a while.
If you find lotsa gunge in the filter, check any water traps, drain the fuel tank - not the whole thing, just let a few litres out into a bucket and see what has settled at the bottom. Then decide if your tank needs to have a full flush and clean. A few hundred litres of BioD run through will clean it out, then you'll find how much nicer it runs and smokes less and smells better, and not go back to diesel.
Tim
AnswerID: 236592
Reply By: Member - Davoe (Nullagine) - Sunday, Apr 29, 2007 at 15:39
last time I had a disal just die the wire had busted off the shutoff solonoid - Who says 1hz are and old school motor that doesnt rely on electronics?
AnswerID: 236622
Reply By: revhead307 - Sunday, Apr 29, 2007 at 16:46
Thanks for the replies.
From your advice as well, im a little more relieved and fairly sure its just fuel related. I will head in 2mrw morning and check the above, hopefully its a simple fix.
Will let you know how i fare, once i've got to it.
Regards Jeff
AnswerID: 236641
Reply By: Richard & Leonie - Sunday, Apr 29, 2007 at 17:07
I hate getting my hands dirty. Call for road service.
AnswerID: 236646
Follow Up By: revhead307 - Sunday, Apr 29, 2007 at 17:36
Haha,
Unfortunately my RAC has lapsed, and im not going to fork out another $150 for this one incident. but yes ill sign back up sometime. Would have come in handy this morning.
As for dirty hands...ive got to take every opportunity i can, as im usually a pen pusher...so i dont mind ;-)
Jeff
FollowupID: 497724
Reply By: revhead307 - Monday, Apr 30, 2007 at 13:17
Well got back into town this morning, took some extra fuel just in case the guage was wrong.
I have a lucas CAV filter, and on inspection the viewing bowl showed only 1/2cm of fuel. (no surprise as it at least shows the engine is getting no fuel)
However, on cranking the level in the bowl does not change, i've tried the priming pump on top of the filter...cranked the engine with the bleed screw out...and the level in the filter does not change.
I have a new CAV filter insert, however i think its unlikely that its blocked to the stage of not letting any fuel through?? i have only been to the servos that i normally go to.
Are there any suggestions on what I could try. I am going to organise a tow to a fuel specialist to have it diagnosed...however i got the usual fuel pump spiel of costing $1500 - $2000 (if thats the case) which is money i dont have..
Jeff
AnswerID: 236839
Follow Up By: Robin - Monday, Apr 30, 2007 at 14:14
Friend had problem like that with Nissan 3lt - blocked filter- clean - can't prime.
Tried everthing to help- including pressurizing fuel tank , in the end I towed it at about 60kph for a while and got it going.
Robin Miller
FollowupID: 497900
