weight
Submitted: Monday, Apr 30, 2007 at 17:14
ThreadID: 44925 Views:1841 Replies:2 FollowUps:4
Hi all was wondering if you people could help me out with a weight issue.Would 1.6mm gal at 2200x1400 weigh more than 12mm ply at the same length as i am considering making drawers and as i have to take them in and out was wondering which one would be lighter.
Regards Chef
Reply By: Johnny boy - Monday, Apr 30, 2007 at 17:43
Hi Chef
I assume you mean a rectangle/ cube? frame at 2200x1400 but are there any cross bars for support/strength and are you using 1.6 gauge gal angle or RHS and what size as in 25x25 or 20x20 at 1.6 I will assume it is RHS and I think they come in about a 6 .5 mtr length so add up all the measurements that you will need for your job then call your steel supplier and ask how much the material you are going to use weighs per mtr or length then you should come up with an idea on weight ,then compare the plys weight with the same method.
I hope this helps because I had an issue not unlike yours so GOOD LUCK :)
Regards J.B.
AnswerID: 236893
Follow Up By: big fella - Monday, Apr 30, 2007 at 18:05
Hi J.B. no that is a overall size so the Sqm is 3.08m2 of 1.6 guage gal sheet or the same of ply , but the ringing of the steel supplier is a good idea.
Regards Chef
FollowupID: 497931
Follow Up By: big fella - Tuesday, May 01, 2007 at 16:03
Thanks to all that replied as someone suggested I rang the corresponding suppliers for the materials and the run down is this. For a 1200x2400 sheet of 12mm ply the weight is 19-22kg and a 1200x2400 sheet of 16# gal is 36kg .
So the out come is for the saving of 16kg a drawer I will be using the ply
Regards Chef
FollowupID: 498154
Reply By: Andrew-rodeo - Monday, Apr 30, 2007 at 19:03
The easiest way would to be get an off-cut of each cut them to the same size, grab the kitchen scales and weigh them. You should then have a starting point for some calculations...
AnswerID: 236917
Follow Up By: Johnny boy - Monday, Apr 30, 2007 at 20:48
Sorry Chef .....UM I Misunderstood your question entirely LOL
FollowupID: 498005
Follow Up By: big fella - Tuesday, May 01, 2007 at 16:04
Regards Chef
FollowupID: 498155
