4x4 diffs
Submitted: Monday, Apr 30, 2007 at 18:45
ThreadID: 44933 Views:3348 Replies:6 FollowUps:9
Hi all
Just ripped out a read housing and diff, how can I tell if its LSD or not
TT
Reply By: mrbasilbrush - Monday, Apr 30, 2007 at 19:34
Dunno ?
AnswerID: 236936
Reply By: Exploder - Monday, Apr 30, 2007 at 20:25
If is has a spring in-between the side gears and has Clutch disks fitted behind the side gears then it is LSD.
It pretty easy to tell
This is a Ford 8.8 showing the pre load spring and you can see the Locator tabs on the Clutch disks fitted into the carer behind the side gears
This is a Moroso Brute Strength LSD, you can see the heavy duty spring set in-between the gears, they also have extra Clutch disks around 10 I think
Cheers.
AnswerID: 236958
Follow Up By: tommytomato - Monday, Apr 30, 2007 at 22:59
Thank you
I'll un blot the diff from the housing over the weekend to see if it is LSD, got another front housing and diff to remove tommorow
cheers guys
TT
FollowupID: 498043
Reply By: samsgoneagain - Monday, Apr 30, 2007 at 20:50
lick it, if you start laughing and seeing colours it lsd diff man
AnswerID: 236966
Follow Up By: Bonz (Vic) - Monday, Apr 30, 2007 at 22:14
hahahahahaha blue red green hahahahah yellow purple orange hahahahaha
man I am HUNGRY what gives?
FollowupID: 498036
Follow Up By: Member - DOZER- Tuesday, May 01, 2007 at 13:00
Liquor...she'll love it :@)
FollowupID: 498122
Reply By: ross - Tuesday, May 01, 2007 at 16:38
If its that landcruiser your wrecking it will almost certainly be a LSD.
If you look on the aluminium plate on the firewall it will mention KO85 which is a LSD.
Im sure they were all LSD after 84 maybe earlier, unless they had lockers.
KO82 is an open diff you mainly see on landcuiser imports.
AnswerID: 237160
Follow Up By: tommytomato - Tuesday, May 01, 2007 at 16:43
Cheers for that mine says KO82 so it hasn't got LSD diff then ?
TT
FollowupID: 498169
Follow Up By: tommytomato - Tuesday, May 01, 2007 at 16:45
what good and bad about the K082 imports, and what do you mean about open diff, if you dont mine explaning.
TT
FollowupID: 498170
Follow Up By: ross - Tuesday, May 01, 2007 at 18:35
Nope ,no LSD unless someone has fitted one. It must be a pre 84?
For some reason nearly all landcruiser's exported to OZ had LSD after 84.
I dont know of any other country that got this.
There is nothing bad about the K082 open diff ,it just means that only one wheel on the rear axle propels the vehicle at any one time.
The LSD ,when it senses loss of traction transfers 14% of its torque to the left rear wheel. Not enough to be really useful.
There is a list of the codes here for all landcruiser diff types and ratios.
http://www.off-road.com/tlc/faq/axle.html#HD_NM_24
And the complete TLC FAQ here,slanted towards american landcruisers but still useful
Site Link
FollowupID: 498204
Follow Up By: ross - Tuesday, May 01, 2007 at 18:37
1st link not working,just go to axle codes on the other link
FollowupID: 498206
Reply By: Wayne (NSW) - Tuesday, May 01, 2007 at 19:06
TT,
If the diff was still on the vehicle the way to tell if it has any type of traction aid is to jack both rear wheels off the ground.
Release the hand brake and put gear box in neutral. Turn one rear wheel.If the other wheel turns in the same direction, there is some type of traction aid. If the other wheels turns in the opposite direction it is a open diff.
Wayne
AnswerID: 237208
Follow Up By: Barn - Thursday, May 03, 2007 at 23:46
G'day, Does the 80series, 1997, GXL have a LSD? Couple of the guys in our club think it might, but lm not sure (thought it didnt) and lve had the TLC since new.
Barn
FollowupID: 498891
Follow Up By: Steve from Top End Explorer Tours - Friday, May 04, 2007 at 00:39
Hey Barn
All 80 series rear diffs are LSD.
Cheers Steve.
FollowupID: 498898
Reply By: Wayne (NSW) - Friday, May 04, 2007 at 00:20
Barn,
It should have a LSD. There would also be a sticker on the back of the diff housing stating that LSD oil should be used.
Wayne
AnswerID: 237800
