gu turning circle
Submitted: Monday, Apr 30, 2007 at 21:48
ThreadID: 44946 Views:1753 Replies:1 FollowUps:3
Hi guys
have a gu cab chass 2004 4.2 tdi, turning to the right does not go as far as the left turn, has any one else had this problem or can any one throw any light on the subject
Reply By: Snowy 3.0iTD - Monday, Apr 30, 2007 at 22:51
On the inside of bot front wheel assemblies there is a bolt, about 10mm from memory that is not done all the way in. These bolts hit stops which limit the wheel turn. By screwing these bolts in or out you can adjust how far the wheel can turn and therefore your turning circle.
Snowy
AnswerID: 237016
Follow Up By: Member - steve F (WA) - Monday, Apr 30, 2007 at 23:32
Thanks snowy , will have a look see in the morning
Steve F
FollowupID: 498053
Follow Up By: Snowy 3.0iTD - Monday, Apr 30, 2007 at 23:35
When you start adjusting the stops, it is best to jack the front up and put the wheels on full lock to make sure you haven't adjusted things too far, otherwise the tyres will start rubbing on or even snagging the guards.
FollowupID: 498055
Follow Up By: Member - Tour Boy- Tuesday, May 01, 2007 at 10:46
Not to mention tearing out a CV
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 498106
