Site Search
Section Image
Loud Valve train at startup.
Submitted: Tuesday, May 01, 2007 at 19:57
Goldsahara
Greetings tonight,,
My 12ht motor has a loud valve train at cold start up. It lasts only a few seconds and once lubricated, operates normally, I would only like to know if this is a normal trait of that particular motor.
Thanks in advance..
Advertisement
ThreadID: 44986 Replies: 3
Views: 525 FollowUps: 3
AnswerID: 237253   Submitted: Tuesday, May 01, 2007 at 20:38
Dave198 replied:
G'day Goldsahara,
mine does not do that.
Mine has 217,000Km
Reply 1 of 3
FollowupID: 498266   Submitted: Tuesday, May 01, 2007 at 21:06
Oldsquizzy (Kununurra) posted:
Nor does mine at 412000
FollowUp 1 of 2
FollowupID: 498327   Submitted: Wednesday, May 02, 2007 at 01:10
Tim HJ61 (WA) posted:
Nor mine at 145,000
Click Image to Enlarge
12H-T on 100% WVO
FollowUp 2 of 2
AnswerID: 237268   Submitted: Tuesday, May 01, 2007 at 21:12
furph replied:
THe 2h/12ht motor is known for wear on the rocker arm tip. You can adjust the clearence but it could still be 20thou out.
The rocker shaft is probably worn in your case. A problem with dirty oil, the contamination embeds in the bushes and laps a groove in the shaft.
Pretty easy fix, but how is the hot oil pressure holding up at idle?
furph
Reply 2 of 3
FollowupID: 498507   Submitted: Wednesday, May 02, 2007 at 19:38
Goldsahara posted:
Hey furph,
The hot oil pressure idicates over half on the factory dash guage at running speeds and drops slowly to under half when slowed to idle. About a 1/4 each side.
I dont know how accurate the dash units are but i guess reasonably.
Thanks.
AnswerID: 237329   Submitted: Wednesday, May 02, 2007 at 05:28
Member - BUNDY BOY (WA) replied:
hay there ..i know this sounds silly ....try ..new oil...or maybe oil pick-ups clogged.....or Wynn's tunes up frees up sticky lifters..im not one for additives but it works
City sux . go Bush ::::::::IF YOU DONT LOVE IT HERE ::::::;;LEAVE
Reply 3 of 3
