Winches
Submitted: Wednesday, May 02, 2007 at 19:56
ThreadID: 45021 Views:2751 Replies:7 FollowUps:2
I have been looking into a winch for the 100 series cruiser.
I am weighing up either the 9000 pound or the XP 9.5.
There is a bit of a price difference, but not sure if the 9000 will be stong enough in a single line pull for the weight of the cruiser.
Reply By: Member - Matt Mu (Perth-WA) - Wednesday, May 02, 2007 at 20:19
Whats the price diff??
You can always use the snatch block for a recovery if the price diff is that excessive!!
You would never stall a 9000 on a twin line pull
Matt.
AnswerID: 237499
Follow Up By: aeiou - Wednesday, May 02, 2007 at 20:35
400 more for the 9.5
FollowupID: 498535
Reply By: Member - Davoe (Nullagine) - Wednesday, May 02, 2007 at 20:50
neither is powerfull enough for a cruiser 100. 10k is bare minimum and then you are talking double pull for a decent bog 12k would be more like it
personal experience
AnswerID: 237526
Reply By: tdf - Wednesday, May 02, 2007 at 21:11
have you considered hydraulic winches
AnswerID: 237536
Reply By: Member - 'Lucy' - Wednesday, May 02, 2007 at 22:21
Truckster is the forum resident winch expert - seek his guidance.
AnswerID: 237553
Follow Up By: Truckster (Vic) - Wednesday, May 02, 2007 at 23:36
I am? :o
I'll say my 9000 pulled the GU the other day at Dissa easily, although very slow :-s
Wouldnt mind throwing the 10,000 on but then its 30kg more + new springs for front :(
FollowupID: 498611
Reply By: Crackles - Wednesday, May 02, 2007 at 23:14
The $400 extra is not just for the 500lb extra in pulling capacity. Check the specs which will show a far superior line speed at lower power use, particually unladen which helps avoid bird caging from over run when assisting the pull by driving. The 9.5 is probably the best recreation winch for the 100 series as above that the size & weight of the winch increases allot requiring heavier front springs etc. Both will pull the Cruiser out of the majority bogs double blocked. Even the 12K Warn would struggle to pull a 100 series single blocked if seriously stuck.
Cheers Craig.....
HZJ105. 9500lb Ramsey.
AnswerID: 237572
Reply By: Tony Middleditch - Thursday, May 03, 2007 at 09:30
aeiou, First check to see if the XP 9.5 will fit into your bullbar. The winch motor is too long to fit into an 80 series ARB Deluxe bar. The XP9.5 has a 6hp motor against the XD9000 4.8hp.
On spec, weight is close to the same 40/39 Kg for the XP9.5 / XD9000.
Cheers, Tony - 80 series cruiser.
AnswerID: 237612
Reply By: Member - Mike H (VIC) - Thursday, May 03, 2007 at 14:03
G'day All.
I'm just back from 6 weeks way with tours.
Talking of winches,
has anyone heard of or has experience with the "Bushwinch"?
Bushwinch
Thanks for any info,
Mike
AnswerID: 237651
