Extended Tow Bar ?
Submitted: Thursday, May 03, 2007 at 12:32
ThreadID: 45048 Views:8371 Replies:4 FollowUps:4
Has any one else here solved this dilema. I have a hilux tray top dual cab. I cart around a small aerochute its an ultralight aero plane of sorts and the tray was custom made to extend out a further 12 inches or so to fit the plane on. Problem is the tow bar is too far under the tray now and need to get it exteneded does any one know of a towbar manufacturer that custom makes these espesially in WA ?
SARGE
Reply By: DIO - Thursday, May 03, 2007 at 15:53
I would think that any tow bar manufacturer should be able to advise you on the most appropriate course of action including manufacturing to suit your needs.
AnswerID: 237667
Follow Up By: Member - Peter R (QLD) - Thursday, May 03, 2007 at 17:22
Suggest you contact a crowd that does vehicle recovery.
They sometimes need to put vehicle on tray and tow a caravan .
Pedro
FollowupID: 498752
Reply By: _gmd_pps - Thursday, May 03, 2007 at 19:28
this is what I have on my truck
http://www.ozshops.com/P1110012.JPG
its a double receiver top 2.5" underneath 2"
have a double bar 28" extension .. my slide-on sticks out 60cm
it's not yet legalised here in WA .. I am working on that ..
I was told a shop in Vic Park should be able to do that ...
I also a working on a custom trailer with an extended drawbar
that I only need the extension when I really go tracks or off road
on road I can tow without extension with the extended draw bar ..
there is no standard solution in OZ to do that .. only flimsy Hayman Reece
low end stuff .. they only go to class IV for an extension with decent tow rating you need a class V ... so most likely a custom job and engineer certified ..
good luck
gmd
AnswerID: 237728
Follow Up By: Flight Sargent - Friday, May 04, 2007 at 17:27
Thanks for that...can you tell me where I can get an extended set up like that? You say that this set up is not legal in WA.....It may be I will need to get my campers draw bar extended that seems like an easier option.
SARGE
FollowupID: 499016
Follow Up By: _gmd_pps - Friday, May 04, 2007 at 17:30
I don't think you can buy one for a Hilux .. I got mine in the US
for a US vehicle ... Torquelift is the brand ..
I think you will need a custom job like this ..
good luck
gmd
FollowupID: 499018
Reply By: arewelost - Sunday, May 06, 2007 at 23:03
hi
i realise i am a few days late with a response i am in perth if you go and see the vehicle engineering section in mount street perth they will be able to give you all relevant information required this is the same dept that gives permits for vehicle modifications makes it all legal
cheeers steve
AnswerID: 238310
Reply By: Graham & Ann - Sunday, May 13, 2007 at 20:07
Wow at a quick glance I'd think those extended tow hitch receivers certainly could cause some issues with stability especially if there was any sort of ball weight involved, (ie much less weight on the front wheels for braking steering, more prone to be affected by winds etc.) the further back from the rear axle you have the tow ball the more instability would most likely be the result. Maybe much much safer to get the A frame extended to suit the vehicle.
AnswerID: 239781
Follow Up By: _gmd_pps - Sunday, May 13, 2007 at 20:28
It's all a matter of the vehicle .. surely with a pathfinder the extension is killing it ...
I can tow 3.5t at 28" extended and don't even feel it ...
have fun
gmd
FollowupID: 500762
