Gear Box
Submitted: Thursday, May 03, 2007 at 18:58
tommytomato
Hi all
Got a FJ60 5 speed box to remove very soon, how do you remove the main gear stick ? all i see are two ( unsure ) like pop rivets on either side of the stick.
Hope some one gets what i mean, I want to be able to remove the motor and gear box in one hit, then remove gear boxx and housing from motor.
TT
Reply By: Peter 2 - Thursday, May 03, 2007 at 19:04
Push down on the tin cup shaped bit that surrounds the bottom of the gearstick in the top of the gearbox and turn it. Those two lugs go through into the centre and act like the bayonet fitting on a light globe.
237717
Follow Up By: tommytomato - Thursday, May 03, 2007 at 19:19
Thank you Peter
TT
498787
Reply By: texas - Thursday, May 03, 2007 at 19:06
Hi tt If you remove the rubber boot you will see a half ball shape at the base of the gearstick if you depress thiss and rotate anti clockwise it willrelease the gearstick and bobsyouraunty cheers. Texas
Darwin N.T.
237718
Follow Up By: tommytomato - Thursday, May 03, 2007 at 19:20
Thanks texas, I will try that tommorow
TT
498788
Reply By: tommytomato - Thursday, May 03, 2007 at 19:29
Bugger tommorow LOL, thanks it worked, is it best to remove the 4x4 stick linkages before removing the motor and gearbox ?
TT
237729
Reply By: Peter 2 - Thursday, May 03, 2007 at 20:50
Yes it will make it a little easier
clearing stuff as you lift the engine and trans out the front.
237752
Reply By: Alan H (Narangba QLD) - Friday, May 04, 2007 at 19:45
Don't lose the washer that is under the ball part of the gear lever.
Maybe good idea to replace it (20c)
I had one which disintergrated on me and lost the gears. It holds the gear lever up at the critical height for the gear shift to work.
237931
