Jeep Saga continues!!
Submitted: Thursday, May 03, 2007 at 19:54
Member - Axle
This Day to-night, is still on about Jeeps getting a bit hot!!. Another one went up evidently, The media is a chit at times , Give the company a little bit off space to rectify a problem and admit liability if necessary. Its not the first time this sort of incident has happened over the years with different makes and models of vehicles.
> VWs The fuel pump hanging over the exhaust manifold
If the little absorption tray failed underneath, instant Fire.
Tin battery covers millimetres off the terminals, a build up of acid and hey presto another fire!! .
Xe falcons had a steel fuel line from the fuel pump to within 70mm of the carby & then changed to a rubber hose, for flexibility i suppose, trouble was as age & fatigue came along it would crack and spray fuel all over your lovely hot motor.
Subaru!!! of all cars, know what I'm on about hear, have had it happen on my own, They use those stupid spring clips which are pre tensioned ( the ones you close the ends together to open up) The trouble is if the fuel hose shrinks or goes hard they leak!!, on ours the outlet one on the fuel filter sprung a leak and sprayed a mist of fuel all over the alternater, Potential dasaster.
Landrover and electrical faults , Been a few discoveries go up in smoke.
I know a sales rep who was driving a merc down the freeway, next minute the thing stopped, white smoke every where, he bailed out just in time ,and watched it burn to a crisp!.
So i guess it can happen to any bloody thing really, Ijust think its only fair for a please explain! before the knives go in.
My thoughts only
Cheers Axle.
Reply By: Member - DAZA (QLD) - Thursday, May 03, 2007 at 20:20
Hi Axle
I know a fellow who had trouble starting his tojo on cold mornings, so he
decided to leave an old sugar bag on top of the motor, thinking it would keep
it warm, the only thing is, he forgot to take it of, it got warm all right when he was
driving to work, the fire brigade had to put it out, before they took it to the
wreckers.
Daza
237744
Follow Up By: Member - Axle - Thursday, May 03, 2007 at 20:30
HaHaHA,! At least he didn't blame Toyo, or did he?.
Axle.
498802
Follow Up By: deserter - Thursday, May 03, 2007 at 20:39
Saw an engine bay fire once where a backpacker had stored his sleeping bag in the engine
well of the hire car. Some people eh.
498807
Reply By: blue one - Thursday, May 03, 2007 at 20:34
What about car gearbox oil boiling and spitting onto the exhaust. Oil creates fire fire heats gearbox more oil feeds fire.
Boom Bada Boom
237747
Reply By: Member - Michael J (SA) - Friday, May 04, 2007 at 11:54
Hi Axle,
Confession time.....
It certainly can happen at any time.
Years ago I had a you beaut Austin Healy 100/4, pride and joy but..
decided to clean the engine with a fairly potent mixture, can't remember exactly what I used but suffice to say it was very flammable.
There I was spraying away and cleaning when OOPS shorted out the starter solenoid with
the tip of the spray gun.......big spark and instant fire.
Was at an airport at the time and fire persons attended real quick, but heaps of damage of course.
Lesson..disconnect batteries. As a form of defence for stupidity the batteries in that car were in a box tucked behind the seats......out of sight out of mind:((
Michael
237855
Reply By: Member - Toytruck (SA) - Friday, May 04, 2007 at 12:56
Nup,
I'm convinced that Jeeps are a lethal dangerous weapon that are a threat to mankind........cos the chick on the tele said so:-)
Toytruck
237862
Reply By: djm67 - Monday, May 07, 2007 at 11:33
Remember triple carbs on early Torana's?
Backfire = under bonnet fire
Saw many driving around with scorched bonnets
238360
