how?
Submitted: Tuesday, May 08, 2007 at 19:21
hiab
how can i put a pic on here? tried the suggested path but nothing, anybody?
Reply By: Rock Ape - Tuesday, May 08, 2007 at 19:34
yep
from your other posts, just being sarcastic should work.
The Ape
238634
Follow Up By: hiab - Tuesday, May 08, 2007 at 19:36
never was a person more aptly named.
499697
Follow Up By: Redback - Tuesday, May 08, 2007 at 19:47
You have to use this thingy at the bottom when you decide to type your post there are thing called hyperlinks
there is a specific one for images, you copy the image URL and put in between these img src= "url goes here but use all of what is before and after" don't forget to put these things at the start and end
499699
Follow Up By: Redback - Tuesday, May 08, 2007 at 19:49
I hate this setup make it hard to explain
499700
Reply By: Rock Ape - Tuesday, May 08, 2007 at 19:44
Well there you go again, should put a handle in the middle of your back and call you suitcase
you can't be all that smart if you are trying to out smart a dumb ape
The Ape
238637
Reply By: Redback - Tuesday, May 08, 2007 at 20:34
hiab are you a member of any other
forum?
If you are pick one
i'm a member of
outerlimits
overlander
4wdmonthly
australia4wd
4wdcentral
and a few more if your a member of any of these, pick one and PM me i'm Redback on all of them and i'll explain it properly.
sad i know, but hey who cares.
Baz.
238658
Follow Up By: hiab - Tuesday, May 08, 2007 at 20:38
thank you baz, but as old groucho said," i wouldnt care to join a club that would have me as a member", so not member of anything.
499722
Follow Up By: Willem - Tuesday, May 08, 2007 at 21:09
Yes, sad Baz, very sad.......................hahahahahaha
Cheers mate
499731
Follow Up By: Redback - Wednesday, May 09, 2007 at 17:09
Thanks mate i knew you would understand, lol
Gotta dosomething to keep me occupied at work...;-))
499881
Reply By: Hairy - Tuesday, May 08, 2007 at 21:01
Go to photobucket.com/ and set up an acount.
Then go to post.....PostID: 44692 Exploder explains to me how to do it easily.
238671
Reply By: Steve from Top End Explorer Tours - Wednesday, May 09, 2007 at 16:27
Try this.
www.bcl.org.au/ - 7k -
238829
Follow Up By: Bware (Tweed Valley) - Wednesday, May 09, 2007 at 16:57
LOL
499877
