Oziex instruction manual
Submitted: Wednesday, May 09, 2007 at 13:34
ThreadID: 45261 Views:2488 Replies:4 FollowUps:4
Is there an instruction manual for this program?
This is the first program I came across without instruction manual.
It maybe ok going thru the menus but a manual will help with some of the tricks and tips.
I-mate
Reply By: Red Frog - Vic - Wednesday, May 09, 2007 at 14:30
try the help section, it's very good.
AnswerID: 238815
Follow Up By: The Explorer - Wednesday, May 09, 2007 at 14:40
Yes the Ozi PC or CE help file is your best option (AFAIK) and is certainly very comprehensive. I printed it out the PC version help in 2001 - there are no page numbers but it is very thick - 2cm high A4 book with double sided printing. It is a pain to print out unless you print to PDF using Adobe and use print all links (the help file is web format..or whatever you call it)..then print to paper. I would email a finished product but cant find it - if you cant do it yourself email me and Ill have another bash tonight (trying to work now:(
I have the Ce version help file in PDF - will email that which should help a bit...and I supsect taht is what you are actually after anyway.
FollowupID: 499849
Follow Up By: Member - Andrew (QLD) - Wednesday, May 09, 2007 at 14:44
Damn it's annoying to type something only to find others have said the same thing 2 minutes earlier :-)
FollowupID: 499851
Follow Up By: The Explorer - Wednesday, May 09, 2007 at 14:47
What the hell - the more the merrier - at least he knows we're not lying:)
FollowupID: 499853
Follow Up By: selasticman - Wednesday, May 09, 2007 at 16:17
FollowupID: 499869
Reply By: Member - Andrew (QLD) - Wednesday, May 09, 2007 at 14:42
The help section IS the manual essentially....it contains a good tutorial for the beginners as well as some good details.
Even though the help file is getting a little out of touch with respect to the updates, it is none-the-less useful, and one of the better help files for any program.
Another option is to print the help file to a PDF file (requires acrobat or similar software) and then print out the subsequent file. I tend to do this and have a paper manual then albeit rather large.
Hope this helps
AnswerID: 238817
Reply By: I-Mate - Wednesday, May 09, 2007 at 15:15
Thanks everybody. I would expect an instruction manual for a program I am paying for. this will do for now.
AnswerID: 238823
Reply By: Oldman - Wednesday, May 09, 2007 at 23:56
Hi GPSOZ runtraining courses. I have not attended one so can't say how good but may be worth checking out
www.gpsoz.com.au/training.htm
AnswerID: 238979
