3.0 Nissan clutch saga........ Advice needed
Submitted: Friday, May 11, 2007 at 17:55
Member - Luke (SA)
Today at work we went to change the clutch in my brothers Patrol when we found out we have to pull the bloody whole motor out just to do it. (NOT KIDDING) even the workshop manual says so. What a bloody joke. You would think that Mr Nissan would make these things a bit more user friendly wouldn't you??
Undid all the bolts and nuts to remove the gear box and found that the bellhousing will not go back far enough as it hits on the fire wall.
Has anyone changed a clutch in one of these before and what are we up against.
Is there an easier way???
Cheers Luke
Reply By: Member - Axle - Friday, May 11, 2007 at 18:27
Someone on here was on about that, a few months ago with a GQ , might pay to do a search, from what i remember there is a way of turning the box to get it out.
Not much help i know, but hope all goes
Axle.
239336
Follow Up By: Willem - Friday, May 11, 2007 at 18:47
GQ 4.2lt box comes out easy(especially when someone else is doing the job...lol).
BUT you need a vehicle hoist and a gearbox stand. Yes the gearbox is turned as it pops out. It is also probably the heaviest gearbox around.
The 3 lt box is different, methinks
500343
Follow Up By: Leroy - Friday, May 11, 2007 at 19:39
Same box Willem, I big heavy hunk of metal! 2.8 has a lighter box.
Leroy
500352
Follow Up By: Member - Roachie (SA) - Friday, May 11, 2007 at 19:54
Got a funny feeling that Luke is referring to a GQ with an RB30 engine. Not sure though.
The GU's gearbox certainly should be able to be pulled (dropped??? OUCH) out without the need to remove the donk.
500357
Follow Up By: Member - Borgy.. (SA) - Friday, May 11, 2007 at 20:18
No Bill he is actually refering to a 3litre TD GU Patrol...you know the ticking time bomb ones ....haha.......It belongs to my oldest son and he has given Luke and his other brother Shane the pleasure of doing the job for him ..lol....Suckers
Cheers ......Dave
500367
Follow Up By: blue one - Friday, May 11, 2007 at 20:30
Leroy,
Had a 3ltr now have a 4.2ltr, definitely not the same gearbox.
500371
Follow Up By: shane adelaide - Friday, May 11, 2007 at 20:57
yep im the sucker that has to change it lol change a clutch in a 4by easy i thought
well i thought wrong not so easy lol
500380
Follow Up By: Member - Roachie (SA) - Friday, May 11, 2007 at 21:15
Sorry blokes.....my mistake. (I thought you blokes, Borgy, Shane and Luke, would have shown him the error of his ways by now and convinced to get a 4.2...hahaha
Strewth, I'm glad you blokes have plenty of upper body strength; cos the gearboxes in these 'trols are as heavy as Bill
Gate's wallet!!!!
Good luck!!
500385
Follow Up By: Member - Roachie (SA) - Friday, May 11, 2007 at 21:16
BTW, I have a
Gregory's workshop manual and one of those ones on CD Rom if you'd like to borrow them......
500386
Follow Up By: Member - Luke (SA) - Friday, May 11, 2007 at 23:37
Roachie, Sorry mate I should have said it was a GU 3.0.
Thanks for the offer Bill but I think we should be right.
Well we are always trying to drum it into his head that one day he will be driving down the road and all of a sudden he will hear......... TICK.........TICK..........TICK..........TICK........... "lights out" BANG
500428
Reply By: 120scruiser (NSW) - Friday, May 11, 2007 at 21:48
Pull the transfer case off the box.
Remove the exhaust at the turbo.
Remove the drivers side engine mount and you can get the box back far enough to remove the clutch and pressure plate. The box will then drop down. Remove the flywheel and throw it at your nearest enemy and replace it with an exedy solid flywheel conversion.
It is a bit challenging but you can do it. We do them in a day in our workshop but thats with the correct lifting gear. If doing it at home, best of luck as they are heavy and hard to twist when you are lifting them. We use a
seat belt strap on a crane through the door as the strap allows the box to twist a bit easier.
Hope this helps
120scruiser
239406
Follow Up By: shane adelaide - Friday, May 11, 2007 at 22:08
thanks 120scruiser luke and i have our own tyre business and do a bit of mechanical work as
well so have all the equipment needed will give it a go and see how we go will keep you all posted
cheers.....shane
ps thanks for the offer roachie have borrowed a workshop manual from the deisel mechanic next door but cheers anyway
500408
Follow Up By: Member - Luke (SA) - Friday, May 11, 2007 at 23:20
Thanks for the advice 120cruiser sounds like you know what your doing. As Shane has said above we have a work
shop with a couple of hoists.
Cheers Luke
500424
Follow Up By: 120scruiser (NSW) - Sunday, May 13, 2007 at 22:43
Patrol Stuff
500817
Reply By: Fatman - Friday, May 11, 2007 at 22:05
The easiest way to do it is to just pay someone ...surely if ya own one of these boom boom vehicles ya must have heaps a money Bro....The Fatman
239414
Reply By: jon p qld - Saturday, May 12, 2007 at 07:26
G'day Luke
I've removed several of them with the correct gear, ie. heavy duty transmission jack, the box needs to be turned 45 degrees to the right as it comes out otherwise the starter motor locater in the bell housing will foul on the body. As others have said it is a very heavy and awkward box to remove.
Jon
239471
