Suspension Change.
Submitted: Saturday, May 12, 2007 at 07:05
Wayne (NSW)
One of the things on the "TO DO List" before I head off was to change the
suspension on the Troopie.
No big deal, picked
the springs, shocks, bushes, shackles and pins. I am doing it at home in the driveway and thought it would take 3 to 4 hours. It has been a while since I have changed the full
suspension on a vehicle so I would take my time.
5:30 last night I had just finished the rear springs only.
What had happened the pins on the front of the rear spring had frozen solid. I could not remove the pin and there was no rotation between the spring bush and the pin. This could have meant that the main leaf could have broken due to metal fatigue while driving over corrugations.
The first spring took hours to remove, I was trying to save
the springs. In the end I used the angle grinder an cut the spring off and was able to slide the pin and the end of the spring out through
the big hole in the spring bracket. The other spring was the same, frozen, but didn't take as long to change as I already knew what I had to do.
When I ordered the new
suspension I had also ordered new greaseable pins and shackles. This should stop the frozen pin problem in the future. The front being coils it should not cause too many problems to day, I hope.
Wayne
Reply By: Willem - Saturday, May 12, 2007 at 08:26
Wayne
The older you get the longer it takes...lol
I guessed that removinmg the old tin from the garage roof would take 2-3 hours. It ended up taking 3 days.
Same goes with mechanical stuff. These days I save up and get a mechanic to do the hard yard.
239487
Reply By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 09:25
Wayne
You must like being punished, I took
mine into ARB at
Rockhampton to have the front done with OME, sat and watched a DVD, in about 2 hours I was on the road, 6 weeks later I was back in
Rockhampton for the rear , same again , 2 hours of relaxation and job was done, I guess when you have a hoist and air
tools makes a job a lot easier,the old fire stick goes a long way too ,
Have Fun and skun knuckles
Doug
239495
Follow Up By: Wayne (NSW) - Saturday, May 12, 2007 at 09:56
Doug,
The pins in the 75 Series are different to the 78 Series so I have found out. The 78 Series has a steel pin and steel bush surrounded by a rubber bush. When they are frozen together the only way out was to cut.
The pin and bush that I am replacing it with is like the set up on the 75 Series, pin and bush.
Wayne
500472
Follow Up By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 09:58
Yeh and you can bet the 70 series will be different again .....
500473
Reply By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 10:01
Wayne
I meant to ask you , what brand of spring did you buy , and make sure you have the right tool for the coils , ie a CLAMP.........BOINNGGGG........OUCH
239507
Follow Up By: Wayne (NSW) - Saturday, May 12, 2007 at 10:14
Doug,
TJM supplied
the springs, shocks and bushes and with the front coils there is no need to compress.
Vehicle on axle stands,
wheels off, remove front sway bar, remove shocks, lower front diff housing via trolley jack and
the springs will just about fall out. Putting new front springs in can be a little harder being a bit longer but with a little brute force they will go in.
Wayne
500478
Follow Up By: 120scruiser (NSW) - Saturday, May 12, 2007 at 10:27
Once your done drop down with the beast and I will check the wheel alignment on it for you Wayne.
The new front coils will probably be the same length as the standard ones, just bigger.
Scott
500483
Follow Up By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 10:35
120scruiser
You won't believe this but after replacing springs, and later steering knuckles by me,I measured with calipers and counted the threads on the old one before removal. I have never had a wheel alignment done, it drives straight, feels ok and I don't get uneven tyre wear, must be lucky eh,
Doug
500485
Follow Up By: 120scruiser (NSW) - Saturday, May 12, 2007 at 14:24
I can believe that Doug
I have done a few and alot don't need adjusting at all.
It still pays to check as tyres are expensive to scrub out.
Scott
500519
Follow Up By: Wayne (NSW) - Saturday, May 12, 2007 at 20:00
Doug,
Front coils just about fell out, and the new ones fitted in as easy as the old ones came out.
Wayne
500569
Follow Up By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 20:48
Wayne
Thats good , one you don't need is a coil spring smack in the face .
Doug
500577
Reply By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 10:27
TJM eh, is that the series 2000 set, probably will serve you
well and you won't know your in the same 4x4 when you get rolling, .......................................
Just that when I mentioned to the bloke who runs the TJM store in town South of
Townsville that I had bought OME his answer was I did the right purchase, and that was only because TJM couldn't do it on 5 mins notice and ARB did ,
I'm not knocking your choice, probably just as good , you will be in a position to keep us all informed on how they go, look out for the wild coil on the loose....lol
239509
Follow Up By: Wayne (NSW) - Saturday, May 12, 2007 at 10:35
Doug,
I have not had a problem with the TJM
suspension. I have sold and fitted the
suspension, when I had the TJM
shop in Penrith, and it is not that bad.
Wayne
500486
Reply By: Member -Signman - Saturday, May 12, 2007 at 19:35
Wayne
Where you ' looking' at TJM - Narellan??
239583
