Slightly OT - Pulleys
Submitted: Monday, May 14, 2007 at 17:57
ThreadID: 45471 Views:2025 Replies:6 FollowUps:5
I know its slightly off topic, but I am after some pulleys (preferably aluminium) about 80mm - 100mm (or 3-4 inches) in diameter. Does anyone know of any suppliers? Blackwoods stock ones with a v-shaped groove and I am ye tto contact them, but can anyone suggest another supplier?
cheers,
Sam.
Reply By: crfan - Monday, May 14, 2007 at 18:05
Hi Sam, Most bearing supplies will stock them.
AnswerID: 239963
Follow Up By: Peter 2 - Monday, May 14, 2007 at 19:09
Was just going to suggest that bearing places usually have them, also engineering supplies, where are you located?
FollowupID: 500946
Follow Up By: Member - Sam (NSW) - Monday, May 14, 2007 at 19:36
I'm in southern Sydney Peter.
I've tried one or two local engineering supplies, but one place only had larger steel pulleys. I only need a smaller light weight one
FollowupID: 500949
Follow Up By: Peter 2 - Monday, May 14, 2007 at 20:24
Our local (hornsby) North Shore bearing supplies has a big range of the alloy ones with the pink/maroon centres as does the local engineering supplies.
Try Coventry at Alexandria. Bourke rd from memory.
FollowupID: 500964
Follow Up By: Member - Sam (NSW) - Monday, May 14, 2007 at 20:28
Thanks Peter,
i'll give them a buzz tomorrow.
Trying to make an aerial camera crane.
FollowupID: 500965
Reply By: crfan - Monday, May 14, 2007 at 19:36
Hi Sam I am In WA, also ag supplies will have them as well.
AnswerID: 239983
Reply By: Member - andrew B (Kununurra) - Monday, May 14, 2007 at 21:29
Gday Sam
Also worth a look would be a boat shop - they have them for the old style of steering, came in a few sizes....yachts also have all sorts of pulleys etc as well so they may be of some help
Cheers Andrew
AnswerID: 240031
Follow Up By: Member - andrew B (Kununurra) - Monday, May 14, 2007 at 23:33
just had a bit of a look at an old bias boating catalogue, heaps of pulleys etc there
FollowupID: 501025
Reply By: Eric Experience - Monday, May 14, 2007 at 22:01
Sam.
Some Exercise machines use glass reinforced plastic pulleys about that size, stronger than aly, look for them in your local hard rubbish collection. Eric
AnswerID: 240042
Reply By: joc45 - Tuesday, May 15, 2007 at 12:39
Can't give a supplier, but fyi, altho it depends on the amount of use you are giving them, steel V-pulleys give a lot better life than the ally ones, which tend to wear out quickly.
Gerry
AnswerID: 240117
Reply By: selasticman - Tuesday, May 15, 2007 at 14:28
Try power steering pump pulleys, wreckers would have heaps and different sizes too.
dave
AnswerID: 240137
