80 series not wanting to accelerate
Submitted: Sunday, May 20, 2007 at 16:09
Diver1
our 80 series (279,300km) isn't wanting to accelerate when its cold and gets what seems to be a lag, motor also sounds different too when its running like this....doesn't sound as smooth. sounds a bit raw. what would be causing this and hows it fixed? would it be a fuel pump ?
also gotta do bearings this week -pulley bearings???
laura
Reply By: Steve from Top End Explorer Tours - Sunday, May 20, 2007 at 16:27
Hey
Laura
When was the oil changed last? As when the oil breaks down in a diesel it tends to sound a bit raw as you put it.
No the bearings are not pressed so no pulley required.
The best wheel bearing grease to use is Morrey's Big foot EP2, Its not cheap but it's the best on the market, Its a bit messy to use as it's as sticky as baby poo.
Don't forget to replace the axle seals, it's a fun job as I have just done 2 trucks with 1 to go.
Hope this helps.
Steve.
241194
Follow Up By: Diver1 - Sunday, May 20, 2007 at 16:32
just got oil change so thats not it....just had a bit if a look at lcool....matrix build up on injecters....needs "hot flush".....so i wonder what they charge for thar sorta thing...
laura
502091
Follow Up By: disco driver - Sunday, May 20, 2007 at 19:55
Would have thought that an 80 series would be be old enough to have it's own "hot flushes"
Disco
502140
Reply By: Kev M (NSW) - Sunday, May 20, 2007 at 16:29
Is the extra weight now that you have a new bullbar and winch LOL
Kev
| Russell Coight:
241195
Follow Up By: Diver1 - Sunday, May 20, 2007 at 16:34
well could be but no winch in...maybe ive git a few of mums bricks under the bonnet still,,,lol
no new 4b for you yet???
laura
502093
Follow Up By: Kev M (NSW) - Sunday, May 20, 2007 at 16:41
Not yet, still trying to find the one I'm after.
Mind you I've looked at close to 30 ATM.
Kev
| Russell Coight:
502095
Reply By: Member - DOZER- Sunday, May 20, 2007 at 16:59
Change your fuel filter as a starter...clean the inlet filter, put some diesel conditioner in it if you dont usually...and if all that doesnt work, light an old diesel rag and throw it under the sump in the mornings to warm her up :)
241203
Follow Up By: Diver1 - Sunday, May 20, 2007 at 17:10
good idea but aint diesel....its petrol / lpg. the filter is top of the list but im thinking we're due to do something to it that costs a bucket load....lol....
laura
502104
Follow Up By: Member - DOZER- Sunday, May 20, 2007 at 19:31
In that case, check air filter and valve clearances.
502132
Reply By: nowimnumberone - Sunday, May 20, 2007 at 17:20
is it efi or carby?
what engine 3f or twin cam?
241206
Follow Up By: Diver1 - Tuesday, May 22, 2007 at 20:31
nowimnumberone -
efi 4.5lt twincam...
Laura
502609
Reply By: Dallas from Team Green Autogas - Sunday, May 20, 2007 at 21:45
G'day Diver1,
Does it do it on both fuels (LPG & Petrol) or is it specific to 1 particular fuel source. This will narrow it to a fuel supply problem or engine tune etc.
Keep in touch
Dallas
241276
Follow Up By: Diver1 - Tuesday, May 22, 2007 at 20:30
Hi Dallas.......Had it on Petrol when it was happening lately, filled in with lpg yest and hasnt done it since.....
Laura
502607
Follow Up By: Dallas from Team Green Autogas - Tuesday, May 22, 2007 at 20:57
Hey G'day
Laura,
So it sounds like it's a fuel delivery problem specific to Petrol (as long as it's not simply having a good run).
I don't think it'll be anything related to the fuel pump as it simply pumps when powered & isn't relevant to engine operating temp.
If it's carby then check the plate height on the mixer.
If it's EFI then that's a whole different kettle of fish.....
When you are running on LPG you are actually bypassing alot of the vehicles sensors so if they are giving you grief, you will mainly experience it only when on petrol. There isn't that many sensors in the system really. Air Flow Meters / Air Mass Meters are usually what gives trouble most of the time. This tells the cars computer how much air is going into the engine & the computer calibrates the Petrol Injection accordingly so if the AFM is giving the wrong info then the engine will have the wrong amount of Petrol being delivered so it'll run poorly. Apart from that you have the Throttle Position Sensor which is also used by the gas in most systems so would effect both fuels or the coolant temp sensor which the cars computer uses to know how to calibrate the Petrol delivery. In all honesty i'd be surprised if it was giving you trouble. It's not impossible but they very rarely play up.
I'd be checking the Air Flow Meter / Air Mass Meter (whichever it has) 1st off the rank. If it comes up ok then go further with other sensors.
Keep In Touch
Dallas Green
502621
Reply By: Dallas from Team Green Autogas - Saturday, Jun 02, 2007 at 18:52
Hey
Laura,
Got it figured yet???
Dallas Green
244217
Follow Up By: Diver1 - Saturday, Jun 02, 2007 at 21:36
Changed fuel filter but havent had the chance to run her really cold on petrol but i think prob is kinda solved, for now....got a pretty big gear box leak and there's oil coming out of motor too....aaahhhh...never ending !!!
Going to run some injector cleaner in it and give her a clean out...
When its cold, and its down this for ages, (on lpg) it doesnt like accelerating and almost stalls but comes good if you stop accelerating and then try to get going...just another one of those things that you never think of fixing except for when it happens first thing in the morning!!
Laura
505219
Reply By: Dallas from Team Green Autogas - Sunday, Jun 03, 2007 at 15:13
Laura,
LOL.... in amongst it by the sound of it.
Let me know if there's anything i can do to help.
Kind Regards
Dallas Green
244376
