Damp Mattress Problem
Submitted: Monday, May 21, 2007 at 20:53
cavvy
We have a Windsor Rapid, probably same problem with other mfgs, and have found that after a few nights of sleeping that the bottom of the mattress is quite damp due to no air circulation. Has any member got any suggestions as how to remedy the problem
Reply By: Harry - Monday, May 21, 2007 at 21:11
G'day,
Not sure what a Windsor Rapid is, but depending on the weather conditions, most mattresses will be damp underneath when it is cold outside.
We find this even with close cell foam hikers mats under as
well, and we use 2 50mm foam mattresses each and it's only the bottom 1.
Most people wouldn't know the damp is there if they're not aware of it happening.
Don't take long to dry out.
241475
Reply By: chips59 - Monday, May 21, 2007 at 21:24
i also have the windsor rapid and have never had tis problem, have you got the plastic up around the bed properly?
241481
Follow Up By: cavvy - Wednesday, May 23, 2007 at 15:58
Thanks for all the input. It seems that I need to raise the mattress a little and get some air circulation to be able to rectify the problem
502816
Reply By: Member - Uncle (NSW) - Monday, May 21, 2007 at 21:27
If you have a look at www.caravansplus.com.au and look in the bedding accessories section and you'll see the Hypervent bedding underlay, that should fix it. Cheers.
241484
Reply By: Peter 2 - Monday, May 21, 2007 at 21:37
A much cheaper way to vent it is a couple of layers of shadecloth under the mattress, much cheaper than the Hypervent stuff and works just as
241488
Reply By: Wayne-o - Tuesday, May 22, 2007 at 01:19
Perhaps a couple less beers before bed time.....lol
241494
Reply By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 09:41
Stop wetting the bed
241534
Reply By: Ole Grizzly - Tuesday, May 22, 2007 at 10:39
We had similar problems in the Army..we did an easy fix by using a newspaper underneath..actually draws out the moisture from the mattress. In the morning just put the paper into the recycle bin and replace it with the read daily paper.
241547
Reply By: Hairy - Tuesday, May 22, 2007 at 12:27
Nappy's
241564
Follow Up By: Graham & Lynne - Tuesday, May 22, 2007 at 19:50
If mattress on one solid piece of ply use hole saw & drill series of 50mm holes in ply toallow air circulation.
cheers Graham
502586
Reply By: Auntie - Wednesday, May 23, 2007 at 23:14
We have a Jayco Dove, and the pull out beds are made of heavy ply, probably 5 ply or more. Underneath the mattress are 3 lengths of ply, about 1 metre by 20cm.just scatteres randomly so as to leave air gaps. Never have any moisture problems. Another good point. I spoke to someone recently who had a similar van and decided to varnish the bondwood extendable bed bases to protect them and look good. Straight away got moisture problems. Apparently the timber needs to breath, and the varnish prevents this. All the best.
241962
