Oziexplorer - additional maps
Submitted: Saturday, Apr 26, 2003 at 16:23
ThreadID: 4574 Views:1720 Replies:3 FollowUps:1
Hi Everybody,
I have just got used to my Ozieplorer software and using the maps provided by Natmap ( 1:250,000 scale topographic maps). I was curious as to whether anybody out there has downloaded maps of the larger cities throughout the country.
I would appreciate your feedback on the calibrating function or some direction in where I can get digital images (maybe?).
Looking forward to your reponses.
Reply By: joc45 - Saturday, Apr 26, 2003 at 20:35
HI Andrew.
Check the OziExplorer web page, http://www.oziexplorer.com/ if you haven't already done so. There is a section there on maps available in Aust, with appropriate links. The Perth MSD on CD, for example works fine on Ozi, calibration files downloadable via the Ozi website.
You can of course scan your own maps if you have the patience of Job. I have done the whole of the SW of WA on 1:50k, since I can't afford (read unwilling) to buy them (already had the paper maps tho). Understand that other states have these higher res maps at more reasonable prices.
Ozi also tells you how to do your own maps, incl stiching A4 scans back to full-size.
rgds
Gerry
AnswerID: 18417
Reply By: Truckster (Vic) - Saturday, Apr 26, 2003 at 23:01
There is also a yahoogroup on Oziexplorer www.yahoogroups.com and search for it.
AnswerID: 18446
Reply By: Member - Topcat - Sunday, Apr 27, 2003 at 21:11
Have found with scanning maps, using a single pass flatbed scanner is to set your resolution setting (dpi) low enough to scan the map in none contiuous pass, otherwise errors will occur when calibrating due to the distortion effect when the scan stops & starts several times during the pass. Around 120 dpi works ok.
Cheers.Have Wheels Will Travel
AnswerID: 18529
Follow Up By: Member - Topcat - Sunday, Apr 27, 2003 at 21:13
That was one continuous pass of the scanner. My typing is R.S.!! tonight.Have Wheels Will Travel
FollowupID: 11573
