Steering hard with Lokka (front end)
Submitted: Tuesday, May 22, 2007 at 12:42
ThreadID: 45751 Views:6669 Replies:12 FollowUps:25
G'day all, I took a snipet from another thread cos I'd like to know the answer aswell.
Frankl wrote "One other question: With the front hubs locked and in 2wd, I still found it difficult to steer. I think i know why its hard but I just need someone to confirm its perfectly normal with the lokka when not in 4wd? "
Phill
Reply By: Member - Troll 81 (QLD) - Tuesday, May 22, 2007 at 12:56
Well when you have the lockers on it locks the diff so both wheels turn at the same rate
AnswerID: 241571
Reply By: Batman69 - Tuesday, May 22, 2007 at 13:16
Phill,
I think this is the answer but not 100% sure - The lokka requires torque from the axle being driven slower (I think) to unlock the differential. When the vehicle is in two wheel drive this torque is not present, therefore the diff doesn't open and is harder to steer.
Batman.
AnswerID: 241580
Reply By: disco driver - Tuesday, May 22, 2007 at 13:59
Ford Rodeo,
The way I understand it doing that, running with hubs locked and a Lokka fitted in 2wd, to be safe.
Disco is a sure way to destroy something in the front diff/axle area, particularly on bitumen.
Take the hubs out
AnswerID: 241585
Follow Up By: disco driver - Tuesday, May 22, 2007 at 23:47
Stuffed if I know what happened to that, it's nothing like what I typed in.
This is the correct version:
The way I understand it doing that, running with the hubs locked and a Lokka fitted in 2wd, is a sure way to destroy something in the front diff/axle area, particularly on bitumen.
Take the hubs out to be safe.
Disco
FollowupID: 502703
Follow Up By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 11:29
Your left hand has no idea what the right hand is doing
FollowupID: 503454
Reply By: Member - Bruce and Anne - Tuesday, May 22, 2007 at 14:18
Ist up I have a Lokka in front diff of my MU, never tried driving it with hubs locked in 2WD. But in 4WD it is a bit tighter but with power steering its not a problem, 60ks on the beach in 4WD good as gold. Is that what your asking Phill?
Cheers Bruce
AnswerID: 241588
Reply By: F4Phantom - Tuesday, May 22, 2007 at 14:22
With the front hubs locked you have no drive to the front but you still have the wheels locked together. In this situation the prop shaft turns freely and so the wheels remain locked, for them to unlock you need the prop shaft to be locked up so the locker has something to push off. If the car was in 4x4 the locker would unlock as the outside wheel would freewheel faster than the inside driven wheel and the steering would lighten up. For the locker to unlock you need one wheel and the propshaft joined and then the other wheel to be rotated faster like in the outside of a corner.
AnswerID: 241589
Follow Up By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 11:35
Bloody hell .......now that is ...um....well yeh . head scratching statement that one.
(With the front hubs locked you have no drive to the front but you still have the wheels locked together. In this situation the prop shaft turns freely and so the wheels remain locked )
Don't know what your driving but if you LOCK the hubs you cannot rotate the prop shaft ,
Doug
FollowupID: 503457
Follow Up By: F4Phantom - Saturday, May 26, 2007 at 11:50
what i ment was the propshaft is now locked to the front wheels but you are not actually engaged in 4x4, only 2x4 so the prop shaft spins freely when your front wheels turn. Rarther than the 4x4 senario where the prop shaft is driving the wheels.
FollowupID: 503463
Follow Up By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 12:00
OK That looks better....lol
FollowupID: 503465
Reply By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 14:54
Iv'e never read so much BS from a bunch of 4x4 owners in a long time . none of you have got the faintest idea how an Auto Locker works , if you turn the front the front hubs to LOCK and remain in 2wd there will be a slight difference to steering , BUT when turning the front Auto diff will unlock and allow the left wheel to turn faster than the right wheel in a RH turn or there would be massive wear and scrubbing, There is no power being applied to the diff so it will do what it is suppose to do and that is UNLOCK, I have no problems with mine ,
OK now all the experts can tear strips off me,
Doug
AnswerID: 241593
Follow Up By: Member - John L G - Tuesday, May 22, 2007 at 14:58
Doug,
I agree.
Have one fitted to the front of the cruiser and only realised the other day that the hubs were still locked in after a trip four weeks ago in Collie. Now in Newman and have noticed no difference in steering characteristics at all
FollowupID: 502505
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 15:21
Didn't you notice the fuel gauge moving a tad faster, well at least it gave it a good lube up , I run mine for a few Ks about every 3 weeks.
FollowupID: 502506
Follow Up By: Member - John L G - Tuesday, May 22, 2007 at 15:32
Doug
Now that you mention it, the trip up from Perth did prove a tad expensive.
Came via Merredin this time thru the back of the wheatbelt ending up in Paynes Find before the drag north. Plenty of dirt, but hardly used and super smooth. Interesting country,.
As for auto lockers, they have proved to be probably one of the cheapest and certainly the best mod I've done to this truck.
FollowupID: 502508
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 15:36
I had to do a detour to Merredin from Wubin last year and went down the Rabbit Proof Fence , that was a really good fast track
FollowupID: 502510
Follow Up By: Member - DOZER- Tuesday, May 22, 2007 at 16:27
Doug..im starting to think you like stirring up things with your approach to telling everyone how you know everything better....maybe you do, (know better) but others on here had had differing experiences with their front auto unlockers and mine was crap....isnt that what this forum is about...sharing experiences so others can sort out whats right for them and whats not????
No car company puts them up front standard...does that say anything to you??
For traction, they are better than a air locker, because the x factor is taken away, they lock automatically, not after you get bogged.. good for farm trucks that are used 51% off road, but for the ones that use their 4wd 99% on road, manual lockers are better and for thesame reason.(x factor)...oops left the hubs in...or some bleep locks one on ya
Driving with an auto unlocker running in a front diff wont damage anything, but the extra weight on he steering doesnt help longjevity of steering....ie it wont make it last longer either... The thing i missed the most after putting my auro unlocker in the front was being able to drive in high range 4wd on fast dirt roads...the steering was effected that much by the pedal, it was downright dangerous.
I wont be posting again, brcause confucious, in his infinate wisdom once said....Man who argue with silly person, silly himself....take some Q7
FollowupID: 502518
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 17:19
Not much point in having the debate with Dozer because 1 he aint posting anymore and 2 he reackons this is an arguement,
So I will point out one comment he made
[because the x factor is taken away, they lock automatically, ]
They don't lock automatically, they UNLOCK , This is a straight forward issue we are talking about but still people want to rip into you even when they don't understand how things work ,
FollowupID: 502535
Follow Up By: Exploder - Tuesday, May 22, 2007 at 19:57
Yeah agree with Doug hear, It’s one reason why people don’t like mechanical Lockers in the back cause they are a bit unpredictable you can be turning a corner give it some gas and she will lock on you and in the wet that can get hairy.
The Lock-rite is one of the more popular lockers in the front of the explorers in the states; the X has no hubs to unlock so they are constantly engaged however you can trick the T/case into not using its TOD system thus making it optional 2WD or Full 4WD and making driving on-road with the locker more pleasant, I have never heard reports of people saying steering is bad with the locker up front when in 2WD.
Never driven anything with a mechanical Locker up front my-self, thinking of putting a True track up front in mine, but will test the hole steering issue out when we fit a DANA 40 up Front and Duel Detroit lockers to my mates Jeep in a few weeks, but with 6-Inch lift and no sway bars it’s a Pig anyway LOL.
FollowupID: 502590
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 20:06
Exploder
Now Here's a bloke that knows what he's talking about and knows what he wants and why
Good one mate
Doug
FollowupID: 502595
Reply By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 15:23
Phill
Read this link
Site Link
AnswerID: 241595
Follow Up By: Member-Granpa Joe - Tuesday, May 22, 2007 at 17:38
Doug,
The Lock Right has springs that hold the dog teth apart when there is no driven force applied from the front tailshaft. The Soft locker and the like from detroit are are different to these as you stated. I think some of the people above were refering to the Lock Right mate.
FollowupID: 502542
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 17:56
Granpa Joe and others
C'mon gimme a break, if the damn thing had springs to keep unlocked it would be useless, I put a link there for you all to read , seem you didn't bother but would talk about rumors you hear about in the pub or elsewhere,
The Detroit Locker and the Lock Right are an automatic locker that are always in operation. They work by leaving the diff locked and automatically unlocking it when required. Without getting technical, they work by transmitting drive equally to both wheels but allow a wheel to turn faster than driven speed, such as required when cornering. The ARB diff lock is operated by a switch when required and locks the diff completely. It does not allow any difference in wheel speed on the same axle.
As someone else said in this article that he is starting to think I like stirring up things with my approach to telling everyone how I know everything better. well I don't know everthing better , What I do is read , study a product, and learn all that I can about it , and 2 of my favorite interests are GPS's and Diff Locks, So before I make a comment I try to make sure I have it right, Now we're all perfect and niether am I but when I see someone making misinformed comments, and they are just that I feel I would like to put them on the right track, thats all, and if you lot don't want to read, listen and learn then too bad.
FollowupID: 502550
Follow Up By: Member-Granpa Joe - Tuesday, May 22, 2007 at 18:08
You haven't done a lot of research on the Lock Right then obviously or you haven't seen the mechanics of the actual product.
I have fitted these to a couple of 4by's and know how they work, don't take the wording in a peice of literature literally or you might end up with egg on your face!
Although ingnorance is bliss ........ is it not ?
Cheers, ; )
FollowupID: 502557
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 20:47
Granpa Joe
Seems you missed the point too, the original post ....was
Steering hard with Lokka (front end) PostID: 45751
And yet you say the damn thing has springs to keep it unlocked , if so then would it be easy to steer, but of course he says it's hard to steer,thats because it's locked , now I have a full Detroit No-Spin in the front and yes I can feel just a little pressure there when turning slightly in 2wd hubs locked, In 4wd in the Dunes when asked it steered either direction with little effort , it's no problem just push the stick forward into 2wd until the next dune , of course if there is only a couple hundred meters then I left it in 4wd high, and secondly with the rear Locker working 100% of the time sometimes it is not needed to engage 4wd.
Doug
FollowupID: 502617
Follow Up By: Member-Granpa Joe - Tuesday, May 22, 2007 at 21:09
No Doug,
He asks: "I just need someone to confirm its perfectly normal with the lokka when not in 4wd? " for the steering to be hard.
You say yes for "any" type of locker, I say no , not for the Lock Right.
I am certainly not plugging any particular brand either.
And "I" don't profess to know everything.
His answer depends on what type of "auto locker " he is using, don't get upset I am just trying to help Phill like other here.
Ps. sorry for filling up your post Phil.
FollowupID: 502629
Follow Up By: Sarg - Tuesday, May 22, 2007 at 22:16
What I do is read , study a product, and learn all that I can about it , and 2 of my favorite interests are GPS's and Diff Locks, So before I make a comment..............
AND he believes in himself that Garmin make the best GPS. More study needed.
FollowupID: 502663
Follow Up By: Member - Captain (WA) - Saturday, May 26, 2007 at 11:19
Hi Doug,
Glad you liked my article on diff locks!!! Haven't touched that web site for years and still suprising how many hits it gets.
Captain
FollowupID: 503452
Reply By: Member -Dodger - Tuesday, May 22, 2007 at 17:46
Doug is totally correct, if it is an auto locker the dif is locked until one turns then the dif unlocks. I have had one in my Gu for 6 yrs and have had no probs except for the clicking sound when one turns with the hubs locked and I have learned to live with it. At least I know that they are still working.
Cheers Dodg.
AnswerID: 241623
Reply By: Member - dock - Tuesday, May 22, 2007 at 22:18
Doug is right on this one. The Lokka I have in the front diff of the Troopy (which used to be in my 80 series prior to changing it over) is locked all the time in a straight line until one wheel starts to go faster ,ie when turning, then it unlocks.
As for for it being harder when it is 2WD with the hubs locked there is no difference, actually woudn't be bad if it did cos then i would know that I have left the hubs locked in. Have done 100's of K's accidentally with the hubs locked in and have not noticed till I have stopped and looked at the front wheels.
Reckon it is one of the best things I've added to the 4WD even in the wet at high speed on gravel roads
AnswerID: 241732
Reply By: slammin - Tuesday, May 22, 2007 at 23:10
As some have said,
Front auto lockers do NOT make it any harder to steer if the hubs are locked and in 2wd.
YES you will hear the clicking sound but I have never found the steering any different in 2wd with hubs locked.
Doug, I have been off forum for a while so I'm not sure what history you have with your protaganists but comments like "none of you have got the faintest idea how an Auto Locker works" just begs a blow torch for a flame session - EVEN if you are right. LOL
Simplest way to think of auto lockers is "AUTO UNLOCKERS".
Ford Rodeo I am wondering why you think yours may be difficult? 4wd not disengaging correctly? OR worse still lockers not disengaging, please post to put the fire out on Doug.
AnswerID: 241750
Reply By: frankl - Wednesday, May 23, 2007 at 07:31
This thread was entertaining to a certain point. I am the person who originally asked the question.
I am using a Lock-Rite.
My experience is with the front hubs locked and IN 4wd, the steering is stiffer and I would love to say BS to those who didnt know the front hubs were locked... but as someone else said, seems like everyone is having a completely different experience.
what i find really difficult is steering with the hubs locked and IN 2wd.
Picture this scenario. Driving along dirt track that intersects with bitumen road and you need to drive the bitumen for 1km. I take the car out of 4wd but I dont get out of the car to unlock the hubs. From stand still and turning onto bitumen the steering is a dog, to the point where the wheels are scrubbing and the car is still going straight (in some situations only). a normal turn onto bitumen i need to make 3 point turn. What i found that helps me in this situation is to keep moving when I need to make a turn. I figured that if the wheels are still moving the diff will unlock a lot quicker than when at a standstill.
AnswerID: 241770
Follow Up By: Member - DOZER- Wednesday, May 23, 2007 at 10:21
Gday Frankl
No-one should be alowed to get on here and bully or verbally abuse others responses, it takes away participation in discussion. Sorry i hyjacked your thread.
A couple of things....there are more than one brand, they all work slightly different, im guessing some better than others, then we all have different cars, some ifs, some rfs, some worn out, some new. They will all behave differently with one brand, and all differently again with a few brands....
Now as stated above, the lockers are locked untill one wheel wants to turn faster than the diff.....at this point, the torque overcomes the springs holding the drive dogs, and it opens. This spring pressure that needs overcoming will be felt in your steering.
Yours however, seems a little excessive. Maybe there was some wear on your centre gears and the brand of locker installed is jamming up due to this...i can only suggest you drop the diff oil and look at what comes out...if you have steel filings, you should then discuss options with a mechanic. or. unlock those hubs....comeon i know its hard to get out...thats why you need a passenger at all times....:@)
FollowupID: 502755
Follow Up By: Ford Rodeo - Wednesday, May 23, 2007 at 14:44
WOW! Now that was a response!!!
OK, with all that said and done, has anyone here got a Lokka (brand name) auto locker in their front end and switch from 4wd to 2wd (hubs locked) and travel at high and low speeds? If so how does it change steering, travel, etc between 2wd unlocked to 2wd,4wd locked?
Phill
FollowupID: 502807
Follow Up By: slammin - Wednesday, May 23, 2007 at 15:52
FWIW mines a Quick Lok.
Any auto locker should not be affecting steering in 2wd with the hubs locked. If they are then they are NOT unlocking.
From what you have described it seems that the diff is not unlocking or your transfer case is not disengaging 4wd.
Is your diff making the clicking sound when cornering in 4wd? If not maybe that's the culprit.
Alternately jack up the front end with both wheels off the ground - 2wd engaged - hubs locked and gently see if the wheels can turn? (DO NOT USE FORCE or you may find that you will force the rear wheels to roll the car off the supports..... squash woops :o ) If the wheels do not turn maybe the transfer case is not disengaging from 4wd.
FollowupID: 502814
Follow Up By: B3 - Wednesday, May 23, 2007 at 20:01
frankl
I do the same - when offroad in my Hilux I leave my hubs locked to save having to get in and out of the vehicle, and switch between 4WD and 2WD as needed. I have a Lock - Rite in the front diff.
When in 4WD the steering is stiffer. When in 2WD it is not noticeable.
My observation, sorry can't help as to why yours is different. Good Luck!
FollowupID: 502891
Follow Up By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 11:27
frankl
( From stand still and turning onto bitumen the steering is a dog, to the point where the wheels are scrubbing and the car is still going straight (in some situations only).
By what you just said there it sounds like it's not unlocking, maybe installed to tight with no backlash
Doug
FollowupID: 503453
Reply By: Member - DOZER- Saturday, May 26, 2007 at 16:21
frankl
You dont by any chance have two different tyres on the front end, or one inflated more than the other???or different size front to back etc etc???? Either of the above will cause the diff to lock and steering to become very hard when in 4wd, and alot more resistance to steer when locked hubs but out of 4wd.
AnswerID: 242544
