Exhaust Brakes
Submitted: Tuesday, May 22, 2007 at 22:28
Member - Doug T (W.A)
I was going raise the issue on Exhaust Brakes , and had not seen it mentioned since I have been a member so found this in the Archives
On Friday, October 22, 2004 at 09:04
Member - ramp posted about exhaust brakes - (PostID: 17221)
I have driven a truck with E/B , a 1976 CK40 UD and they were good , they would lock the drive on mud in 2nd and 3rd gear ,but still not as good as the Jacobs Engine Brake , I remember seeing the E/B advertised a couple or more years ago and thought the idea would be very good for when towing a caravan abd for
hill decents,
The system on the UD worked with an air operated solenoid ram, with micro switches on the clutch and Accelerator pedals as
well as the lever on the steering Column,
Wonder why they don't make a small version of the Jacobs Brake , would be ideal for the likes of F250s when towing Horse Floats etc
Reply By: Richard Kovac - Tuesday, May 22, 2007 at 22:34
Check out site link Doug
www.jakebrake.com/technology/exhaust.php
even jake make them now
Richard
241736
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 22:41
Richard
Bloody brilliant mate , good to see someone knows their homework, I didn't even bother to check the web for the Jacobs , I looked for the Exhaust brake that uses a butterfly in the pipe, Thanks , I will sdd it too the favorites
Doug
502670
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 22:48
Richard
I can just see it now , A Troopy with a big bulge in the bonnet to accomdate the extra height in the engine , that;s using the one same as the larger Trucks .
502675
Follow Up By: Member - lyndon K (SA) - Tuesday, May 22, 2007 at 22:49
Sorry Doug
I've had a few beers, what does SDD =?
502677
Follow Up By: Richard Kovac - Tuesday, May 22, 2007 at 22:52
No compression to noisy,, exhaust brakes can be fun.. and I love the big black poof of smoke out the back when you hit the go peddle again...
502683
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 22:54
lyndon K
Thats ok mate , Iv'e had a cuppa coffee , eaten part of a cow for supper, and NO i aint done a Ben Cousins yet,,,lol
What in hell are you referring too SDD , where did you see that ????
502685
Follow Up By: Richard Kovac - Tuesday, May 22, 2007 at 22:58
Your first reply
502690
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 23:01
Richard
Know what ya mean about the puff , the UD had a straight through ex' and when you turned it off without hitting the go pedal it used make a very loud HISS and when you took the foot off for a gear change made a noise like a Mortar going overhead, Use to like driving that Truck through the streets of
Melbourne
502692
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 23:09
lyndon K
OH THAT SDD .....um .....err thats big finger shorthand typing for the word ADD.
If you look closely at your keyboard you will dee the letter S is next to the letter A and I'm bloody tired and Cranky and the old finger hits the wrong letter you naggin' bugger ....lmao your worse than a wife , I also have trouble with the T and Y
I'm going to ADD it to my favorites Lyndon OK now be a good fella and have a XXXX for me mate , my fridge is bare tonight.
Doug
502693
Follow Up By: Shaker - Wednesday, May 23, 2007 at 10:09
You wouldn't love exhaust brakes if you lived on a road used by log trucks constantly ignoring the "no exhaust brakes" signs!
502747
Follow Up By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 10:39
Shaker
Awww does the noisy woisy keep him awake .....lol
No mate I know what you mean, I had to ride with a D/head
young idiot from
Brisbane to Melb' back in 02 , I was to be driving this particular Freighliner but it had so much wrong with it that it was sent back to the leaser, Anyhow this goose used the Jake Brake right through the middle of Jerelderie , a flat street at 2am and it was loud to , there is no need for that , On the other hand I had to drive an International S Line down the Palmerston Hwy with a load of Railway Lines without the Jake because there was a fault and it would not work, the lowest gear would not hold the truck back , it wanted to over-rev so the only way was to go up a couple of gears and use the brakes when when the revs got to high, I tell you it was scary because the smoke was pouring out of the trailer brakes,So todays modern Trucks are designed to run in conjunction with Engine Brakes for best efficiency, Yes Shaker like everything in life there will always be someone who has to be a D/Head and give everyone else a bad name,
502756
Follow Up By: Ozboc - Wednesday, May 23, 2007 at 16:05
" BIG black poof " - something you want to tell us Richard?
502818
Follow Up By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 16:33
Ozboc
I do believe Richard was commenting on a puff not a poof.....lmao
Your trouble is that your mind is corrupt,warped,filthy,contaminated.one tracked. Red Necked, Disgraceful, ........bugger I can't think of any more,
Doug
502821
Follow Up By: Richard Kovac - Wednesday, May 23, 2007 at 23:40
Thanks Doug
To me makes the same sound when sead...LOL
502965
Follow Up By: Ozboc - Thursday, May 24, 2007 at 07:49
Doug T- As usual - nothing intelligent to add - just the usual judgemental garbage a dolt(as yourself) could manage.
Boc
502983
Follow Up By: Member - Doug T (W.A) - Thursday, May 24, 2007 at 10:45
Ozboc
Site Link
We'll see
503006
Reply By: Steve from Top End Explorer Tours - Tuesday, May 22, 2007 at 22:46
Hey Doug
Something you might try is the system they have on the Toyota coaster bus they have an exhaust brake.
Just a thought.
Cheers Steve.
241741
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 22:49
You got em on your rigs
502678
Reply By: Steve from Top End Explorer Tours - Tuesday, May 22, 2007 at 22:53
No, but the coaster has a 1hz motor.
So it may be plausible.
Steve.
241746
Follow Up By: Member - Doug T (W.A) - Tuesday, May 22, 2007 at 22:55
Hmmmm very interesting, might have to check out some wrecked Coasters.
502686
Follow Up By: Steve from Top End Explorer Tours - Tuesday, May 22, 2007 at 22:57
Those motors have a bigger fuel pump as
Steve.
502689
Follow Up By: traveller2 - Wednesday, May 23, 2007 at 08:13
I drive a Coaster with a 1Hz every day, the exhaust brake works a treat and I really miss it when in the truck.
Have often wondered why the cruisers aren't fitted with them if only on the troopies and traytops.
One thought though is how do they work with an auto trans? Be ok if you could lock the TC but most trans won't allow it in the lower gears.
502728
Reply By: _gmd_pps - Wednesday, May 23, 2007 at 01:59
I use this on my truck
Site Link
the 4" exhaust with the air turbine in place of the kitty has little back pressure
so this unit will solve that ... have it here but not mounted yet ...
have fun
gmd
241762
