Magellan Explorist XL
Submitted: Wednesday, May 23, 2007 at 09:47
ThreadID: 45784 Views:1951 Replies:2 FollowUps:3
Hey guys,
Is it ok to leave the batteries in the XL when it is plugged in to the cigarette lighter or do you need to remove them?
Cheers, Jack
Reply By: Member - Nutter (QLD) - Wednesday, May 23, 2007 at 10:09
Gidday CYT , I have an XL and leave the batteries in , had no problems, also handy if you switch off ignition, reverts to battery power and doesn't get shut down, a message comes up on the screen, "power lost at ....."
See ya
Nutter
AnswerID: 241810
Follow Up By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 11:25
Nutter
Why don't you hot wire it so it don't go off with the ignition key, That's how my two are , always on and ready ,
FollowupID: 502771
Follow Up By: Member - Nutter (QLD) - Wednesday, May 23, 2007 at 13:19
Gidday Doug, that is on the to do list , sort of , we have three 4x4s in the family so it gets moved from one to the other sometimes, probably should hardwire it then it will NOT get borrowwed.
Ahhh such is life
Nutter
FollowupID: 502791
Follow Up By: Member - Doug T (W.A) - Wednesday, May 23, 2007 at 13:25
Nutter
Bloody Banana Bender, ....shhhh I lived in Qld for 26 years, probably come back one day,
Anyhow seems your a Gunnado like me , I was a Gunnado with the truck CB antenna on the left mirror frame , I broke 3 on trees and signs before I actually got around to putting it on the right side mirror frame.
FollowupID: 502794
Reply By: CapeYorkTroopy - Thursday, May 24, 2007 at 08:43
Thanks guys,
I will leave the batteries in.
Nutter, you could hard wire the cigarette lighter in all of your vehicles.
That way it could be swapped between them and you still wouldn't lose power if you turn the car off.
Cheers, Jack
AnswerID: 241986
