Driving Light Wiring MK Triton
Submitted: Thursday, May 24, 2007 at 18:33
ThreadID: 45842 Views:9673 Replies:2 FollowUps:2
G'day all,
have a mate with a 2006 MK Triton, but he's having some trouble wiring up the driving lights.
Has anyone wired them up to work on both High Beam and Pass successfully? If so do you have wiring schematics?
Reply By: Notso - Thursday, May 24, 2007 at 19:22
Thought it was only legal to have em wired into the high beam switch??
AnswerID: 242096
Reply By: Member - Blue (VIC) - Friday, May 25, 2007 at 00:08
I have an '03, which is still an MK... I installed Narva lights, followed the diagram enclosed and all has been working just dandy for the last 4 years.
If by "pass" you mean pulling back on the indicator stick for a quick flash of the lights, mine work there too...
AnswerID: 242207
Follow Up By: Member - Sam (NSW) - Friday, May 25, 2007 at 09:50
Is the 2003 model an negative switched model? From what I can work out, the 2006 model is.
FollowupID: 503222
Follow Up By: Member - Blue (VIC) - Friday, May 25, 2007 at 14:22
I can only assume it isn't negative switch as the standard instructions worked... I can't understand why they would change to negative switch when the rest of the vehicle is essentially identical bar the headlights and grill...
Just sitting here re-reading my reply and I may have just answered the question... They did have a headlight upgrade so perhaps that is where the negative switch came in...
FollowupID: 503266
