I am in trouble with OziExplorer AGAIN
Submitted: Friday, May 25, 2007 at 11:52
ThreadID: 45872 Views:2035 Replies:4 FollowUps:1
HELP ,
I open 1:250,000 mosaic and turn on the moving map feature . It works for a minute , then comes up with a message in the middle of the page , you close the message and it immediately changes the map to the LANDSAT one .
Now your going to say "what was the message " and an intelligent person would be able to tell you ! But I am a dummy and I cannot remember and I cannot turn it on here to find out . Very frustrating .
At least the old Magellan never lets me down .
Cheers ,
Willie .
Reply By: Willem - Friday, May 25, 2007 at 12:15
Looks like you are destined for paper maps and a boy scouts compass, Sir Willie.
Latte's indeed!!!!
Sorry to hear about your Coopers. When will ya listen?
Enjoy the Kimberley.
AnswerID: 242283
Reply By: Member - Phil G (SA) - Friday, May 25, 2007 at 12:29
Go to File/Configuration, and click on the Moving Maps tab.
Untick the "search for more detailed map" box if it is ticked.
Apart from that I cannot help!
AnswerID: 242288
Reply By: SCUBADOO - Friday, May 25, 2007 at 12:45
Willie
You MUST read the help file.
Your OziExplorer is probably set up to check for other more detailed maps.
In OziEplorer Menu:
Moving Map > Moving Map Control. In the new window untick 4th box "Check for More Detailed Map"
OR for a more permanent solution:
File > Configuration > Moving Map - Untick "Always Check for a More Detailed Map"
You can even set up function keys to do all this and more.
Hope it works.
Neville
AnswerID: 242293
Follow Up By: SCUBADOO - Friday, May 25, 2007 at 12:55
If it does not work please report back with the message.
Mine often reports "You are a dummy and please remember this message!" (-:
Neville
FollowupID: 503254
Reply By: Richard W (NSW) - Saturday, May 26, 2007 at 06:05
Sorry Willie I can't help with this one but earlier posts are worth a try.
AnswerID: 242461
