Water for CSR Trip
Submitted: Saturday, May 26, 2007 at 09:21
ThreadID: 45904 Views:3086 Replies:6 FollowUps:3
What have people done to carry heaps of water for the CSR ??? We're going to have 2 adults and 3 kids in our 80 so not a huge amount of room once all the gear is on the roof and in the back.
I thought about jerry cans across the back of the roof rack - fuel at the moment isnt too much of a worry to carry...will possibly be getting a 200lt spare tank....but i thought that there has got to be a better idea and one that takes up less room...
Any ideas on what people have done would be great.....
Laura
Reply By: Willem - Saturday, May 26, 2007 at 09:49
Laura
The Wells of the CSR have water in them.
You can boil the water to be on the safe side.
I carry 100lts of rain water from home and top up when necessary. Keep the rain water for drinking and the topped up water for other uses.
Keep only light stuff on the roof. Water up there will be a pain and may be too heavy for the rack. Buy 10lt water bottles from discount shops. They are easier to pack
AnswerID: 242485
Reply By: Wayne (NSW) - Saturday, May 26, 2007 at 09:50
Laura,
There is water available on the CSR from some of the Wells that are still working. The Well water is alright for adults but for the children I would have water from home as the Well water might up set them. I always boil the water just in case.
If you go for jerry cans for water make sure they are only 10lt. They are lighter to lift, can be stored around the vehicle and if they do leak you have not lost a lot of water.
Wayne
AnswerID: 242487
Reply By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 10:12
Laura
I wouldn't put water up on the roof rack, water is heavier than fuel plus the center of gravity will be affected, I don't know where you are but if near a big city zipp of to a Truck accessory shop and see if you can get one of these
They are meant to have the flat part up and under a Semi Trailer, this one is 40ltr and there is an 80ltr, I have an 80ltr in my Troopy , Installed flat side down , it's in under the bed , not fixed down, it never moves, The 80 cost me $110 and is good for drinking water, it's tough and won't break.
www.bmackay.com.au/dp/tank.html
AnswerID: 242494
Follow Up By: Alan H (Narangba QLD) - Saturday, May 26, 2007 at 11:45
Doug
How do you get the water out if located flatside down with tap at the top?
Pump? Air pressure? ?????????
FollowupID: 503460
Follow Up By: Member - Doug T (W.A) - Saturday, May 26, 2007 at 11:57
Your a funny man ya know , geez mate didnya know water runs up hill .
Now look what your've got us into !!!
But just in case your serious I put the tap in the other bloody hole, and use the tap hole for breather and then force the water back up the outlet which is a tap fixed to the rear bumper with clip on fittings, The water goes in and the air escapes out the breather , when the tank is full water begins to issue out the breather , the breather outlet also has a tap so I don't lose water from it, When the water level drops a 100mm I just leave the breather open ,
Doug
FollowupID: 503464
Follow Up By: Alan H (Narangba QLD) - Saturday, May 26, 2007 at 13:50
Thanks Doug
Not having a good day! I did not investigate the website to see that there are two tap holes. (silly me)
It seems like a great idea. I hope to get one of those new troopies one day and a tank like that would be great.
I have a very funny shaped tank under the passenger side on the 80 series but it only holds about 20L to fit up between the chassis rails. I fill it through the outlet tap (has male hose fitting) and have a long breather looped up under the bonnet.
FollowupID: 503474
Reply By: Crackles - Saturday, May 26, 2007 at 16:18
3 x 20L jerry's fit directly behind the seat between the wheel arches & accessed by dropping the back seat. 1 x 20L jerry behind RHS wheel arch & 1 x 10L jerry on LHS both with taps & a short length of hose to gravity feed the water out the back.
Fill them all up with clean water on departure & top up with well water as you go. Plenty of opportunity to refill & I just mark that jerry with grey tape to indicate the water must be boiled or used only for washing.
A small pressure pump can also be fitted into the jerry's behind the seat running to a trigger tap for convenience. I like to have many smaller containers to store the water to avoid losing the lot should one spring a leak.
I have in the past used a 50L water bladder accross the rear floor & if you can put up with a little sloshing works well. May require a timber panel over the top for the kids to put their feet on.
Underneath I think the 80 has room for about a 40L water tank on the LHS if you want to fabricate something more permanent.
Cheers Craig...........
AnswerID: 242543
Reply By: kimprado - Saturday, May 26, 2007 at 18:42
Laura
We did a survey on the Wells back in 2004 which included:
Water availability
Quality
Depth
Capacity
Recovery rate
I'll have a look at my files and send a copy of the report to you. Be mindful that Well conditions can change over a relatively short period of time.
Kim
AnswerID: 242575
Reply By: howie - Saturday, May 26, 2007 at 22:17
i had to buy 4/5 new plastic jerries for the petrol i was taking on at well 23.
as well as my usual green water jerries.
the new fuel jerries were filled with water and used untill well 23, then used for fuel.
like mentioned before, use well water for washing up etc and keep the good water for consumption.
didn't have to boil or steralise any water (but had the gear to do it)
AnswerID: 242610
