Broken Fronteria
Submitted: Tuesday, May 29, 2007 at 12:30
Vince NSW
With only 4 weeks to go before we were to leave for the Flinders & a west to east Simpson crossing, found cracks in chassis rails. After talking to engineers they can not be fixed quickly, SO. Looks like a new truck.
Questions for thoes with knowledge :
1.Looking at Navara as I can get a great deal on the run out of the DT22. Any info good or bad ?
2. If I go for the Navara, where do I mount the main box of the Barrett ?
3. Will not have time to get a 2 inch lift before we go, so will this cause big with the Simpson.
4. Have been told by the dealer (Do you believe them) that if I fit a
Snorkel I will have enough room to mount aux battery in the engine bay. Has anyone donr this ?
I can get a Duel cab with Bull bar, tow bar Canopy &
snorkel fitted for $41K on the road. Best price I have come up with.
Reply By: Member - Duncs - Tuesday, May 29, 2007 at 13:30
Vince,
It should be pretty simple to check with a 4wd accessories place about the battery/
snorkel question.
You will not have any probs with ground clearance on a standard Navara in the Simpson.
Is there a V8 Disco going in your group?
Duncs
243178
Follow Up By: Vince NSW - Tuesday, May 29, 2007 at 14:21
Thanks Duncs
I will make some enquries re battery.
As for V8 Disco. NO
My party at this stage will be 1 Navara.
Going to the EO gathering in the Flinders and hope to pick up someone on the way. If not I will stick to the French line & they tell me it is like Pitt St during July
regards
Vince
504148
Reply By: Grungle - Tuesday, May 29, 2007 at 18:43
Hi Vince,
We have a dual cab and single cab D22 Navara as our work vehicles. We have our communications and electronic equipment mounted behind the back
seat in both which comprises of 3 transceiver bodies, fuse holders and invertor all mounted on a plywood base which is stood off from the back wall and secured by 4 bolts. Saves putting tech screws in the back of the cab and the possibility of
water and dust ingress. Looks good too.
David
243276
Follow Up By: Vince NSW - Tuesday, May 29, 2007 at 19:11
Thanks David,
Is there any space under the rear
seat ?
Vince
504220
Follow Up By: Grungle - Tuesday, May 29, 2007 at 19:28
No unfortunately. The base doesn't move from what I recall so would have to try and remove completely to gain access. Way easier to drop the back
seat forward and fit / work on equipment that way.
David
504221
Reply By: Willem - Wednesday, May 30, 2007 at 10:14
Hi Vince
Sorry to hear of your troubles
Have had good and bad reports on Navara's. Member Extfilm here on EO hates his. Others I have met with Navaras, think they are great. I do think they may be a bit more robust than some of the other makes around.
I wouldn't worry about the 50mm lift for the Simpson considering that Mini Mokes have been driven along the route.
Hope you get things sorted out soon.
243438
Follow Up By: Vince NSW - Wednesday, May 30, 2007 at 10:40
Thanks for that Willem,
Looks like I will be doing your trick of useing Jerry cans this trip as there is a 6 - 9 week delay in long range tanks. I will havbe a lot more space in the dule cab so this sohuld not be a prob.
Look forward to seeing you at Warrawena.
Vince
504380
Reply By: Leroy - Wednesday, May 30, 2007 at 11:58
Vince,
Ask for ABN pricing. Yes I know you will probably say you don't have a business. Anyone can apply for an ABN number. We had Nissan advertised for $33k + on raods for ABN holders on TV a while back. Worth asking the question otherwise enquire at another dealer.
Leroy
243454
Follow Up By: Vince NSW - Wednesday, May 30, 2007 at 12:34
Leroy
Easy to get ain't they, ABN that is. Did it on line yesterday & saved $2k. Needed one anyway for when I leave work in next few years as I will become a parasite called a consultant.
Vince
504403
Follow Up By: Leroy - Wednesday, May 30, 2007 at 12:52
Good stuff. I thought it worth a mention.
Leroy
504406
