camping spot between Waikerie Burra
Submitted: Tuesday, May 29, 2007 at 21:37
ThreadID: 46053 Views:4884 Replies:6 FollowUps:3
Hi i was wondering if anyone knows of any camping spots between Burra and Waikerie in south Aus? We are just looking for a spot to get of the road for the night on the way to the Simpson desert. Thanks for your help Cheers Flannel Bros
Reply By: Des Lexic - Tuesday, May 29, 2007 at 22:21
Try Hogwash Bend just out of Waikerie, or Morgan Caravan Park or Burra Gorge about 20k's out of Burra on the Morgan Road.
AnswerID: 243368
Reply By: Blaze - Wednesday, May 30, 2007 at 00:58
Hi Flannel, Why would you be coming through Waikerie on your way to Burra? If you are coming from Adelaide, its easier to go straight to Morgan, then Burra and if you are coming from the Mildura way then Renmark, Monash and turn right and up to Morgan also.
If you are coming out of Waikerie then Hogwash is a really nice spot as Des says, if Burra Gorge is to far then there are quite a few spots to get off the road between Morgan and Burra.
AnswerID: 243401
Follow Up By: Blaze - Wednesday, May 30, 2007 at 01:20
One other thing. Not sure when you intend on hbeading off but a lot of roads up around the top of S.A. are closed at present...
FollowupID: 504331
Reply By: Member - Bucky (VIC) - Wednesday, May 30, 2007 at 13:04
Got a copy of Camps Australia 4 !
its brilliant, and the Producers should be congratulated !
Bucky
AnswerID: 243480
Follow Up By: Member - Pesty (SA) - Wednesday, May 30, 2007 at 22:41
Hiya Bucky,
We have had the camps 2 for a while but just waiting for the 4, I ordered it as part of my membership renewal, from the EO shop, should be here any day.
Hope you are behaving yourself!!!
Cheers Pesty
FollowupID: 504535
Follow Up By: Member - Bucky (VIC) - Thursday, May 31, 2007 at 06:58
G day Pesty !
How's it all going ?
We are off next weekend to Hedley ( near Welshpool ) , I finally snagged another long weekend, ( from shift ) on an actual long weekend,, so its off to the scrub ,, well the edge of it anyway.
My luck it will "hiss" down. and I get the flu ,,, but then again thats what its all about
Say g'day to the rest of the crew over there '
Roachie not tipped over the " Titanic " yet ?
Must be a carefull ( lucky ) driver, that thing he has needs lowering a little is it "lists" too much for mine
But as I said to you once b4,, its his money, and as long as he is happy then its ok
Cheers for now
Bucky
FollowupID: 504557
Reply By: Member - Pesty (SA) - Wednesday, May 30, 2007 at 15:44
Hi Flannel,
There is a good spot, bush camp, at Morgan if you would like to avoid the C/Park.
If you come from Waikerie/Cadell, when you are approx. 100m from the queing point for the Morgan ferry, take the road on your right, and follow it for a little way, keeping to the left when the road turns right, and go in there and there are plenty of places to camp right on the water, opposite the S A Water pumping station.
Cheers Pesty
AnswerID: 243503
Reply By: Member - Mike (SA) - Wednesday, May 30, 2007 at 21:18
Hi Flannel,
On Morgan Burra section there is off road parking/ camping on N side of road, signposted with a blue P sign, approx 20kms E of Burra in the Mallee Scrub. Only tables, no other facilities,
regards
Mike
Too little time in the bush!
VKS 737 Mobile 0230
AnswerID: 243613
Reply By: Skippy In The GU - Thursday, May 31, 2007 at 10:06
We cam across a nice place just out of Morgan Co-ords are S 34 01.383 E 139 41.644 very quiet place next to the river
AnswerID: 243703
