Holden Rodeo V6
Submitted: Monday, Apr 28, 2003 at 10:05
ThreadID: 4611 Views:21150 Replies:9 FollowUps:11
I have a 99 model V6 Rodeo which is giving me shocking fuel economy, only just over 5 km/litre. (My tyres aren't flat and I don't drive at 160!) Just wondering if anyone out there with a similar vehicle could let me know what sort of fuel economy they get and any ideas on the cause of the problem. Any advice would be appreciated. Cheers, Keith.
Reply By: Will - Monday, Apr 28, 2003 at 11:10
Hi Keith, I drive a V6 rodeo and a reasonably conservately and am lucky to get 300 K's from a tank, sometimes 340. (rare)
we have a fleet of these and others have worst figures than that.
Will
AnswerID: 18580
Follow Up By: keith tayler - Monday, Apr 28, 2003 at 11:15
Thanks Will - not really the response I was hoping for! If that is the best that I can get then I think the old Rodeo will be getting the arse pretty quickly. That sort of fuel consumption is crazy - especially when comparitive vehicles (Triton and Hilux) get considerable better - around 7-8km/l. Know anyone wants a good Rodeo....
FollowupID: 11600
Follow Up By: mick - Wednesday, Apr 30, 2003 at 21:13
g''day keith you haven't mentioned if your rodeo just started chewing juice or is it always that bad. a mate of mine's went from good to attrocious in just a week apparently after much head scratching it was diagnosed with a faulty oxygen sensor. just something else you might want to check, although they are expensive ,genuine there is an aftermarket substitute
cheers and good luck
mick
FollowupID: 11786
Follow Up By: keith tayler - Thursday, May 01, 2003 at 08:29
Mine has always been pretty average but certainly appears to have got worse lately. Oxygen sensor a good tip and will investigate that. Thanks, Keith.
FollowupID: 11813
Reply By: Member - David - Monday, Apr 28, 2003 at 13:03
G'day there mate,
Don't despair- there is a fix. Our V6 gets about 7.5 km/l around town, and on a trip up to 8km/l- and we do big miles around town and when tripping.
1) Fit a 'FinerFilter' type air cleaner element- and service when required.
2) Find the thread here re: removing/replacing the ECM fuse (this made a big difference)
3)Don't 'baby' the thing when driving & don't thrash it. Use the gears and put the boot in a bit harder- but not too hard.
4)When PremiumUnleaded is cheap- put a tankful in- 5% dearer for about 10% better economy.
5)And just for interest sake we run the tyres at 36psi (if that makes a difference)
Thats my 5c worth-
See yaA bad days sailing sure beats a good day at work
AnswerID: 18587
Follow Up By: keith tayler - Monday, Apr 28, 2003 at 13:44
David - thanks for that. Could you please explain the ECM fuse thing a bit more. Not sure what you mean there. Have the finer filter on order already and hoping the see a difference there. Used to driving diesels so probably should rev it a bit harder too. Cheers, Keith.
FollowupID: 11607
Follow Up By: Savvas - Monday, May 05, 2003 at 09:49
Hi David,
Just a comment about your 5th point above. I've noted that at my local servo, 98 unleaded is always a flat 9c/litre dearer than normal unleaded. I've been keeping track of all my 'roos fuel consumption since April last year and noticed that when using 98, I do actually get 7% better fuel economy, roughly 1.7L/100km improvement. I don't get this improvement with 95 premium though.
What I didn't consider is that when the price of 98 is down, it is actually not worth buying it. For example yesterday I filled up with normal unleaded at 81.7c/L. The 98 was 90.7c/L. 98 is 11% dearer. Clearly that doesn't compare to a 7% consumption improvement.
However, as the price of ULP goes up as it did in the last couple of months to say 99.7c/L (or more), 98 was still 9c/L dearer at 108.7c/L. 98 is now only 9% dearer. Still doesn't match a 7% consumption improvement but it illustrates the point I'm making.
Assuming the difference between ULP and 98 stays at a constant 9c/L (or 5c/L, 7c/L, whatever), then it is actually more worthwhile to fill up with the higher octane fuel as the price gets dearer. Something to think about!
Nonetheless, I generally use normal ULP around town. But will always use either a 98 or Premium when on any sort of extended trip. The extra responsiveness is noticeable and makes the trip more pleasant for me as the driver. I start using the 98 two tankfuls ahead of the trip so by the time the trip rolls around, the octane rating is not diluted.
Cheers...Savvas
FollowupID: 12036
Follow Up By: Savvas - Monday, May 05, 2003 at 10:06
PS...Make that the 4th point, not 5th!
FollowupID: 12037
Reply By: Member - David - Monday, Apr 28, 2003 at 15:40
Keith,
Check out post #1469 on this forum.
It does work for the 3.2 V6 Rodeo.A bad days sailing sure beats a good day at work
AnswerID: 18600
Follow Up By: keith tayler - Monday, Apr 28, 2003 at 15:51
Thanks David - bit new to the web page idea and didn't click what you meant by thread (thinking bolts....). Hope it sorts her out a bit. Cheers, Keith.
FollowupID: 11614
Reply By: Member - Andrew (Bris) - Monday, Apr 28, 2003 at 20:51
Keith,
I traded my Rodeo last November. It was a 1998 V6 dual cab. I had it for two and a half years and put 140,000km on the clock while I owned it. Mostly city driving around Brisbane with a load of 600-800kg in the back for work. I always got about 6 km/litre. Country driving didn't improve economy much. Getting on the beach was even worse. Great vehicle to drive, but expensive on fuel.
Premium fuel did help a little, but the additional cost didn't make it worth while for me.
AnswerID: 18624
Reply By: Member - Peter D M - Monday, Apr 28, 2003 at 21:38
keith
have a 2000 model v/6.
best, but consistant average 7km per ltr. will try the ECM trick and will let everyone know the result next week.
regards peter
AnswerID: 18632
Follow Up By: Savvas - Friday, May 02, 2003 at 15:51
Peter,
I just have to ask....how did your Rodeo fair after the dunking in the photo?
FollowupID: 11924
Reply By: Member - David - Tuesday, Apr 29, 2003 at 11:52
Keith
Have just completed an extended consumption test- including Sydney-Newcastle return over Easter- a bit of running around town- up to the 4WD show at RoseHill- in all 850 km of a bit of everything.
This was on std. unleaded.
850km used 111.13 litres-13.07l/100km..or in your speak about 7.6 km/l.
I'm not too unhappy with that.
Doid ya find the info about the ECM bit???
BTW...Where are ya??A bad days sailing sure beats a good day at work
AnswerID: 18669
Follow Up By: keith tayler - Wednesday, Apr 30, 2003 at 08:55
Yep - found the info on the ECM and will give it a try shortly. I am in Darwin and the economy figures I got were from a run to Kunanurra and back (1600km total). I was sitting on around 125km/hr going across and probably 110km/hr coming back. The car had no load going across and I was towing a 12ft tinnie back (but would be surprised if that made a great difference). I was following an auto commodore back and he was getting 9-10km/l under the same conditions. Still waiting on my finer filter - things up here only happen in NT time (Not Today, Not Tomorrow!). If I can drag my rig upto around 7km/l I will be more than happy. Cheers, Keith.
FollowupID: 11730
Reply By: rodeoowner - Wednesday, Apr 30, 2003 at 12:29
My Rodeo V6 gets constantly around 6km/litre. The vehicle is however always loaded with tools so it tips the scales at around 2400kg. I also have two ladders on top, so considering all this I thought 6km/litre was fairly good. Cheers.
AnswerID: 18815
Reply By: Savvas - Saturday, May 03, 2003 at 08:23
Keith ...
I have a 2000 Jackaroo which has always been thirsty since new. At the 60000km service, I asked for an off-car injector clean.
Prior to this, it was averaging 20L/100km and upto 23L/100km around town. In the last 4 weeks since the clean it has been averaging 18L/100km around town.
There were other symptoms such as pinging under load, a flat spot when cold, and a Pajero beating it in a traffic light duel (that one indicated there was something amiss) which led me to ask for the injector clean. A totally different car since then.
I originally posted the ECM reset tip. However I found that remedy to be short lived and the consumption always crept up after a week or two.
AnswerID: 19039
Follow Up By: Member - David - Wednesday, May 07, 2003 at 14:34
I must be in a fortunate position here as the 'premium' juice is 5c/litre up on the normal. So when normal is 78c, as it here most Tuesdays, then it less than 5% dearer to use the 'premium'. I'm fortunate I have a 115 litre tank, so I can put off buying fuel til the price is right.A bad days sailing sure beats a good day at work
FollowupID: 12169
Reply By: Member - David - Wednesday, May 07, 2003 at 14:38
To Keith
Another interesting point- do you have a tonneau cover or a canopy on your ute?? Travelling at those speeds above 100klicks, I reckon an open ute tray would make a damn good air brake.A bad days sailing sure beats a good day at work
AnswerID: 19371
Follow Up By: keith tayler - Friday, May 09, 2003 at 08:35
I have a full cage on the back, with a tyre on the top. The cage follows the line of the cab pretty well, but the tyre sticks up a bit. Probably effects the fuel a bit, but not to level I experienced. Have fitted the finer filter which has helped slightly I believe, but have yet to get around to checking the oxygen sensor. KT.
FollowupID: 12265
