GPS Stolen & I'm Now Lost
Submitted: Thursday, May 31, 2007 at 22:43
ThreadID: 46128 Views:3077 Replies:9 FollowUps:9
Its probably good that some low ########## stole my GPS last weekend now I have a good excuse to get a flash new one.
I had a Garmin III+ and found it excellent and it connected easily to my laptop with OziExplorer
So what should I buy to replace it - Tom Tom - Garmin, Navman ???????? or big or small screen, color or b/w screen, remote aerial - any suggestions would be great
Reply By: Des Lexic - Thursday, May 31, 2007 at 22:47
Trekkie, I can't see for the life of me as to why you need a GPS. Once Scotty has beamed you up, surely you have a great view from there and you can see where your going anyway. :-))))))))))))))
AnswerID: 243868
Follow Up By: Trekkie (Member - WA) - Thursday, May 31, 2007 at 22:51
Good one, but even my space cruiser needs nav aids
FollowupID: 504761
Reply By: Member - andrew B (Kununurra) - Thursday, May 31, 2007 at 22:50
Gday Trekkie
Sorry to hear of the incident, too much of that sort of thing goes on...I can only support your origional brand, I have a garmin GPS76 (the dumb one with very small memory)....I have treated it badly, it spends a lot of time in the sun in the boat, on the dash of the car, and wherever I misplace it time to time (bit ironic I suppose). Garmin seem very reliable to me
Cheers Andrew
AnswerID: 243869
Follow Up By: Trekkie (Member - WA) - Thursday, May 31, 2007 at 22:53
Thanks Andrew - I have similar thoughts - my old Garmin sat on the dash in all temperaures that I would have thought would melt it, but it never even looked like stopping but some of the fancy ones seem to have some very good features
FollowupID: 504762
Follow Up By: Grungle - Friday, Jun 01, 2007 at 07:44
Can vouch for the GPS76. I have had one since 2000 which has sat on the dash of 2 cars ever since. Powered on 24/7 and has not had a problem except the protective lens is starting to go a little milky. Still easy to read and the LCD does not go black in the heat.
My criteria when I bought it was (in order):
-> Screen resolution
-> Computer conectability
-> External antenna cabapility
-> High waypoint and track storage
-> Solid mount (however this has broken and the bitumin pads suck)
The Garmin eTrex range is very good and there is a great range of units with all maner of features. Link -> www.gme.net.au/garmin/outdoor.php
If I were to upgrade, I would probably get something a little smaller than the GPS76. Don't care about all the maps etc as I use it with a permantly mounted PDA primarily and laptop secondly. As long as it can leave a breadcrumb trail and can store a lot of waypoints and tracks, I am happy (in case the PDA comes to grief).
Have also got a 32CH Bluetooth GPS used with my PDA phone for work which I have had for around a month. Works a treat also but is so small I am worried I will loose it.
David
FollowupID: 504789
Reply By: The Explorer - Thursday, May 31, 2007 at 23:14
Hello - probably need a bit more info on your intended use - do you wish to continue using GPS connected to Laptop (if so Tom Tom/Navman probably no good) or do you want to give OziExlorer the flick - some of the time or all of the time? Would you be happy with a PDA running OziExplorerCE?. Do you need a gps for walking in bush or are you a car bound trekker? Do you want one with detailed mapping capabilities or are you happy with basic greyscale, no map model (and then for example run OziExplorer for maps)? Do you have a price limit? Do you want it for city work and bush work or just one or the other? There are so many options it is impossible to say what is (possibly) best for you without additional info.
AnswerID: 243872
Follow Up By: Trekkie (Member - WA) - Thursday, May 31, 2007 at 23:21
Now Greg your making it a bit complex for a simple Klingon warrior.
Mostly I use it in the car only (very occasional bush walking)
I could see an advantage it it had suburban maps, but primary use is in the Bush
Occasional use it connected to laptop - one day if I make up a bracket I would use a laptop more often
FollowupID: 504771
Reply By: Navigator 1 - Thursday, May 31, 2007 at 23:17
It all depends on the $$$ you want to spend on a unit. I have a Garmin 276C and it hasn't missed a beat. Excellent clarity and big screen.
Good luck!
The outback calls
AnswerID: 243874
Reply By: Blaze - Thursday, May 31, 2007 at 23:35
Well Trekkie after using just about every setup probably available I think the PDA is the go, just set Uncle Des up with one with a solar powered GPS. If you want to stay with a brand name GPS I would suggest the Garmin Quest. Get a good buy on one now, has talking map and connects easily to laptop (USB).
As I said I have used them all and the PDA with talking map and Ozi CE is the best of both worlds.
AnswerID: 243877
Follow Up By: Willem - Friday, Jun 01, 2007 at 09:33
Oh Gaaawd..........Uncle Donut is going Hi Tech?...I gotta see this...LOL
FollowupID: 504806
Follow Up By: Des Lexic - Friday, Jun 01, 2007 at 11:04
Now listen here you donut muncher, I have been low tech for all my life and now I'm upgrading. LOL
Even an old codger like you could work these things out. I do reserve my comments cos I know it would be way beyond Roachies capabilities. LOL
FollowupID: 504839
Follow Up By: Blaze - Friday, Jun 01, 2007 at 11:29
Forgot to mention Trekkie, If you want the best thing around and you lots of money like most of the fourby owners on this site, I would actually go for a Garmin 7200
www.ja-gps.com.au/garmin_sp7200_1.htm
It does the best of both worlds:
7-inch touch-screen. Designed for larger vehicles such as RVs, it comes preloaded with City Navigator NT detailed maps for Australian city and rural areas. Also runs Ozi CE. Advanced sunlight-readable display. Remote control included.
Only $1939 and you can even put a reversing camera into also. If you get one, you can send it to me if you like to test for the first 12mths or so. LOL
FollowupID: 504845
Reply By: Member - Doug T (W.A) - Friday, Jun 01, 2007 at 00:46
Trekkie
You better rip into Terlins and get one of these ........No they are full ptice, better you get on the internet as I did and call J-A
www.ja-gps.com.au/garmin_nuvi660.aspx
And if you don't mind a smaller screen
www.ja-gps.com.au/garmin_quest_1.html
AnswerID: 243886
Follow Up By: Member - John D (VIC) - Friday, Jun 01, 2007 at 17:08
Trekkie, I've gotta back Doug up here, he put me on to the Garmin Quest which I bought online through ja, it arrived 2 days later & I can't fault it.
With the mapping software supplied I can create my routes & waypoints on the pc & download to the quest and any tracks that I have created on the quest can be uploaded to the pc... a great tool, looking forward to using it on our 5 week trip to the Kimberley's in July.
John D
FollowupID: 504924
Reply By: Mr Fawlty - Friday, Jun 01, 2007 at 10:06
One thing is for sure, the prices on these seem in somecases become quite sensible. I'm trying to ascertain what exactly one misses out on in the $350 models as opposed to the $1500 models. Maybe a case thinking that more expensive is 4 times better, I don't know.
The Aldi one a mate has seems to be very good, has maps of the most obsure regions, even tracks in the Budawangs...
AnswerID: 243918
Reply By: Gronk - Friday, Jun 01, 2007 at 12:34
I don't have a gps device (yet ) but with looking at others that use one, they don't know where they're going !!!!!!!!!!!!!!
Seriously............once they punch in a destination, they just happily drive into the wild blue wonder and follow the prompts !!!!!
With a map, you look at it before leaving and roughly work out direction and roads or intersections etc to look out for, so you get a feeling for the intended journey ( nearly always )
With a gps device, I know of several times the person ended up going down some overgrown track that they weren't sure was the proper way to go !!!!
Awwhh, go on....tell me I'm wrong lol..........
AnswerID: 243941
Follow Up By: Harry - Friday, Jun 01, 2007 at 14:02
I use GPS and paper maps together.
It's an invaluable tool that keeps you on the correct track.
I know quite a few people that can't use their GPS properly, but that doesn't make it an unnecessary tool.
Grab a hold of somebodies unit, find out how to use it and you'll probably be amazed at it's virtues.(make sure they know how to )
What happens when you arrive at a track intersection your not sure about your position and that happens sometimes. The GPS will give you co-ords so you can plot your position.
It will also allow you to detour and then the little bugger will tell you which direction to keep heading back for.
Try 1.
FollowupID: 504883
Reply By: curious - Friday, Jun 01, 2007 at 21:21
I use GPS at work (150 trucks on GPS) and for taking my Prado into the bush. What I learn from personal use tends to help what I do at work and vice versa. I've had a great run with my Garmin GPSmap60Cx yet the cheaper Garmin 60 is also quite good (1/3 the price). I've found that the more expensive unit has a much faster processor and pulls in more satellites. Also had a Garmin 72, again a good unit but slower processor. If you connect with a notebook PC, the USB connection is much faster than the old serial connection. Most of the posts here have covered the subject pretty well - just depends on what you want to do with your GPS.
- Peter
AnswerID: 244079
