Site Search
Section Image
lpg - does injection avoid airflow meter damage?
Submitted: Friday, Jun 01, 2007 at 14:51
pathfinder
Hi - I've heard that injected lpg overcomes traditional problems of backfiring etc and associated damage to airboxes/airflow meters etc. Intuitively this would seem correct as lpg is being injected directly into the cylinder, but does injection overcome all traditional lpg problems and reduce the need to have electrics/ignition absolutely spot on?
I presume injection also results in better lpg power/economy, but presumably still not as good as petrol despite the hype?
Advertisement
ThreadID: 46146 Replies: 3
Views: 475 FollowUps: None
AnswerID: 243989   Submitted: Friday, Jun 01, 2007 at 15:28
hl replied:
You will find that the injection is done into the inlet manifold, not directly into the combustion chamber. Therefore the same problems could still happen.
Reply 1 of 3
AnswerID: 244025   Submitted: Friday, Jun 01, 2007 at 19:15
Andrew-rodeo replied:
YES, having lpg injection avoids all problems associated with lpg in the past. You no longer have an inlet manifold full of lpg vapour, the injector is located as close as possible the the petrol injector and only injects the lpg vapour as required. The lpg computer is linked the the factory ecu and emulates the petrol injection.
Reply 2 of 3
AnswerID: 244205   Submitted: Saturday, Jun 02, 2007 at 18:18
Dallas from Team Green Autogas replied:
G'day Pathfinder,
Andrew is spot on mate. The problem in the past has been that you have an inlet manifold full of lpg so if you get a crossfire from your ignition system then you ignite the entire manifold wurth of lpg resulting in backfires, blowing the airbox & airflow/mass meters to pieces.
With the new vapour injection system you have brass fittings fitted into the inlet manifold as close to the inlet valve as possible so you don't have a complete manifold full of fuel. This means there's not as much opportunity for a backfire as such. The worst that you'll get is a stutter / miss as you would get on petrol.
The vapour injection system will give you better efficiency than the standard venturi system so over the long run it would be the better investment but just remember that you'll really need to do more K's before you reach your payback point.
Dallas Green
Team Green AutogasTeam Green Autogas
Member: Lapsed Membership
Reply 3 of 3
